一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示) 圖1
二,調(diào)整虛擬器件,另存工程文件。(如下圖2,3,4所示) 圖2 圖3
圖4
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖5所示) 圖5
四,編輯main.c,timer.c,timer.h, key.c,key.h, led.c,led.h 代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖6所示) 圖6
五,Main.c 代碼: /* Main.c file generated by New Project wizard * Author: Ziegler Yin * Created: 周四 一月 16 2020 * Processor: STM32F407ZGT6ZGT6 * Compiler: GCC for ARM */
#include "mfuncs.h" #include "delay.h" #include "usart.h" #include "led.h" #include "key.h" #include "timer.h"
#define RT(A , B) (A> 300)? (B= 0): (B=1)
uint32_t gt_fig(u8 sts){ if(1== sts) return TIM_GetCapture1(TIM4); if(2== sts) return TIM_GetCapture2(TIM4); if(3== sts) return TIM_GetCapture3(TIM4); if(4== sts) return TIM_GetCapture4(TIM4); }
void st_fig(u8 sts, uint32_t gt){ if(1== sts) TIM_SetCompare1(TIM4, gt); if(2== sts) TIM_SetCompare2(TIM4, gt); if(3== sts) TIM_SetCompare3(TIM4, gt); if(4== sts) TIM_SetCompare4(TIM4, gt); }
void new_Pwm(u16 *tmbuf, u16 * mdc) { Pwm_Init(*(tmbuf+0), *(tmbuf+1)); TIM_SetCompare1(TIM4, mdc[0]); TIM_SetCompare2(TIM4, mdc[1]); TIM_SetCompare3(TIM4, mdc[2]);
Pwm_Init3(*(tmbuf+2), *(tmbuf+3)); TIM_SetCompare2(TIM3, mdc[1]); }
int main(void) { u16 psc=840, per=600, idc[4]= {500, 200, 300, 400}; u16 umd, pwmval=0, tm43[2][2]= {840, 600, 1680, 1200}; u8 status= 0, dir= 1, chgFry[1]= {0, 0}; int gtln= 0; char *wd, *wds, *lnslt[7]={"未選", "A線路", "B線路", "C線路", "D線路", "變頻1-A,B,C倍頻或初始狀態(tài)", "變頻2-D四倍頻或初始狀態(tài)"}; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2 delay_init(168); //初始化延時(shí)函數(shù) uart_init(9600);//初始化串口波特率為115200 LED_Init(); KEY_Init(); uprint("大家好!!!\r\n"); uprint("大家來造呼吸機(jī)-----。\r\n"); gtln= nmtoa(wd, 10, psc); uprint(wd); uprint("\r\n"); gtln= nmtoa(wd, 10, (psc+10000)); uprint(wd); uprint("\r\n");
LED0= LED1= LED2= 1;
chgFry[0]= 0; chgFry[1]= 4; new_Pwm(tm43, idc);
uprint("控制芯片STM32F407ZGT6_008_PWM仿真開始了。\r\n"); delay_ms(100);
while(1) { wd= lnslt[status]; ; uprint("Arm運(yùn)行時(shí)......占空比:\r\n"); uprint(wd); uprint("線路可調(diào)整狀態(tài):\r\n"); if(1==ReadKey(GPIOC, 0x0080)) { status++; delay_ms(20); if(status> 6) status= 0; wd= lnslt[status]; ; uprint("線路調(diào)整狀態(tài)......占空比"); uprint(wd); uprint("線路可調(diào)整狀態(tài):\r\n"); } if(1==ReadKey(GPIOC, 0x0010)) { LED0= 1; pwmval= gt_fig(status); gtln= nmtoa(wds, 10, pwmval); if(status>0){ if(per< (pwmval+ 50)) { uprint("線路調(diào)整, 占空值到達(dá)最高值 ......\r\n"); st_fig(status, (per+ 1)); } else{ LED0= 1; pwmval= gt_fig(status); gtln= nmtoa(wds, 10, pwmval); umd= pwmval +50; uprint("線路調(diào)整, 占空值由 "); uprint(wds); uprint(" 增加50 至"); uprint(numtoa(10, umd)); uprint(" ...\r\n "); st_fig(status, umd); } } } if(1==ReadKey(GPIOC, 0x0020)) { LED1= 1; if(status==5) { if(chgFry[0]==0) { chgFry[0]= 2; tm43[0][0]= 1680; new_Pwm(tm43, idc); uprint("線路A,B,C頻率調(diào)整到倍頻...\r\n"); delay_ms(200); } else{ chgFry[0]= 0; tm43[0][0]= 840; new_Pwm(tm43, idc); uprint("線路A,B,C頻率調(diào)整到初始狀態(tài)...\r\n"); delay_ms(200); } } if(status==6) { if(chgFry[1]==0) { chgFry[1]= 4; tm43[1][0]= 1680; tm43[1][1]= 1200; new_Pwm(tm43, idc); uprint("線路D頻率調(diào)整到四倍頻...\r\n"); delay_ms(200); } else{ chgFry[1]= 0; tm43[1][0]= 840; tm43[1][1]= 600; new_Pwm(tm43, idc); uprint("線路D頻率調(diào)整到初始狀態(tài)...\r\n"); delay_ms(200); } } delay_ms(20); pwmval= gt_fig(status); gtln= nmtoa(wds, 10, pwmval); uprint("Arm運(yùn)行時(shí)......占空比"); uprint(wd); uprint("線路調(diào)整, 由 "); uprint(wds); uprint(" 清零 "); uprint(" ...\r\n "); st_fig(status, 0); } if(1==ReadKey(GPIOC, 0x0040)) { LED2= 1; pwmval= gt_fig(status); gtln= nmtoa(wds, 10, pwmval); if(pwmval> 50) { umd= pwmval -50; uprint("線路調(diào)整, 占空值由 "); uprint(wds); uprint(" 減少50 至 "); uprint(numtoa(10, umd)); uprint(" ...\r\n "); st_fig(status, umd); } else { umd= 1; uprint("線路調(diào)整, 占空值到達(dá)最低值 ......\r\n"); st_fig(status, 1); } } LED0= LED1= LED2= 0; delay_ms(100); } }
key.c,key.h, led.c led.h,time.c,time.h之前的代碼都可借鑒,不在多列,以后不再一一羅列,只列main.c 與相關(guān)功能的.c, .h代碼。 六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖7所示) 圖7
七,點(diǎn)擊窗口左下方仿真按鈕,可見紅,黃,綠燈點(diǎn)亮后一會滅,仿真開始,按下SELECT按鈕,選擇"變頻1-A,B,C倍頻或初始狀態(tài)", "變頻2-D四倍頻或初始狀態(tài)",按下按下KEY_ZERO按鈕,倍頻, 四倍頻或初始狀態(tài)。占空比的調(diào)試,參見:博主的Proteus8.9 仿真STM32407ZGT6系列009_PWM多路可調(diào)占空比輸出文。虛擬串口,示波器將的狀態(tài)變化顯示在屏。 (如下圖8,9,10,11所示) 圖8 圖9 圖10 圖11 八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖12所示) 圖12
九, 系列的001-003虛擬仿真與開發(fā)板對應(yīng)已證明:虛擬仿真程序?qū)τ陂_發(fā)板有效,之后不再➕上下載到開發(fā)板的介紹。 附件Proteus8.9 仿真STM32407ZGT6系列010_PWM多路可變頻率可調(diào)占空比輸出在已安裝Proteus8.9的計(jì)算機(jī)文件夾中打開即可 需要進(jìn)一步了解,請加入QQ群:976235464 |
