查看: 1523|回復: 2
單片機設置矩陣按鍵 計算相應1到16的平方
ID:758358 發表于 2020-5-22 16:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit du = P2^6;         //段選
sbit we        = P2^7;         //位選
uint k;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f};
void delay(uint z)
{  uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0; y--);
void display(uint k)
         uchar bai,shi,ge;
         bai = k / 100;
         shi = k % 100 / 10;
         ge = k % 10;
                P0 = 0xff;
                we = 1;
                P0 = 0xfe;
                we = 0;
                du = 1;
                P0 = table[bai];
                du = 0;
                delay(5);
                P0 = 0xff;
                we = 1;
                P0 = 0xfd;
                we = 0;
                du = 1;
                P0 = table[shi];
                du = 0;
                delay(5);
                P0 = 0xff;
                we = 1;
                P0 = 0xfb;
                we = 0;
                du = 1;
                P0 = table[ge];
                du = 0;
                delay(5);
void keyscan()
{        P3 = 0xf0;
        if(P3 != 0xf0)
        {        delay(10);//軟件消抖
                if(P3 != 0xf0)
                        switch(P3)
                {        case 0xe0: k = 1; break;
                        case 0xd0: k = 2; break;
                        case 0xb0: k = 3; break;
                        case 0x70: k = 4; break;        }
                P3 = 0x0f;
                 switch(P3)
                {        case 0x0e: k = k; break;
                        case 0x0d: k = k + 4; break;
                        case 0x0b: k = k + 8; break;
                        case 0x07: k = k + 12; break;  }
                        while(P3 != 0x0f);//松手檢測
void main ()
{        while(1)
        {        keyscan();
                display(k*k);
這是源代碼
ID:1 發表于 2020-5-24 01:30 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
