#include<regx51.h>
uchar y;
bit ce_anjian ( )
bit key=0;
P1=0xf3;
if(P1!=0xf3)
key=1;
key=0;
return(key);
void doudong_ys( )
uchar i,j;
for(i=0;i<30;i++)
for(j=0;j<248;j++);
void ce_jianzhi ( )
uchar i,j,p;
P1=0xf3;
i=P1&0x03;
if(i==0x02) j=1;
if(i==0x01) j=3;
P1=0xfc;
i=P1&0x0c;
if(i==0x08) p=0;
if(i==0x04) p=1;
y=j+p;
doudong_ys();
do
while(ce_anjian()==1);
doudong_ys();
}while(ce_anjian()==1);
if(ce_anjian()==1)
ce_jianzhi();
switch(y)
case 1:P2=0xfe;break;
case 2:P2=0xfd;break;
case 3:P2=0xfb;break;
case 4:P2=0xf7;break;
default:break;
這個是2X2的怎么改為3X3的?
