麻煩大家?guī)臀铱纯次业乃{牙程序這樣寫有什么問題,還是控制不了對應的按鍵(藍牙程序標紅了)
#include <reg52.h> //調(diào)用單片機頭文件
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
#include <intrins.h>
//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0x05,0xdd,0x46,0x54,0x9c,0x34,0x24,0x5d,0x04,0x14,
0x0c,0xa4,0x27,0xc4,0x26,0x2e,0xff}; //斷碼
sbit smg_we1 = P0^4; //數(shù)碼管位選定義8
sbit smg_we2 = P0^5;
sbit smg_we3 = P0^6;
sbit smg_we4 = P0^7;
sbit beep = P3^7; //蜂鳴器IO口定義
uchar flag_start; //開始搶答標志位
uchar flag_weigui; //搶答違規(guī)標志位
uchar dis_smg[4] = {0}; //數(shù)碼管顯示緩沖區(qū)
uchar smg_i = 4; //顯示數(shù)碼管的個位數(shù)
uchar miao,s_time = 30,s2_time = 25; //時間
uchar flag_num; //號碼
uchar menu_1 ; //菜單設置變量
bit flag_200ms = 1; //200ms的標志位
uchar flag_qd_en; //搶答
uchar i,qd2_en;
static uchar value;
/***********************語音模塊控制IO口的定義************************/
sbit VBUSY= P0^0;
sbit VSDA = P0^1;
sbit VCS = P0^2;
sbit VSCL = P0^3;
* 名稱 : delay_1ms()
* 功能 : 延時1ms函數(shù)
* 輸入 : q
* 輸出 : 無
void delay_1ms(uint q) //延時1ms函數(shù)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************小延時函數(shù)**************************/
void delay_us (unsigned int us)
while(us--)
_nop_();
/***********************語音子程序************************/
void Send_threelines(unsigned char addr,uchar dat)
unsigned char i;
beep = 1;
VCS=0;
delay_1ms(5); /* 片選拉低5ms */
for(i=0;i<8;i++)
VSCL=0;
if(addr&0x01)
VSDA=1;
VSDA=0;
addr>>=1;
delay_us(150); /* 150us */
VSCL=1;
VCS=1;
delay_1ms(30);
if(dat == 1)
while(VBUSY == 0); //忙等待
/***************************數(shù)碼管位選函數(shù)****************************/
void smg_we_switch(uchar i)
switch(i)
case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
/********************獨立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨立按鍵程序
static uchar key_new;
key_can = 20;
P2 |= 0xff;
if((P2 & 0xff) != 0xff) //按鍵按下
delay_1ms(1); //按鍵消抖動
if(((P2 & 0xff) != 0xff) && (key_new == 1))
{ //確認是按鍵按下
key_new = 0;
switch(P2 & 0xff)
case 0xfe: key_can = 1; break; //得到按鍵值
case 0xfd: key_can = 2; break; //得到按鍵值
case 0xfb: key_can = 3; break; //得到按鍵值
case 0xf7: key_can = 4; break; //得到按鍵值
case 0xef: key_can = 5; break; //得到按鍵值
case 0xdf: key_can = 6; break; //得到按鍵值
case 0xbf: key_can = 7; break; //得到按鍵值
case 0x7f: key_can = 8; break; //得到按鍵值
key_new = 1;
uchar key_can1; //按鍵值
void key_1() //主持人獨立按鍵程序
key_can1 = 20;
P3 |= 0x64;
if((P3 & 0x64) != 0x64)
delay_1ms(1);
if(((P3 & 0x64) != 0x64) && (key_new == 1))
key_new = 0;
switch(P3 & 0x64)
case 0x60: key_can1 = 11; break;
case 0x44: key_can1 = 10; break;
case 0x24: key_can1 = 9; break;
if(key_can1 == 11) //復位
menu_1 = 0;
beep = 1;
flag_weigui = 0;
flag_qd_en = 0;
miao = s_time;
qd2_en = 0;
flag_num = 0;
flag_start = 0;
beep = 0; //叫一聲
delay_1ms(100);
beep = 1;
key_new = 1;
/******************按鍵處理函數(shù)*****************/
void key_with() //按鍵處理函數(shù)
if(key_can1 == 10) //設置按鍵
menu_1 ++;
if(menu_1 == 1)
dis_smg[0] = smg_du[s_time % 10]; //顯示設置值
dis_smg[1] = smg_du[s_time / 10 % 10]; //顯示設置值
dis_smg[2] = 0xfe;
dis_smg[3] = smg_du[10]; //顯示A
if(menu_1 == 2)
dis_smg[0] = smg_du[s2_time % 10]; //顯示設置值
dis_smg[1] = smg_du[s2_time / 10 % 10]; //顯示設置值
dis_smg[2] = 0xfe;
dis_smg[3] = smg_du[11]; //顯示B
if(menu_1 > 2)
menu_1 = 0;
if(key_can1 == 9) //開始搶答鍵
if(flag_start == 0)
Send_threelines(flag_num,1); // 語音
flag_start = 1;
if(key_can < 9)
if(menu_1 == 0)
if(flag_qd_en == 0) //沒有搶答
if(key_can == 1)
flag_num = 1; //1號選手
if(key_can == 2)
flag_num = 2; //2號選手
if(key_can == 3)
flag_num = 3; //3號選手
if(key_can == 4)
flag_num = 4; //4號選手
if(key_can == 5)
flag_num = 5; //5號選手
if(key_can == 6)
flag_num = 6; //6號選手
if(key_can == 7)
flag_num = 7; //7號選手
if(key_can == 8)
flag_num = 8; //8號選手
if(flag_start == 1) //開始搶答
flag_weigui = 0;
flag_qd_en = 1; //已經(jīng)搶答
if(qd2_en == 0)
qd2_en = 1;
dis_smg[0] = smg_du[flag_num]; //顯示選手號碼
Send_threelines(flag_num,1); // 搶答成功語音
miao = s2_time;
dis_smg[3] = smg_du[15]; //顯示設置值
dis_smg[2] = smg_du[15]; //顯示設置值
Send_threelines(flag_num+20,1); // 搶答違規(guī)語音
flag_weigui = 1; //違規(guī)了
if(menu_1 == 1)
if((key_can == 8) || (key_can == 2)) //加鍵
s_time ++; //設置倒計時加1
miao = s_time;
if(s_time >= 99)
s_time = 99;
if((key_can == 7) || (key_can == 1))
if(s_time > 3)
s_time -- ; //設置倒計時減1
miao = s_time;
if(menu_1 == 2)
s2_time ++; //設置倒計時加1
if(s2_time >= 99)
s2_time = 99;
if(s2_time > 3)
s2_time -- ; //設置倒計時減1
beep = 1;
/******************倒計時處理*****************/
void djs_dis() //倒計時處理
static uchar value;
if((flag_start == 1) && (flag_weigui == 0))
value ++;
if(value >= 5) //1s
value = 0;
if(miao != 0)
miao --; //倒計時減一
if(miao <= 5)
beep = ~beep; //蜂鳴器提示報警
if(miao == 0)
beep = 1; //關閉蜂鳴器
flag_start = 0;
dis_smg[3] = smg_du[miao / 10 % 10]; //顯示設置值
dis_smg[2] = smg_du[miao % 10]; //顯示設置值
if(qd2_en == 0)
Send_threelines(17,1); // 搶答結束 語音
Send_threelines(18,1); // 回答問題時間結束 語音
* 名稱 : display()
* 功能 : 數(shù)碼管顯示
* 輸入 : 無
* 輸出 : 無
void display() //數(shù)碼管顯示
static uchar i;
i++;
if(i >= smg_i)
i = 0;
P1 = 0xff; //消隱
smg_we_switch(i); //位選
P1 = dis_smg[ i]; //
/*************定時器0初始化程序***************/
void time_init() // 定時器0初始化程序
EA = 1; //開總中斷
TMOD = 0X01; //定時器0、工作方式1
ET0 = 1; //開定時器0中斷
TR0 = 1; //允許定時器0定時
/*************定時器0中斷服務程序***************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0xf8;
TL0 = 0x30; // 2ms
display(); //數(shù)碼管顯示
value ++;
if(value >= 100)
value = 0;
flag_200ms = 1;
//藍牙
void Uart_Init()
SCON = 0X50; //UART方式1;8位UART
REN = 1; //允許串行口接收數(shù)據(jù)
PCON = 0x00; //SMOD=0;波特率不加倍
TMOD = 0x20; //T1方式2,用于產(chǎn)生波特率
TH1 = 0xFD; //裝初值
TL1 = 0xFD;
TR1 = 1; //啟動定時器1
EA = 1; //打開全局中斷控制
ES = 1; //打開串行口中斷
void RECEIVE_DATA(void) interrupt 4 using 3
unsigned char temp = 0;
char i = 0;
ES=0;
temp = SBUF;
RI = 0;
switch(temp)
case'1' :
flag_start = 1; break;
case'2':
break;
ES=1;
/******************主程序**********************/
Uart_Init();
beep = 0; //開機叫一聲
delay_1ms(100);
P0 = P1 = P2 = P3 = 0XFF; //IO口全部輸出為1
time_init(); // 定時器0初始化程序
miao = s_time;
key(); //獨立按鍵程序
key_1(); //主持人獨立按鍵程序
if(flag_weigui == 0)
if((key_can < 20) || (key_can1 < 20))
key_with(); //按鍵處理函數(shù)
if(flag_200ms == 1)
flag_200ms = 0;
if(menu_1 == 0)
dis_smg[1] = 0xfe;
if(flag_weigui == 1) //違規(guī)了顯示FF
if(value == 0) //違規(guī)提示報警
value = 1;
for(i=0;i<6;i++)
beep = ~beep;
delay_1ms(100);
beep = 1;
djs_dis(); //倒計時處理
