查看: 2772|回復: 1
基于單片機HC-06和LCD1602的藍牙小車程序
ID:656155 發表于 2020-5-12 16:28 | 顯示全部樓層 |閱讀模式
#include "reg52.h" //此文件中定義了單片機的一些特殊功能寄存器
#include<intrins.h>
typedef unsigned int u16;          //對數據類型進行聲明定義
typedef unsigned char u8;
sbit s1=P1^4;
sbit s2=P1^5;
sbit s3=P1^6;
sbit s4=P1^7;
static unsigned char DisNum = 0; //顯示用指針
bit      flag =0;//設定標志位,中斷溢出則標志位為1
#define LCD1602_DB  P0      //data bus 數據總線
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
u8 i;
u8 printf1[]="GO_Forward";
u8 printf2[]="Back_Run";
u8 printf3[]="Now:STOP";
u8 printf4[]="Left_Run";
u8 printf5[]="Right_Run";
void delay(u8 i)
while(i--);//電機延時
void run()
          s2=1;
    s1=0;//右輪
    delay(17);//delay越多,轉越猛
          s4=0;
    s3=1;//左輪
    delay(130);
void back()
          s2=0;
    s1=1;//右輪
          s4=1;
    s3=0;//左輪
    delay(130);
void left_run()
          s2=1;
          s1=0;//右輪
          s3=0;//左輪
          s4=1;
    delay(130);
void right_run()
          s2=0;
          s1=1;//右輪
          s3=1;//左輪
          s4=0;
    delay(130);
void stop()
    s1=0;//右輪
                s2=0;
          s3=0;//左輪
          s4=0;
void Read_Busy()           //忙檢測函數,判斷bit7是0,允許執行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(u8 cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(u8 dat)   //寫數據
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(u8 x,u8 y)  //坐標顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個字符
void give_where(u8 X, u8 Y,u8 DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
        X |= 0x80; //算出指令碼
        Lcd1602_Write_Cmd(X); //發命令字
        Lcd1602_Write_Data(DData); //發數據
void LcdShowStr(u8 x,u8 y,u8 *str)     //顯示字符串
    LcdSetCursor(x,y);      //當前字符的坐標
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開,5*8,8位數據
    Lcd1602_Write_Cmd(0x0c);//顯示開及光標設置
    Lcd1602_Write_Cmd(0x06);//顯示光標移動位置
    Lcd1602_Write_Cmd(0x01);    //清屏
void UsartInit()
        SCON=0X50;                        //設置為工作方式1
        TMOD=0X20;                        //設置計數器工作方式2
        PCON=0X80;                        //波特率加倍
        TH1=0XF3;                                //計數器初始值設置,注意波特率是4800的
        TL1=0XF3;
        ES=1;                                                //打開接收中斷
        EA=1;                                                //打開總中斷
        TR1=1;                                        //打開計數器
void zd0() interrupt 1                  //T0中斷用來計數器溢出,超過測距范圍
    flag=1;                                                         //中斷溢出標志
void Usart() interrupt 4
{         u8 receiveData;
   InitLcd1602();   //1602初始化
   i=SBUF;
        switch(i)
                case 'W':
                run();
          LcdShowStr(0,0,printf1);//顯示字符
                break;
                case 'B':
                back();
          LcdShowStr(0,0,printf2);//顯示字符
                break;
                case 'S':
                        stop();
          LcdShowStr(0,0,printf3);//顯示字符
                break;
          case 'L':
                        left_run();
          LcdShowStr(0,0,printf4);//顯示字符
                break;
                case 'R':
                        right_run();
          LcdShowStr(0,0,printf5);//顯示字符
                break;
        receiveData=SBUF;//出去接收到的數據
        RI = 0;//清除接收中斷標志位
        SBUF=receiveData;//將接收到的數據放入到發送寄存器
        while(!TI);                         //等待發送數據完成
        TI=0;                                                 //清除發送完成標志位
        UsartInit();     //        串口初始化
        while(1);
/* 此代碼和小車是剛剛接觸硬件兩個月之后完成的,如有錯漏,請見諒,據此完成的實物小車,轉向為坦克式轉向,藍牙使用手機軟件商店自帶的藍牙串口助手,可以正常實現,如有問題,可直接郵件聯系 */
ID:328014 發表于 2020-5-12 21:24 | 顯示全部樓層
好東東 能補一下 工程文件嗎?
