查看: 8404|回復: 8
單片機lcd1602只顯示第一排黑色方塊
回帖獎勵 20 黑幣 回復本帖可獲得 20 黑幣獎勵! 每人限 1 次
麻煩大佬幫忙看一下是什么問題
#include "LCD1602.h"
#ifdef P25_DRIV_RW
//讀操作,RS=1讀數據;RS=0讀指令
unsigned char Read_LCD1602(bit RS)
unsigned char temp;
LCD1602_RS = RS;//數據寄存器
LCD1602_RW = 1;//讀操作
LCD1602_EN = 1;//上升沿,LCD準備數據
_nop_();
_nop_();
_nop_();
_nop_();
temp =  LCD1602_DATA;//讀取DB7~0
LCD1602_EN = 0;//下降沿,LCD鎖存數據
return temp;
//讀忙操作,高電平表示忙
bit LCD_Busy(void)
   unsigned char temp;
   temp = Read_LCD1602(COMMAND);//讀指令
   return (bit)(temp & 0x80);//返回BF(bit7)位
//寫操作,RS=1寫數據;RS=0寫指令
void Write_LCD1602(unsigned char dat,bit RS)
while(LCD_Busy());
  LCD1602_EN = 0; //使能清零
LCD1602_RS = 1; //選擇輸入數據
LCD1602_RW = 0; //選擇寫入
LCD1602_DATA = dat; //寫入數據
Delay_ms(1);
LCD1602_EN= 1;   //寫入時序
Delay_ms(5);   //保持時間
LCD1602_EN= 0;
#else
LCD1602_RS = 1;   //選擇寫入數據
LCD1602_DATA= dat; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
  Delay_ms(1);
  Delay_ms(5);;
LCD1602_EN = 0;
LCD1602_DATA = dat << 4; //寫入低四位
  Delay_ms(1);
LCD1602_EN = 1;   //寫入時序
  Delay_ms(5);
LCD1602_EN=0;
#endif
void LCD_WrCmd(unsigned char dat)
Write_LCD1602(dat,COMMAND);
void LCD_WrDat(unsigned char dat)
Write_LCD1602(dat,DATA);
void St_LCD1602_Pos(unsigned char pos)
LCD_WrCmd(pos | 0x80);
void LCD1602_Init(void)
unsigned char empty = ' ';
LCD1602_EN = 0;
LCD_WrCmd(0x38);
LCD_WrCmd(0x0c);
LCD_WrCmd(0x06);
LCD_WrCmd(0x01);
  LCD_WrCmd(0x80);
Wr_LCD1602_Num(0x00,0);
Wr_LCD1602_Str(0x00,"t");
Wr_LCD1602_Byt(0x00,'t');
St_LCD1602_Cur(0);
St_LCD1602_Clr();
void Wr_LCD1602_Str(unsigned char pos,unsigned char *Pwdata)
St_LCD1602_Pos(pos);
while(*Pwdata != '\0')
  LCD_WrDat(*Pwdata++);
void Wr_LCD1602_Byt(unsigned char pos,unsigned char _data)
LCD_WrDat(_data);
void Wr_LCD1602_Num(unsigned char pos,unsigned char _data)
if((0<=_data)&&(_data<=9))
  LCD_WrDat((_data+'0'));
  LCD_WrDat('E');
void St_LCD1602_Clr(void)
    LCD_WrCmd(0x01);//清顯示
void St_LCD1602_Cur(bit OpnClose)
if(OpnClose)
  LCD_WrCmd(0x0f);
  LCD_WrCmd(0x0c);
ID:452950 發表于 2020-5-1 09:51 | 只看該作者
先考慮線有沒有接錯,對比度調好沒有
ID:97554 發表于 2020-5-1 10:58 | 只看該作者
RS   RW   EN三根線有沒有對應程序,D0 -  D7線序有沒有接反。
ID:709389 發表于 2020-5-1 11:26 | 只看該作者
調節電位器,對比度要調好
ID:531275 發表于 2020-5-1 14:47 | 只看該作者
xxpp2011 發表于 2020-5-1 09:51
先考慮線有沒有接錯,對比度調好沒有
這些都沒問題,燒例程可以顯示
ID:531275 發表于 2020-5-1 14:49 | 只看該作者
楊雪飛 發表于 2020-5-1 10:58
#define LCD1602_DATA P0
sbit LCD1602_EN = P2^7;
sbit LCD1602_RS        = P2^6;
#ifdef P25_DRIV_RW
sbit LCD1602_RW = P2^5;
#endif
ID:97554 發表于 2020-5-1 15:29 | 只看該作者
dislsqq 發表于 2020-5-1 14:49
燒例程可以的話你就把這個程序對照例程的初始化、寫命令、寫數據函數,看看哪里時序不對吧。開發板這玩意難伺候,所以我就覺得初學者用開發板學是個坑。比如我們驅動1602,我用P0口不解上拉電阻都可以直接驅動1602正常顯示。但是在開發板上就不行。我有塊普中開發板,用的1602就跟一般的不一樣,之前因為這個繞了不少彎路。
對于1602的顯示按以下幾塊分解了學就好了。
void main()   主函數
lcd init();   先初始化液晶
while()      循環
delay();
wrt_com();    寫命令函數,定義位置
delay();
wrt_dat()   ;  寫數據函數,顯示內容。
lcd_init()    初始化子程序
內容
wrt_com()    寫命令子程序
內容
wrt_dat()   寫數據子程序
內容
delay()    延時子程序
內容
admin + 50 回帖助人的獎勵!
ID:531275 發表于 2020-5-2 10:21 來自觸屏版 | 只看該作者
楊雪飛 發表于 2020-5-1 15:29
燒例程可以的話你就把這個程序對照例程的初始化、寫命令、寫數據函數,看看哪里時序不對吧。開發板這玩意 ...
好的,謝謝
ID:691449 發表于 2020-5-2 13:01 | 只看該作者
濫情 發表于 2020-5-1 11:26
調節電位器,對比度要調好
只有一行黑色不是對比度的問題,應該和初始化有關系
