ESP8266+MQTT- #include "onenet.h"
- extern unsigned char esp8266_buf[256];
- // 函數名稱: OneNET_DevLink
- // 函數功能: 與onenet創建連接
- // 入口參數: 無
- // 返回參數: 1-成功 0-失敗
- // 說明: 與onenet平臺建立連接
- _Bool OneNET_DevLink(void)
- MQTT_PACKET_STRUCTURE mqttPacket = {NULL, 0, 0, 0}; //協議包
- unsigned char *dataPtr;
- _Bool status = 1;
- printf("OneNET_DevLink\r\n");
- printf("PROID: %s, AUIF: %s, DEVID:%s\r\n", PROID, AUTH_INFO, DEVID);
- if(MQTT_PacketConnect(PROID, AUTH_INFO, DEVID, 256, 0, MQTT_QOS_LEVEL0, NULL, NULL, 0, &mqttPacket) == 0)
- ESP8266_SendData(mqttPacket._data, mqttPacket._len); //上傳平臺
- dataPtr = ESP8266_GetIPD(250); //等待平臺響應
- if(dataPtr != NULL)
- if(MQTT_UnPacketRecv(dataPtr) == MQTT_PKT_CONNACK)
- switch(MQTT_UnPacketConnectAck(dataPtr))
- case 0:printf("Tips: 連接成功\r\n");status = 0;
- break;
- case 1:printf("WARN: 連接失敗:協議錯誤\r\n");
- break;
- case 2:printf("WARN: 連接失敗:非法的clientid\r\n");
- break;
- case 3:printf("WARN: 連接失敗:服務器失敗\r\n");
- break;
- case 4:printf("WARN: 連接失敗:用戶名或密碼錯誤\r\n");
- break;
- case 5:printf("WARN: 連接失敗:非法鏈接(比如token非法)\r\n");
- break;
- default:printf("ERR: 連接失敗:未知錯誤\r\n");
- break;
- MQTT_DeleteBuffer(&mqttPacket); //刪包
- else
- printf( "WARN: MQTT_PacketConnect Failed\r\n");
- return status;
- unsigned char OneNET_FillBuf(char *buf)
- char text[32];
- memset(text, 0, sizeof(text));
- strcpy(buf, ",;");
- sprintf(text, "Tempreture,%2.1f;", 23.4);
- strcat(buf, text);
- sprintf(text, "Humidity,%2.1f;", 66.8);
- return strlen(buf);
- //json格式打包函數,type=5的方式
- int MqttSample_PackDataByJson5(char *buf)
- char text[32];
- //MQTT協議采用type=2方式封裝數據函數(二進制發送數據)
- //payload:存儲打包的數據
- //bin是發送的數組的首地址
- //size是數組的長度
- int MqttSample_PackDataByBinary2(u8 *payload,u8 *bin, uint32_t size)
- int payload_len;
- char json[]="{\"ds_id\":\"binary\"}";
- unsigned short json_len;
- payload_len = 1 + 2 + strlen(json)/sizeof(char);
- json_len = strlen(json)/sizeof(char);
- //Byte1,數據點類型指示:type=2,二進制數據
- payload[0] = '\x02';
- //Byte2、Byte3指示后面json字符串長度
- payload[1] = (json_len & 0xFF00) >> 8;
- payload[2] = json_len & 0xFF;
- //把json復制到t_payload數組中
- memcpy(payload+3, json, json_len);
- payload[payload_len] = (size & 0xFF000000)>>24;
- payload[payload_len+1]=(size & 0x00FF0000)>>16;
- payload[payload_len+2]=(size & 0x0000FF00)>>8;
- payload[payload_len+3]=(size & 0x000000FF);
- for(u32 i=0; i<size+4; i++)
- payload[payload_len+4+i]=bin[i];
- return payload_len+size+4;
- // 函數名稱: OneNET_SendData
- // 函數功能: 上傳數據到平臺
- // 入口參數: buf: 存儲打包數據的數組
- // type: 發送數據的格式
- // bin: 要發送的二進制數組的首地址
- // size: 要發送的二進制數組大長度
- // 返回參數: 無
- // 說明:
- void OneNET_SendData(u8 *buf,u8 type,u8 *bin,u16 size)
- short body_len = 0;
- switch(type)
- case 5:body_len = OneNET_FillBuf((char *)buf); //獲取當前需要發送的json數據流的總長度
- break;
- case 2:body_len = MqttSample_PackDataByBinary2(buf,bin, size); //獲取當前需要發送的二進制打包數組的長度
- break;
- default:
- break;
- if(body_len)
- if(MQTT_PacketSaveData(DEVID,body_len, NULL, type, &mqttPacket) == 0) //封包
- for(int i=0; i < body_len; i++)
- mqttPacket._data[mqttPacket._len++] = buf[i];
- ESP8266_SendData(mqttPacket._data, mqttPacket._len); //上傳數據到平臺
- printf("Send %d Bytes\r\n", mqttPacket._len);
- else
- printf("WARN: EDP_NewBuffer Failed\r\n");
- // 函數名稱: OneNET_RevPro
- // 函數功能: 平臺返回數據檢測
- // 入口參數: dataPtr:平臺返回的數據
- // 返回參數: 無
- // 說明:
- void OneNET_RevPro(unsigned char *cmd)
- char *req_payload = NULL;
- char *cmdid_topic = NULL;
- unsigned char type = 0;
- short result = 0;
- char *dataPtr = NULL;
- char numBuf[10];
- int num = 0;
- type = MQTT_UnPacketRecv(cmd);
- switch(type)
- case MQTT_PKT_CMD: //命令下發
- result = MQTT_UnPacketCmd(cmd, &cmdid_topic, &req_payload); //解出topic和消息體
- if(result == 0)
- printf("cmdid: %s, req: %s\r\n", cmdid_topic, req_payload);
- if(MQTT_PacketCmdResp(cmdid_topic, req_payload, &mqttPacket) == 0) //命令回復組包
- printf("Tips: Send CmdResp\r\n");
- ESP8266_SendData(mqttPacket._data, mqttPacket._len); //回復命令
- break;
- case MQTT_PKT_PUBACK: //發送Publish消息,平臺回復的Ack
- if(MQTT_UnPacketPublishAck(cmd) == 0)
- printf("Tips: MQTT Publish Send OK\r\n");
- break;
- default:
- result = -1;
- break;
- ESP8266_ClearBuff(); //清空緩存
- if(result == -1)
- return;
- dataPtr = strchr(req_payload, '{'); //搜索'}'
- if(dataPtr != NULL && result != -1) //如果找到了
- dataPtr++;
- while(*dataPtr >= '0' && *dataPtr <= '9') //判斷是否是下發的命令控制數據
- numBuf[num++] = *dataPtr++;
- num = atoi((const char *)numBuf); //轉為數值形式
- if(strstr((char *)req_payload, "redled")) //搜索"redled"
- if(num == 1) //控制數據如果為1,代表開
- LED0 = 0;
- else if(num == 0) //控制數據如果為0,代表關
- LED0 = 1;
- //下同
- else if(strstr((char *)req_payload, "greenled"))
- if(num == 1)
- LED1 = 0;
- else if(num == 0)
- LED1 = 1;
- else if(strstr((char *)req_payload, "allled"))
- if(num == 1)
- LED0 = 0;
- LED1 = 0;
- else if(num == 0)
- LED0 = 1;
- LED1 = 1;
- if(type == MQTT_PKT_CMD || type == MQTT_PKT_PUBLISH)
- MQTT_FreeBuffer(cmdid_topic);
- MQTT_FreeBuffer(req_payload);
復制代碼- #include "main.h"
- int main()
- u16 timeCount = 0; //發送間隔變量
- u8 *dataPtr = NULL;
- u8 data[10]={0x12,0x23,0x45,0x68,0x79,0xAB,0x00,0xEF};
- u8 buf[256];
- Stm32_Clock_Init(9); //系統時鐘設置
- uart_init(72,9600); //串口初始化為9600
- delay_init(72); //延時初始化
- LED_Init(); //初始化與LED連接的硬件接口
- ESP8266_Init(); //初始化ESP8266
- while(OneNET_DevLink()) //接入OneNET
- delay_ms(500);
- delay_ms(250);
- while(1)
- if(++timeCount >= 1000) //發送間隔5s
- printf( "OneNET_SendData\r\n");
- OneNET_SendData(buf,2,data,8); //發送數據
- timeCount = 0;
- dataPtr = ESP8266_GetIPD(0);
- OneNET_RevPro(dataPtr);
- delay_ms(10);
ESP8266和MQTT協議.7z
2020-5-6 13:59 上傳
下載積分: 黑幣 -5
103.88 KB, 下載次數: 29, 下載積分: 黑幣 -5
