能否直接添加 dis_smg[3] = smg_du[set_d / 1000] & 0xdf;
- #include <reg52.h>
- #include <intrins.h>
- #include "eepom52.h"
- #define uchar unsigned char
- #define uint unsigned int</div><div>//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
- 0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff}; //斷碼
- //數(shù)碼管位選定義
- uchar code smg_we[]={0xe0,0xd0,0xb0,0x70};
- uchar dis_smg[8] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};</div><div>sbit smg_we1 = P3^4; //數(shù)碼管位選定義
- sbit smg_we2 = P3^5;
- sbit smg_we3 = P3^6;
- sbit smg_we4 = P3^7;</div><div>sbit c_send = P3^2; //超聲波發(fā)射
- sbit c_recive = P3^3; //超聲波接收
- uchar flag_hc_value; //超聲波中間變量</div><div>sbit beep = P2^3; //蜂鳴器IO口定義
- bit flag_key_b_en,flag_key_set_en; //按鍵蜂鳴器使能</div><div>
- uchar smg_i = 3; //顯示數(shù)碼管的個位數(shù)
- bit flag_300ms ;</div><div>bit key_500ms ;</div><div>
- long distance; //距離
- uint set_d; //距離
- bit flag_csb_juli; //超聲波超出量程
- uint flag_time0; //用來保存定時器0的時候的</div><div>// 按鍵的IO變量的定義
- uchar key_can; //按鍵值的變量
- uchar zd_break_en,zd_break_value; //自動退出設(shè)置界面
- uchar menu_shudu = 10; //用來控制連加的速度
- bit flag_lj_en; //按鍵連加使能
- bit flag_lj_3_en; //按鍵連3次連加后使能 加的數(shù)就越大了
- uchar key_time,flag_value; //用做連加的中間變量
- uchar menu_1; //菜單設(shè)計的變量
- uchar a_a;</div><div>
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- }</div><div>/***********************處理距離函數(shù)****************************/
- void smg_display()
- dis_smg[0] = smg_du[distance % 10];
- dis_smg[1] = smg_du[distance / 10 % 10];
- dis_smg[2] = smg_du[distance / 100 % 10] & 0x7f;
- }</div><div>/******************把數(shù)據(jù)保存到單片機內(nèi)部eepom中******************/
- void write_eepom()
- SectorErase(0x2000);
- byte_write(0x2000, set_d % 256);
- byte_write(0x2001, set_d / 256);
- byte_write(0x2058, a_a);
- }</div><div>/******************把數(shù)據(jù)從單片機內(nèi)部eepom中讀出來*****************/
- void read_eepom()
- set_d = byte_read(0x2001);
- set_d <<= 8;
- set_d |= byte_read(0x2000);
- a_a = byte_read(0x2058);
- }</div><div>/**************開機自檢eepom初始化*****************/
- void init_eepom()
- read_eepom(); //先讀
- if(a_a != 1) //新的單片機初始單片機內(nèi)問EEPOM
- set_d = 100;
- a_a = 1;
- write_eepom();
- /****************獨立按鍵處理函數(shù)********************/
- void key()
- static uchar key_new = 0,key_old = 0,key_value = 0;
- if(key_new == 0)
- { //按鍵松開的時候做松手檢測
- if((P2 & 0x07) == 0x07)
- key_value ++;
- else
- key_value = 0;
- if(key_value >= 5)
- key_value = 0;
- key_new = 1;
- flag_lj_en = 0; //關(guān)閉連加使能
- flag_lj_3_en = 0; //關(guān)閉3秒后使能
- flag_value = 0; //清零
- key_time = 0;
- write_eepom();
- else
- if((P2 & 0x07) != 0x07)
- key_value ++; //按鍵按下的時候
- else
- key_value = 0;
- key_value = 0;
- key_new = 0;
- flag_lj_en = 1; //連加使能
- zd_break_en = 1; //自動退出設(shè)置界使能
- zd_break_value = 0; //自動退出設(shè)置界變量清零
- flag_key_b_en = 1; //按鍵蜂鳴器使能
- key_can = 20;
- if(key_500ms == 1) //連加
- key_500ms = 0;
- key_new = 0;
- key_old = 1;
- if((key_new == 0) && (key_old == 1))
- switch(P2 & 0x07)
- case 0x06: key_can = 3; break; //得到k2鍵值
- case 0x05: key_can = 2; break; //得到k3鍵值
- case 0x03: key_can = 1; break; //得到k4鍵值
- // dis_smg[3] = smg_du[key_can % 10];</div><div> }
- key_old = key_new;
- }</div><div>
- void smg_we_switch(uchar i)
- switch(i)
- case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
- case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
- case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
- case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
- }</div><div>/***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= smg_i)
- i = 0;
- // P1 = 0xff; //段選
- // P3 = 0xf0 | (P3 & 0x0f); //位選
- // P3 = smg_we[i] | (P3 & 0x0f); //位選
- smg_we_switch(i);
- P1 = dis_smg[i]; //段選 </div><div>}</div><div>void delay()
- _nop_(); //執(zhí)行一條_nop_()指令就是1us
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- }</div><div>
- /*********************超聲波測距程序*****************************/
- void send_wave()
- c_send = 1; //10us的高電平觸發(fā)
- delay();
- c_send = 0;
- TH0 = 0; //給定時器0清零
- TL0 = 0;
- TR0 = 0; //關(guān)定時器0定時
- flag_hc_value = 0;
- while(!c_recive); //當(dāng)c_recive為零時等待
- TR0=1;
- while(c_recive) //當(dāng)c_recive為1計數(shù)并等待
- flag_time0 = TH0 * 256 + TL0;
- if((flag_hc_value > 1) || (flag_time0 > 65000)) //當(dāng)超聲波超過測量范圍時,顯示3個888
- TR0 = 0;
- flag_csb_juli = 2;
- distance = 888;
- break ;
- else
- flag_csb_juli = 1;
- if(flag_csb_juli == 1)
- TR0=0; //關(guān)定時器0定時
- distance = TH0; //讀出定時器0的時間
- distance = distance * 256 + TL0;
- distance +=( flag_hc_value * 65536);//算出超聲波測距的時間 得到單位是ms
- distance *= 0.017; // 0.017 = 340M / 2 = 170M = 0.017M 算出來是米
- if(distance > 350) //距離 = 速度 * 時間
- distance = 888; //如果大于3.8m就超出超聲波的量程
- }</div><div>
- /*********************定時器0、定時器1初始化******************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X11; //定時器0、定時器1工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- ET1 = 1; //開定時器1中斷
- TR1 = 1; //允許定時器1定時
- }</div><div>/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
- void key_with()
- if(key_can == 1)
- menu_1 ++;
- if(menu_1 >= 2)
- menu_1 = 0;
- if(menu_1 == 0)
- menu_shudu = 20;
- dis_smg[1] = smg_du[distance / 10 % 10] ;
- smg_i = 3;
- if(menu_1 == 1)
- menu_shudu = 1;
- dis_smg[0] = smg_du[set_d % 10];
- dis_smg[1] = smg_du[set_d / 10 % 10];
- dis_smg[2] = smg_du[set_d / 100 % 10] & 0x7f ;
- dis_smg[3] = 0x88;
- smg_i = 4;
- if(menu_1 == 1) //設(shè)置高溫報警
- if(flag_lj_3_en == 0) //三次連加之后速度加快
- menu_shudu = 10 ; //500ms 加減一次
- else
- menu_shudu = 1; //250ms 加減一次
- if(key_can == 2)
- set_d ++ ; //按鍵按下未松開自動加三次
- if(set_d > 350)
- set_d = 350;
- dis_smg[0] = smg_du[set_d % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[set_d / 10 % 10] ; //取個位顯示
- dis_smg[2] = smg_du[set_d / 100 % 10] & 0x7f; //取十位顯示
- dis_smg[3] = 0x88; //a
- if(key_can == 3)
- set_d -- ; //按鍵按下未松開自動加三次
- if(set_d <= 1)
- set_d = 1;
- dis_smg[2] = smg_du[set_d / 100 % 10] & 0x7f ; //取十位顯示
- // write_eepom();
- } </div><div>/****************報警函數(shù)***************/
- void clock_h_l()
- static uchar value;
- if(distance <= set_d)
- value ++; //消除實際距離在設(shè)定距離左右變化時的干擾
- if(value >= 5)
- beep = ~beep; //蜂鳴器報警
- else
- value = 0;
- beep = 1; //取消報警
- }</div><div>/****************按鍵按下蜂鳴器響下**********************/
- void key_beep()
- static uint value;
- if((flag_key_b_en == 1) && (flag_key_set_en == 1))
- beep = 0; //打開蜂鳴器
- value ++;
- if(value > 800)
- value = 0;
- flag_key_b_en = 0;
- beep = 1;//關(guān)閉蜂鳴器
- }</div><div>
- void main()
- send_wave(); //測距離函數(shù)
- smg_display(); //處理距離顯示函數(shù)
- time_init();
- init_eepom(); //讀eepom數(shù)據(jù)
- while(1)
- if(flag_300ms == 1)
- flag_300ms = 0;
- clock_h_l(); //報警函數(shù)
- if(menu_1 == 0)
- if(zd_break_en == 1) //自動退出設(shè)置界面程序
- zd_break_value ++; //每300ms加一次
- if(zd_break_value > 100) //30秒后自動退出設(shè)置界面
- menu_1 = 0; //
- smg_i = 3;
- zd_break_en = 0;
- key(); //按鍵函數(shù)
- if(key_can < 10)
- key_with(); //按鍵處理函數(shù)
- }</div><div>
- /*********************定時器0中斷服務(wù)程序 用做超聲波測距的************************/
- void time0_int() interrupt 1
- set_d ++; // TH0 TL0 到65536后溢出中斷
- } </div><div>/*********************定時器0中斷服務(wù)程序************************/
- void time1_int() interrupt 3
- static uchar value; //定時10ms中斷一次
- TH1 = 0xf8;
- TL1 = 0x30; //2ms
- display(); //數(shù)碼管顯示函數(shù)
- value++;
- if(value >= 150)
- value = 0;
- flag_300ms = 1;
- if(value % 25 == 0)
- if(flag_lj_en == 1) //按下按鍵使能 50ms
- key_time ++;
- if(key_time >= menu_shudu) //500ms
- key_time = 0;
- key_500ms = 1; //500ms
- flag_value ++;
- if(flag_value >= 3)
- flag_value = 10;
- flag_lj_3_en = 1; //3次后1.5秒后連加大些
