查看: 2575|回復(fù): 4
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS無法生成hex文件
#include <reg51.h>
#define SEG P2
#define SCAN P3
#define uint  unsigned int
uchar shu[] = {0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf9,0x80,0xc0,0xb0,0xc0,0xf8,0xc0,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//18030708
uchar seg[10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar sel[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char count=0;
unsigned int y,m;
void Timer0Interrupt(void) interrupt 1
    TH0 = 0x3C;
    TL0 = 0x0B0;
    count++;
void delay_1ms(uint x)
        uint i,j;
        for(i=0; i<x; i++)
           for(j=0; j<120; j++);
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = 0x3C;
    TL0 = 0x0B0;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
               for(m=0;m<8;m++)
                SCAN = ~0xff;
                SEG = shu[y+m];
                SCAN = ~sel[m];
                delay_1ms(1);
if(count==20){count=0;break;}}
void main(void)
           for(y=0;y<15;y++)
        InitTimer0();
ID:750491 發(fā)表于 2020-5-13 09:43 | 只看該作者
就是出現(xiàn)了這個(gè)*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
ID:213173 發(fā)表于 2020-5-13 10:14 | 只看該作者
ID:584814 發(fā)表于 2020-5-13 11:49 | 只看該作者
Keil 5 表示生成無壓力。ERROR L104: MULTIPLE PUBLIC DEFINITIONS可能是低版本的沒處理好變量以為是有重復(fù)定義,如果堅(jiān)持在低版本上生成可將似是而非的不同之處搞大點(diǎn)而不僅在大小寫。
評(píng)分
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:686878 發(fā)表于 2020-5-13 13:11 | 只看該作者
用Keil 4編譯沒有錯(cuò)誤啊
