查看: 2236|回復: 0
單片機+ADC0809模數轉換與顯示
程序:
/***************   writer:shopping.w   ******************/
#include <reg52.h>
uchar code LEDData[]=
     0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
sbit OE  = P1^0;
sbit EOC = P1^1;
sbit ST  = P1^2;
sbit CLK = P1^3;
void DelayMS(uint ms)
     uchar i;
    while(ms--)
         for(i=0;i<120;i++);
void Display_Result(uchar d)
     P2 = 0xf7;
    P0 = LEDData[d%10];
    DelayMS(5);
    P2 = 0xfb;
    P0 = LEDData[d%100/10];
    DelayMS(5);
    P2 = 0xfd;
    P0 = LEDData[d/100];
    DelayMS(5);
     TMOD = 0x02;
    TH0  = 0x14;
    TL0  = 0x00;
    IE   = 0x82;
    TR0  = 1;
    P1   = 0x3f;
         ST = 0;
        ST = 1;
        ST = 0;
        while(EOC == 0);
        OE = 1;
        Display_Result(P3);
        OE = 0;
void Timer0_INT() interrupt 1
     CLK = !CLK;
ADC0809模數轉換與顯示.zip
62.1 KB, 下載次數: 20, 下載積分: 黑幣 -5
