#include <REGX52.H> //包含51單片機相關的頭文件
#include <intrins.h>
sbit LeftIR=P3^5; //定義前方左側(cè)紅外探頭端口
sbit RightIR=P3^4; //定義前方右側(cè)紅外探頭端口
sbit IN1=P1^2; //定義左側(cè)電機驅(qū)動A端
sbit IN2=P1^3; //定義左側(cè)電機驅(qū)動B端
sbit IN3=P1^4; //定義右側(cè)電機驅(qū)動A端
sbit IN4=P1^5;
sbit EN1=P1^6;
sbit EN2=P1^0;
sbit Beep=P2^3; //定義蜂鳴器端口
sbit IRIN=P3^3; //定義紅外接收端口
sbit p00=P0^0; //LED
sbit p01=P0^1; //LED
sbit p02=P0^2; //LED
sbit p03=P0^3; //LED
sbit p04=P0^4; //LED
sbit p05=P0^5; //LED
sbit p06=P0^6; //LED
sbit p07=P0^7; //LED
sbit sda=P1^1;
sbit key=P3^2;
#define Left_moto_pwm P1_6 //PWM信號端
#define Right_moto_pwm P1_7 //PWM信號端
#define Left_moto_go {P1_2=1,P1_3=0;} //左電機向前走
#define Left_moto_back {P1_2=0,P1_3=1;} //左邊電機向后轉(zhuǎn)
#define Left_moto_Stop {P1_2=0,P1_3=0;} //左邊電機停轉(zhuǎn)
#define Right_moto_go {P1_4=1,P1_5=0;} //右邊電機向前走
#define Right_moto_back {P1_4=0,P1_5=1;} //右邊電機向后走
#define Right_moto_Stop {P1_4=0,P1_5=0;} //右邊電機停轉(zhuǎn)
unsigned char pwm_val_left =0;//變量定義
unsigned char push_val_left =0;// 左電機占空比N/20
unsigned char pwm_val_right =0;
unsigned char push_val_right=0;// 右電機占空比N/20
unsigned char code RecvData[]={0x19,0x18,0x52,0x5A,0x08,0x1C,0x16,0x45,0x46,0x47,0x0D,0x0E,0x00,0x0F};
unsigned char temp = 1;
unsigned char IRCOM[7];//接收數(shù)據(jù)緩沖區(qū)
unsigned int z;
bit Right_moto_stop=1;
bit Left_moto_stop =1;
unsigned int time3=0;
void tingzhi(void)
P1_2 = 0;
P1_3 = 0;
P1_4 = 0;
P1_5 = 0;
void qianjin(void)
push_val_left=3; //速度調(diào)節(jié)變量 0-20。。。0最小,20最大
push_val_right=3;
Left_moto_go ; //左電機往前走
Right_moto_go ; //右電機往前走
void houtui()
push_val_left=12; //速度調(diào)節(jié)變量 0-20。。。0最小,20最大
push_val_right=12;
Left_moto_back ; //左電機往前走
Right_moto_back ; //右電機往前走
void zuozhuan()
push_val_left=6;
push_val_right=12;
Left_moto_back ; //左電機后走
void youzhuan()
push_val_left=12;
push_val_right=6;
Right_moto_back ; //右電機往后走
/* PWM調(diào)制電機轉(zhuǎn)速 */
/* 左電機調(diào)速 */
/*調(diào)節(jié)push_val_left的值改變電機轉(zhuǎn)速,占空比 */
void pwm_out_left_moto(void)
if(Left_moto_stop)
if(pwm_val_left<=push_val_left)
Left_moto_pwm=1;
Left_moto_pwm=0;
if(pwm_val_left>=20)
pwm_val_left=0;
Left_moto_pwm=0;
/* 右電機調(diào)速 */
void pwm_out_right_moto(void)
if(Right_moto_stop)
if(pwm_val_right<=push_val_right)
Right_moto_pwm=1;
Right_moto_pwm=0;
if(pwm_val_right>=20)
pwm_val_right=0;
Right_moto_pwm=0;
///*TIMER0中斷服務子函數(shù)產(chǎn)生PWM信號*/
void timer0()interrupt 1 using 2
TH0=0xFc;
TL0=0X18;
time3++;
pwm_val_left++;
pwm_val_right++;
pwm_out_left_moto();
pwm_out_right_moto();
void Timer1Init() //50毫秒@11.0592MHz
// AUXR &= 0xBF; //定時器時鐘12T模式
TMOD &= 0x0F; //設置定時器模式
TMOD |= 0x10; //設置定時器模式
TL1 = 0x00; //設置定時初值
TH1 = 0x4C; //設置定時初值
TF1 = 0; //清除TF1標志
EA=1;
ET1=1;
TR1 = 1; //定時器1開始計時
void Timer1() interrupt 3//晶振頻率是11.0592M
TH1=0X00; //給定時器賦初值,定時50ms
TL1=0x4C;
z++;
void Delay1ms(unsigned int i)
unsigned char j,k;
do{
j = 10;
do{
k = 50;
do{
_nop_();
}while(--k);
}while(--j);
}while(--i);
void delay_nus(unsigned int i) //延時:i>=12 ,i的最小延時單12 us
i=i/10;
while(--i);
void delay_nms(unsigned int n) //延時n ms
n=n+1;
while(--n)
delay_nus(900); //延時 1ms,同時進行補償
void delayms(unsigned char x) //0.14mS延時程序
unsigned char i; //定義臨時變量
while(x--) //延時時間循環(huán)
for (i = 0; i<13; i++) {} //14mS延時
void delay5(unsigned int i) //延時程序
{while(i--);}
void Delay1us ( int T )
while(T!=0)
_nop_();
T--;
void led_delay(void)
unsigned char i,j;
for(i=0;i<220;i++)
for(j=0;j<220;j++);
void wudao(void)
Timer1Init();
if(z>=3){
z=0;
tingzhi();
if(z>=60){
z=0;
qianjin();
if(z>=3){
z=0;
tingzhi();
if(z>=3){
z=0;
youzhuan();
if(z>=3){
z=0;
tingzhi();
if(z>=60){
z=0;
qianjin();
if(z>=3){
z=0;
tingzhi();
if(z>=3){
z=0;
youzhuan();
if(z>=3){
z=0;
tingzhi();
if(z>=60){
z=0;
qianjin();
if(z>=3){
z=0;
tingzhi();
if(z>=3){
z=0;
youzhuan();
if(z>=3){
z=0;
tingzhi();
if(z>=3){
z=0;
qianjin();
tingzhi();
void wudao(void)
Timer1Init();//定時器1初始化
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
qianjin();
TR1=1;
while(z!=60);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
youzhuan();
TR1=1;
while(z!=3);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
qianjin();
TR1=1;
while(z!=6);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
youzhuan();
TR1=1;
while(z!=3);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
qianjin();
TR1=1;
while(z!=60);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
youzhuan();
TR1=1;
while(z!=3);
TR1=0;
z=0;
tingzhi();
TR1=1;
while(z!=3);
TR1=0;
z=0;
qianjin();
TR1=1;
while(z!=60);
TR1=0;
z=0;
tingzhi();
void forward(void)//兩邊
P0=0x7e;
led_delay();
P0=0xbd;
led_delay();
P0=0xdb;
led_delay();
P0=0xe7;
led_delay();
P0=0xe7;
led_delay();
P0=0xdb;
led_delay();
P0=0xbd;
led_delay();
P0=0x7e;
led_delay();
void Alter(void)//交替
P0=0xaa;
led_delay();
P0=0x55;
led_delay();
void backward(void)
P0=0x7f;
led_delay();
P0=0xbf;
led_delay();
P0=0xdf;
led_delay();
P0=0xef;
led_delay();
P0=0xf7;
led_delay();
P0=0xfb;
led_delay();
P0=0xfd;
led_delay();
P0=0xfe;
led_delay();
void blink(void)
P0=0xff;
led_delay();
P0=0x00;
led_delay();
void deng1() //流水燈
{p00=0;
p01=0;
delay5(5000);
p02=0;
p03=0;
delay5(5000);
p04=0;
p05=0;
delay5(5000);
p06=0;
p07=0;
delay5(5000);
p07=1;
p06=1;
delay5(5000);
p05=1;
p04=1;
delay5(5000);
p03=1;
p02=1;
delay5(5000);
p01=1;
p00=1;
delay5(5000);}
void deng2() //流水燈
{p00=0;
p01=1;
delay5(5000);
p02=0;
p03=1;
delay5(5000);
p04=0;
p05=1;
delay5(5000);
p06=0;
p07=1;
delay5(5000);
p07=0;
p06=1;
delay5(5000);
p05=0;
p04=1;
delay5(5000);
p03=0;
p02=1;
delay5(5000);
p01=0;
p00=1;
delay5(5000);}
void deng3() //流水燈
{p00=0;
p01=0;
delay5(5000);
p02=0;
p03=0;
delay5(5000);
p04=0;
p05=0;
delay5(5000);
p06=0;
p07=0;
delay5(5000);
p07=1;
p06=1;
delay5(5000);
p05=1;
p04=1;
delay5(5000);
p03=1;
p02=1;
delay5(5000);
p01=1;
p00=1;
delay5(5000);}
void deng4() //流水燈
{p00=1;
p01=1;
p02=1;
p03=1;
p04=1;
p05=1;
p06=1;
p07=1;
void Robot_Avoidance() //機器人避障子程序
if(LeftIR==1&&RightIR ==1) //LeftIRBZ RightIRBZ
deng1();
qianjin();
delay_nms (10);
// SB1=1;
if(LeftIR==1&&RightIR ==0) //右邊檢測到紅外信號
deng4();
youzhuan(); //右轉(zhuǎn)
delay_nms (300); //停止300MS 防止電機反相電壓沖擊 導致系統(tǒng)復位
deng1();
if(RightIR ==1&&LeftIR==0) //左邊檢測到紅外信號
deng4();
zuozhuan(); //左轉(zhuǎn)
deng1();
if(RightIR==0&&LeftIR==0) //兩邊傳感器同時檢測到紅外
// SB1=0;
deng4();
tingzhi(); //停止
houtui(); //調(diào)用電機后退函數(shù)
delay_nms (300); //后退50毫秒
youzhuan(); //調(diào)用電機右轉(zhuǎn)函數(shù)
delay_nms (400);
deng1();
qianjin();
void ControlCar_yaokong(unsigned char ConType) //定義電機控制子程序 (紅外遙控單獨設置一個 switch case 語句 )
tingzhi();
switch(ConType) //判斷用戶設定電機形式
case 1: //前進 //判斷用戶是否選擇形式1
tingzhi(); //進入前進之前 先停止一段時間 防止電機反向電壓沖擊主板 導致系統(tǒng)復位
Delay1ms(150);
// LeftLed = 0 ;
qianjin();
break;
case 2: //后退 //判斷用戶是否選擇形式2
tingzhi(); //進入后退之前 先停止一段時間 防止電機反向電壓沖擊主板 導致系統(tǒng)復位
Delay1ms(150);
// LeftLed = 1 ;
houtui(); //M2電機反轉(zhuǎn)
break;
case 3: //右轉(zhuǎn) //判斷用戶是否選擇形式3
tingzhi(); //進入左轉(zhuǎn)之前 先停止一段時間 防止電機反向電壓沖擊主板 導致系統(tǒng)復位
Delay1ms(150);
youzhuan();
//M2電機正轉(zhuǎn)
break;
case 4: //左轉(zhuǎn) //判斷用戶是否選擇形式4
tingzhi(); //進入右轉(zhuǎn)之前 先停止一段時間 防止電機反向電壓沖擊主板 導致系統(tǒng)復位
Delay1ms(150);
zuozhuan(); //M1電機正轉(zhuǎn) //M2電機反轉(zhuǎn)
break;
case 5: //停止 //判斷用戶是否選擇形式8
tingzhi();
break; //退出當前選擇
case 6: //左轉(zhuǎn) //判斷用戶是否選擇形式4
Robot_Avoidance();
break;
case 7: //停止 //判斷用戶是否選擇形式8
deng2();
break; //退出當前選擇
case 8: //停止 //判斷用戶是否選擇形式8
deng4();
break; //退出當前選擇
//----------紅外遙控-------------------------------------------------------------
void IR_IN() interrupt 2 using 0 //定義INT2外部中斷函數(shù)
unsigned char j,k,N=0; //定義臨時接收變量
EX1 = 0; //關閉外部中斷,防止再有信號到達
delayms(15); //延時時間,進行紅外消抖
if (IRIN==1) //判斷紅外信號是否消失
EX1 =1; //外部中斷開
return; //返回
while (!IRIN) //等IR變?yōu)楦唠娖剑^9ms的前導低電平信號。
delayms(1); //延時等待
for (j=0;j<4;j++) //采集紅外遙控器數(shù)據(jù)
for (k=0;k<8;k++) //分次采集8位數(shù)據(jù)
while (IRIN) //等 IR 變?yōu)榈碗娖剑^4.5ms的前導高電平信號。
delayms(1); //延時等待
while (!IRIN) //等 IR 變?yōu)楦唠娖?br />
delayms(1); //延時等待
while (IRIN) //計算IR高電平時長
delayms(1); //延時等待
N++; //計數(shù)器加加
if (N>=30) //判斷計數(shù)器累加值
EX1=1; //打開外部中斷功能
return; //返回
IRCOM[j]=IRCOM[j] >> 1; //進行數(shù)據(jù)位移操作并自動補零
if (N>=8) //判斷數(shù)據(jù)長度
IRCOM[j] = IRCOM[j] | 0x80; //數(shù)據(jù)最高位補1
N=0; //清零位數(shù)計錄器
if (IRCOM[2]!=~IRCOM[3]) //判斷地址碼是否相同
EX1=1; //打開外部中斷
return; //返回
for(j=0;j<10;j++) //循環(huán)進行鍵碼解析
if(IRCOM[2]==RecvData[j]) //進行鍵位對應
// ControlCar(j);
ControlCar_yaokong(j); //數(shù)碼管顯示相應數(shù)碼
EX1 = 1; //外部中斷開
void SendData ( unsigned char addr )
unsigned char i;
// EA = 0;/*發(fā)送時關掉中斷,防止中斷影響時序 */
sda = 1;/*開始拉搞 */
Delay1us ( 1000 );
sda = 0;/*開始引導碼*/
Delay1us ( 3000 );/*此處延時最少要大于2ms,此參數(shù)延時為310ms */
for ( i = 0; i < 8; i++ ) /*總共8位數(shù)據(jù) */
sda = 1;
if ( addr & 0x01 ) /*3:1表示數(shù)據(jù)位1,每個位用兩個脈沖表示 */
Delay1us ( 500 );
sda = 0;
Delay1us ( 210 );
else /*1:3表示數(shù)據(jù)位0 ,每個位用兩個脈沖表示 */
Delay1us ( 210 );
sda = 0;
Delay1us ( 500 );
addr >>= 1;
sda = 1;
// EA = 1;
void Stop_Music()
SendData(0x0a);
SendData(0x13);
void Star_Music()
SendData(0x0a);
SendData(0x03);
SendData(0x0b);
wudao();
void main() //主程序入口
// bit RunFlag=0; //定義小車運行標志位
// LedFlash=3000; //對閃燈數(shù)據(jù)進行初始化
EX1=1; //同意開啟外部中斷1
IT1=1; //設定外部中斷1為低邊緣觸發(fā)類型
EA=1; //總中斷開啟
// ET1=1;
tingzhi();
//初始化小車運行狀態(tài)
while(1) //程序主循環(huán)
if(key == 0)
delay_nms(10);
if(key == 0)
temp++;
while(!key);
if(temp > 4)
temp = 1;
switch(temp)
case 1:tingzhi();
//forward();
Stop_Music();
break;
case 2:
Robot_Avoidance();EX1 = 0;break;
case 3:
EX1 = 1;break;
case 4:
Star_Music();
break;
