查看: 2992|回復: 9
這是論壇上照學的一個單片機測直流電機轉速的一個例子,為啥我仿真的時候電機不轉
回帖獎勵 40 黑幣 回復本帖可獲得 20 黑幣獎勵! 每人限 1 次(中獎概率 80%)
圖片1為原圖,2為我照搬的圖
附上代碼-------
#include <reg51.h>
sbit open = P2^0;
sbit close = P2^1;
sbit swap = P2^2;
sbit sub_speed = P2^3;
sbit add_speed = P2^4;
sbit PWM1 = P3^0;
sbit PWM2 = P3^1;
/************************液晶顯示*************/
sbit E=P3^7;
sbit RW = P3^6;
sbit RS = P3^5;
sbit test = P3^4;
int time = 0;
int high = 20;
int period = 30;
int change = 0;
int flag = 0;
int num_medium = 0;
int num_display = 0;
int count_speed = 0;
uchar wword[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
/*******************延時t毫秒****************/
void delay(uchar t)
        uint i;
        while(t)
                    /*對于11.0592MHz時鐘,延時1ms*/
                  for(i=0;i<125;i++);
                  t--;
//寫命令函數LCD
void wc51r(uchar j)
            RS=0;
                  RW=0;
         P1=j;
                  E=1;
                  E=0;
                 delay(3);
//寫數據函數LCD
void wc51ddr(uchar j)
                  RS=1;
                  RW=0;
         P1=j;
                  E=1;
                  E=0;
                  delay(2);
//初始化函數LCD
void init()
         wc51r(0x01);  //清屏
         wc51r(0x38);  //使用8位數據,顯示兩行,使用5*7的字型
         wc51r(0x0c);  //顯示器件,光標開,字符不閃爍
         wc51r(0x06);  //字符不動,光標自動右移一格
/***********8T0中斷服務程序************PWM波的生成**********/
void time0_int(void) interrupt 1
                time++;
                TH0 = 0xec;
                TL0 = 0x78;
                if(change == 0)
                              PWM2 = 1;
                        if(time == high)
                              PWM1=0;
                        else if(time == period)
                                  PWM1 = 1;
                                  time = 0;
                 {            PWM1 = 1;
                                 if(time == high)
                                       PWM2=0;
                                   PWM2 = 1;
                                            time = 0;
/****T1中斷服務程序********單位時間(S)方波的個數*************/
void time1_int(void) interrupt 3
                count_speed++;
         if(count_speed == 20)
                {     count_speed = 0;
                           num_display = num_medium;
                           num_medium = 0;
/************************速度顯示的數據處理*********************/
void datamade()
uint data MM,NN;
             wc51r(0xc2);
          wc51ddr('S');
                   wc51ddr('p');
                   wc51ddr('e');
                   wc51ddr('e');
                   wc51ddr('d');
          wc51ddr(0x3a);
                   NN = num_display%100;
                   MM = num_display/100;
                    wc51ddr(wword[MM]);
MM = NN/10;
              NN = NN%10;
wc51ddr(wword[MM]);
wc51ddr(wword[NN]);
/**********通過按鍵實現對電機開關、調速、轉向的控制***************/
void motor_control()
                  if(open == 1)
                                EA = 1;
                  if(close == 1)
                                EA = 0;
                  if(swap == 1)
                                        change = ~change;
                                        while(swap != 0)
                        if(sub_speed == 1)
                                           high++;
                                         if(high == 30)
                                                EA=0;
                                       while(sub_speed != 0)
                         if(add_speed == 1)
                                                   high--;
                                                if(high == 5)
                                                   high = 5;
                                       while(add_speed != 0)
/***************************主函數*********************************/
                     P2 = 0x00;
                         ET0 = 1;
                         ET1 = 1;
                         TMOD = 0x11;
                         TH0 = 0xec;             //定時器T0設置參數
                         TL0 = 0x78;
                         TH1 = 0x3c;            //定時器T1設置參數
                         TL1 = 0xb0;
                         TR0 = 1;
                         TR1 = 1;
               init();               //液晶顯示初始化程序
                     wc51r(0x84);
                     wc51ddr('H');
                     wc51ddr('e');
                     wc51ddr('l');
                     wc51ddr('l');
                     wc51ddr('o');
                          if(test == 0)
                     num_medium++;
datamade();
motor_control();
ID:732506 發表于 2020-5-11 04:46 | 只看該作者
從圖上看電機不一樣。
ID:773778 發表于 2020-6-9 17:23 | 只看該作者
你的激勵源弄錯了吧,那不是電源
ID:600952 發表于 2020-6-10 09:53 | 只看該作者
是啊,那個好像不是電源,再可能就是電機不一樣,好像別的地方都一樣啊
你照搬的真規整,Q1 D1 R1 等都對應上了。
原圖沒發工程文件嗎?下下來直接用多好啊
希望對你有幫助
ID:656801 發表于 2020-6-10 14:31 | 只看該作者
P3口沒有配置上拉輸出吧? 單片機管腳能輸出高電平么?
ID:633896 發表于 2020-7-7 12:10 | 只看該作者
會不會是電機的問題
ID:595237 發表于 2020-7-8 00:15 | 只看該作者
只是一組波工作 能夠可以驅動電機嗎?
理論上 上一組與下一組 是 對稱的 就可以 驅動電機。
ID:764088 發表于 2020-7-8 15:56 | 只看該作者
不是抄軟件就能驅動電機的啊!您的直流電機參數如何?如所需 驅動電流 多大啊?您現在輸出配得上嗎?
ID:235954 發表于 2020-7-12 07:14 | 只看該作者
激勵源應該用錯了,你用5V,它實際要用12V或者24V才能驅動,你明顯是電橋的電壓沒有給對。
ID:795846 發表于 2020-7-16 10:38 | 只看該作者
你的電機需要多大電壓,你的電源能供多大的電壓。是不是你的電源供電不夠,導致電機不會轉。改一下電源的賦值
