用于紅外檢測加聚光罩距離可達100米左右
- /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2016
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- // UART0 baud rate initial setting
- void InitialUART0_Timer1(UINT32 u32Baudrate) //T1M = 1, SMOD = 1
- P06_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- P07_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- SCON = 0x50; //UART0 Mode1,REN=1,TI=1
- TMOD |= 0x20; //Timer1 Mode1
- set_SMOD; //UART0 Double Rate Enable
- set_T1M;
- clr_BRCK; //Serial port 0 baud rate clock source = Timer1
- #ifdef FOSC_160000
- TH1 = 256 - (1000000/u32Baudrate+1); /*16 MHz */
- #endif
- #ifdef FOSC_166000
- TH1 = 256 - (1037500/u32Baudrate); /*16.6 MHz */
- #endif
- set_TR1;
- set_TI; //For printf function must setting TI = 1
- void InitialUART0_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
- T3CON &= 0xF8; //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)
- set_BRCK; //UART0 baud rate clock source = Timer3
- RH3 = HIBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- RL3 = LOBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- #endif
- RH3 = HIBYTE(65536 - (1037500/u32Baudrate)); /*16.6 MHz */
- RL3 = LOBYTE(65536 - (1037500/u32Baudrate)); /*16.6 MHz */
- #endif
- set_TR3; //Trigger Timer3
- UINT8 Receive_Data_From_UART0(void)
- UINT8 c;
- while (!RI);
- c = SBUF;
- RI = 0;
- return (c);
- void Send_Data_To_UART0 (UINT8 c)
- TI = 0;
- SBUF = c;
- while(TI==0);
- // UART1 baud rate initial setting
- void InitialUART1_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
- P02_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- P16_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- SCON_1 = 0x50; //UART1 Mode1,REN_1=1,TI_1=1
- T3CON = 0x08; //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1), UART1 in MODE 1
- clr_BRCK;
- #endif
- #endif
- UINT8 Receive_Data_From_UART1(void)
- UINT8 c;
- while (!RI_1);
- c = SBUF_1;
- RI_1 = 0;
- return (c);
- void Send_Data_To_UART1 (UINT8 c)
- TI_1 = 0;
- SBUF_1 = c;
- while(TI_1==0);
- #ifdef SW_Reset
- void SW_Reset(void)
- TA = 0xAA;
- TA = 0x55;
- set_SWRST;
- #endif
紅外發(fā)射程序(N76E003)原始.rar
(191.04 KB, 下載次數(shù): 43)
2020-5-13 12:17 上傳
