查看: 2192|回復: 1
單片機定時器時鐘
ID:456580 發表于 2020-5-11 00:38 | 顯示全部樓層 |閱讀模式
本帖最后由 指尖螺 于 2020-5-13 15:32 編輯
最近在學單片機,用匯編寫了一個時鐘,程序如下
                KEY_HH BIT P2.5
    KEY_MM BIT P2.6
    ORG   00H
    LJMP  START
    ORG   0BH
    LJMP  INTT0
    ORG   30H
  START:
          MOV   30H,#0
    MOV   31H,#0
    MOV   32H,#0
    MOV   33H,#0
    MOV   TH0,#4CH
    MOV   TL0,#00H
    MOV   TMOD,#01H
    MOV   TCON,#10H
    MOV   IE,  #82H
    MOV   R0,#10
    MOV   R1,#50  //??
    MOV   R2,#00  //??
    MOV   R3,#05  //?
   MAIN:  LCALL DISPLAY
          JNB   KEY_HH,SETHH
    JNB   KEY_MM,SETMM
          AJMP  MAIN
  SETHH:   LCALL DISPLAY
                LCALL DISPLAY
    JB    KEY_HH,MAIN
KEY_REPAT:     LCALL DISPLAY
                JNB   KEY_HH,KEY_REPAT
    INC   R3
    CJNE  R3,#24,MAIN_OUT
    MOV   R3,#0
MAIN_OUT:
             MOV   A,R3
    MOV   B,#10
    DIV   AB
    MOV   30H,A
    MOV   31H,B
                AJMP  MAIN
  SETMM:
          AJMP  MAIN
DISPLAY:
             MOV  DPTR,#TAB
       MOV  A,33H
       MOVC A,@A+DPTR
       MOV  P0,A
       CLR  P2.3
       LCALL DL2MS
       SETB P2.3
       MOV  A,32H
       MOVC A,@A+DPTR
       MOV  P0,A
       CLR  P2.2
       LCALL DL2MS
       SETB P2.2
          MOV  A,31H
       MOVC A,@A+DPTR
       MOV  C, 20H.0
    MOV  ACC.7,C
       MOV  P0,A
       CLR  P2.1
       LCALL DL2MS
       SETB P2.1
       MOV  A,30H
       MOVC A,@A+DPTR
       MOV  P0,A
       CLR  P2.0
       LCALL DL2MS
       SETB P2.0
       INTT0:    MOV  TH0,#4CH
                MOV  TL0,#00H
    DJNZ R0,INTTOUT
    MOV  R0,#10
    CPL  20H.0//1//1//0
                JNB  20H.0,INTTOUT
                CJNE R1,#00,INTTOUT_1
    CJNE R2,#00,INTTOUT_1
    CJNE R3,#06,INTTOUT_1
    CLR  P2.0
   INTTOUT_1:
    MOV  A,R2
    MOV  B,#10
    DIV  AB
    MOV  32H,A
    MOV  33H,B
    MOV  A,R3
    MOV  B,#10
    DIV  AB
    MOV  30H,A
    MOV  31H,B
                INC  R1
    CJNE R1,#60,INTTOUT
    MOV  R1,#0
    INC  R2
    CJNE R2,#60,INTTOUT
    MOV  R2,#0
    INC  R3
    CJNE R3,#24,INTTOUT
    MOV  R3,#0
INTTOUT:
                RETI
DL2MS:          MOV  34H,#20
DL1:            MOV  35H,#30
DL2:            DJNZ 35H,DL2
                DJNZ 34H,DL1
       RET
TAB:            DB        0C0H;0
                DB        0F9H;1
                DB        0A4H;2
                DB        0B0H;3
                DB        099H;4
                DB        092H;5
                DB        082H;6
                DB        0F8H;7
                DB        080H;8
                DB        090H;9 ;
      END
ID:1 發表于 2020-5-14 04:19 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
