查看: 1998|回復(fù): 0
為啥我這個(gè)單片機(jī)程序LED顯示會(huì)出現(xiàn)亂碼呢?
回帖獎(jiǎng)勵(lì) 20 黑幣 回復(fù)本帖可獲得 20 黑幣獎(jiǎng)勵(lì)! 每人限 1 次
這是源程序和電路圖
#include <reg52.h>
void displaym();
sbit en=P2^5;                //1602  6管腳
sbit rs=P2^7;         //1602端口        4管腳
sbit rw=P2^6;//lcd1602控制端口 5管腳
sbit num1=P1^0;                                                //占空比加1
sbit num2=P1^1;        //占空比減一
sbit num3=P1^2;        //正傳
sbit num4=P1^3;        //反轉(zhuǎn)
sbit num5=P1^4;        //開始停止切換
sbit out=P3^4;                                                         //PWM輸出用于正傳
sbit out1=P3^7;                        //PWM輸出用于反轉(zhuǎn)
uint zhuansu,flag,z1,z2,m,flag_1,zheng,fan,kai;
void delay(uint z)//延時(shí)1ms函數(shù)
uint x,y;
for(x=0;x<z;x++)
     for(y=0;y<110;y++);
void write_com(uchar com)//向1602寫一字節(jié)(控制指令)
  rs=0;
  P0=com;
  delay(5);
  en=0;
  delay(10);
  en=1;
void write_data(uchar date)//向1602寫一字節(jié)(數(shù)據(jù))
  rs=1;
  P0=date;
  delay(5);
  en=0;
  delay(5);
  en=1;
void init()//初始化函數(shù)
  en=0;
  rw=0;
  write_com(0x01);         //lcd初始化
  write_com(0x38);                                           //5X7顯示
  write_com(0x0c);                         //關(guān)閉光標(biāo)
  TMOD=0x01;               //定時(shí)器方式1
  TH0=0xdc;
  TL0=0x00;                //定時(shí)器裝入初值
  EA=1;                    //開總中斷
  ET0=1;                   //定時(shí)器0開中斷
  TR0=1;
  EX1=1;
IT1=1;                 //定時(shí)器啟動(dòng)
TH1=0xfc;
  TL1=0x66;//定時(shí)100us
  ET1=1;                   //定時(shí)器1開中斷
  TR1=1;
  write_com(0x80);
  write_data('V');
  write_data(':');
  write_com(0x87);                 //第一行顯示轉(zhuǎn)速
  write_data('r');
  write_data('p');
  write_data('m');
  write_com(0xc0);
  write_data('z');
  write_data('h');
  write_data('a');
  write_data('n');
  write_data('k');
  write_data('o');
  write_data('n');
  write_data('g');
  write_data('b');
  write_data('i');          //在第二行顯示zhankongbi:
  write_data(':');
  displaym();
void keyscan()  //鍵盤掃描函數(shù)
  if(num1==0)
    delay(5);      //消除抖動(dòng)
         if(num1==0)
                if(m<=199)
                 m++;
                        displaym();        //設(shè)定占空比加一
  if(num2==0)
    delay(5);
         if(num2==0)
                  if(m>=1)
                m--;
                        displaym();                                        //設(shè)定占空比減一
    if(num3==0)
    delay(5);
         if(num3==0)
          zheng=1;                //正傳標(biāo)志置1
          fan=0;          // 反轉(zhuǎn)標(biāo)志置0
      if(num4==0)
    delay(5);
         if(num4==0)
          zheng=0;                 //正傳標(biāo)志置0
          fan=1;          // 反轉(zhuǎn)標(biāo)志置1
      if(num5==0)
    delay(5);
         if(num5==0)
         while(num5==0)         ;
          kai=1-kai;
void display()
  write_com(0x82);
  zhuansu=zhuansu*30;          //將兩秒內(nèi)的計(jì)數(shù)乘以30得到轉(zhuǎn)每分
  if(zhuansu/10000!=0)
   write_data(zhuansu/10000+0x30);                                                  //如果轉(zhuǎn)速的萬位不為0        正常顯示否則顯示空格
   write_data(' ');
  if(zhuansu/1000==0)
  write_data(' ');
  write_data(zhuansu%10000%1000+0x30);        //如果轉(zhuǎn)速小于1000 千位為空格 否則正常顯示
  if(zhuansu/100==0)
  write_data(' ');
  write_data(zhuansu%10000%1000/100+0x30);                                           //如果轉(zhuǎn)速小于100 百位為空格 否則正常顯示
    if(zhuansu/10==0)
  write_data(' ');
  write_data(zhuansu%10000%1000%100/10+0x30);                                  //如果轉(zhuǎn)速小于10 十位為空格 否則正常顯示
  write_data(zhuansu%10000%1000%100%10+0x30);
  write_com(0xd0);                          //如果沒有這句,當(dāng)中斷內(nèi)的顯示函數(shù)執(zhí)行完,就會(huì)在轉(zhuǎn)速的位置顯示占空比數(shù)據(jù),導(dǎo)致亂碼
void displaym()
write_com(0xcb);
   if(m/200%10!=0)
  write_data(m/200%10+0x30);                           //如果占空比百位不為0則顯示百位否則顯示空格
  write_data(' ');
  if(m/200%10==0&&m/20%10==0)
  write_data(' ');
  write_data(m/20%10+0x30);                                 //如果占空比小于10 十位正常顯示  否則顯示空格
  write_data(m/2%10+0x30);                                 //顯示個(gè)位
    flag_1=0;
        m=100;                                                         //占空比為100
        zhuansu=0;                                           //轉(zhuǎn)速初值0
        flag=0;
        zheng=1;                                  //初始化電機(jī)正轉(zhuǎn)動(dòng)
        fan=0;
    init();              //初始化
        keyscan();                                //鍵盤掃描程序
void int1()interrupt 2                                //外部中斷1脈沖技術(shù)記錄電機(jī)的轉(zhuǎn)速 電機(jī)轉(zhuǎn)一圈zhuansu加一
  zhuansu++;
void int2()interrupt 3                                  //定時(shí)器0顯示轉(zhuǎn)速
  TH0=0xdc;
  TL0=0x00;//定時(shí)10ms
  flag++;
  if(flag==200)                                   //計(jì)時(shí)到達(dá)2s
        display();                                        //顯示轉(zhuǎn)速
        zhuansu=0;                                          //轉(zhuǎn)速置0
        flag=0;
void int3()interrupt 1                                         //產(chǎn)生PWM
  TH1=0xff;
  TL1=0x00;//定時(shí)100us
          flag_1++;
        if(flag_1>199)
        flag_1=1;
        if(kai==1)                  //如果kai==1電機(jī)啟動(dòng)
        if(zheng==1)                                //電機(jī)正轉(zhuǎn)
        if(flag_1<m)                                          //小于占空比m輸出PWM=0輸出電壓為1
     {out=0;
         out1=1;}
           out=1;
           out1=1;
                 if(fan==1)                           //電機(jī)反轉(zhuǎn)
            out=1;
                out1=0;
         else        //大于m輸出PWM=1輸出電壓為0
            out=1;
                out1=1;
         if(kai==0)                          //kai=0電機(jī)停止轉(zhuǎn)動(dòng)
           out=1;
           out1=1;
