查看: 1790|回復(fù): 0
DTH11溫度傳感器模塊
ID:757374 發(fā)表于 2020-5-21 14:41 | 顯示全部樓層 |閱讀模式
DTH11溫度傳感器模塊
#include <reg51.h>
#include <intrins.h>
#include "dht11.h"
//typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           ???8?????  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  ???8?????  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           ???16????? */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           ???16????? */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           ???32????? */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           ???32????? */
typedef float          F32;      /* single precision floating point variable (32bits) ??????(32???) */
typedef double         F64;      /* double precision floating point variable (64bits) ??????(64???) */
#define   Data_0_time    4
sbit  dht=P3^6;
U8  U8FLAG,k;
U8  U8count,U8temp;
//U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];  //????????
U8  indata[5];
U8  count, count_r=0;
U8  str[5]={"RS232"};
U16 U16temp1,U16temp2;
void Delay(U16 j)
        U8 i;
        for(;j>0;j--)
                for(i=0;i<27;i++);
void  Delay_10us(void)
        U8 i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
void COM(void)
        U8 i;
        for(i=0;i<8;i++)
                U8FLAG=2;
                while((!dht)&&U8FLAG++);
                Delay_10us();
                Delay_10us();
                Delay_10us();
                U8temp=0;
                if(dht)U8temp=1;
                U8FLAG=2;
                while((dht)&&U8FLAG++);
                if(U8FLAG==1)break;
                U8comdata<<=1;
                U8comdata|=U8temp;        //0
        }//rof
void RH(void)
        dht=0;
        Delay(180);
        dht=1;
        Delay_10us();
        Delay_10us();
        Delay_10us();
        Delay_10us();
        dht=1;
        if(!dht)                 //T !
                U8FLAG=2;
                U8FLAG=2;
                COM();
                U8RH_data_H_temp=U8comdata;
                COM();
                U8RH_data_L_temp=U8comdata;
                COM();
                U8T_data_H_temp=U8comdata;
                COM();
                U8T_data_L_temp=U8comdata;
                COM();
                U8checkdata_temp=U8comdata;
                dht=1;
                U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
                if(U8temp==U8checkdata_temp)
                        U8RH_data_H=U8RH_data_H_temp;
                        U8RH_data_L=U8RH_data_L_temp;
                        U8T_data_H=U8T_data_H_temp;
                        U8T_data_L=U8T_data_L_temp;
                        U8checkdata=U8checkdata_temp;
                }//fi
        }//fi
//void main()
//        while(1)
//                RH();
//                str[0]=U8RH_data_H;
//                str[1]=U8RH_data_L;
//                str[2]=U8T_data_H;
//                str[3]=U8T_data_L;
//                str[4]=U8checkdata;
//                Delay(20000);
//        }//elihw
//}// main
