查看: 1719|回復: 0
單片機矩陣按鍵串口通訊
ID:622100 發表于 2020-5-4 14:28 | 顯示全部樓層 |閱讀模式
矩陣_串口通信.rar (24.5 KB, 下載次數: 7)
#include "STC89C5xRC.h"
typedef  unsigned int  u16;
typedef  unsigned int u8  ;
unsigned char   led_m ;
extern void key_16(void);
void UsartInit()
  SCON=0x50;
  TMOD=0x20;
  PCON=0x80;
  TH1=0xF3;
  TL1=0xF3;
  ES=1;
  EA=1;
  TR1=1;
void delay_s(unsigned int t)
   while(t--)
         UsartInit();
  key_16();
   switch(led_m)
         case'0':{P27=1;}break;
        case'1':{P27=0;}break;
    case'S':{P27=!P27;
                         delay_s(5000);
                                                }break;
        case'B':{P27=!P27;
                         delay_s(5000);
                                                }break;
////        case'Y':  delay_s (50); {go();}                break;
////        case'X':  delay_s (50); {hou();}            break;
void Usart() interrupt        4
  if(RI);
  led_m=SBUF;
  RI=0;
  SBUF=led_m;
if(TI)
TI=0;
//// void chuan() interrupt 4        //串口服務函數
////        RI=0;                //軟件清零
////        led_m=SBUF;                //讀取SBUF數據
