查看: 2266|回復(fù): 1
兩個(gè)單片機(jī)程序合在一起,警告聲明的函數(shù)未使用,整個(gè)點(diǎn)陣的函數(shù)都無效,不懂編程...
15黑幣
#include<reg52.h>
#include<intrins.h>
//intrins.h函數(shù),一般出現(xiàn)在C51單片機(jī)編程中,一般程序中需要使用到空指令_nop_();字符循環(huán)移位指令_crol_等時(shí)使用
//OE        第13腳        輸出有效(低電平)
//MR        第10腳        主復(fù)位(低電平)
sbit BEEP=P2^0;        //定義喇叭輸出端口
sbit SER = P3^4;    //p3.4串行數(shù)據(jù)輸入   DS
sbit SCK = P3^6;    //串行輸入時(shí)鐘,上升沿有效    SHCP        第11腳        數(shù)據(jù)輸入時(shí)鐘線
sbit RCK = P3^5;    //串行寄存器時(shí)鐘,上升沿有效  STCP        第12腳        輸出存儲(chǔ)器鎖存時(shí)鐘線
uchar tick,tl,th;          //定義節(jié)拍和T0初值變量
uchar TABLE[]={        //音符節(jié)拍表
    0x82,0x01,0x81,0x94,0x84,0xB4,0xA4,0x04,
        0x82,0x01,0x81,0x94,0x84,0xC4,0xB4,0x04,
        0x82,0x01,0x81,0xF4,0xD4,0xB4,0xA4,0x94,
        0xE2,0x01,0xE1,0xD4,0xB4,0xC4,0xB4,0x04,
        0x00};
uchar code TABLE1[]={  //定時(shí)器初值表
0xfb,0x04,0xfb,0x90,0xfc,0x09,0xfc,0x44,
0xfc,0xac,0xfd,0x09,0xfd,0x34,0xfd,0x82,
0xfd,0xc8,0xfe,0x06,0xfe,0x22,0xfe,0x56,
0xfe,0x85,0xfe,0x9a,0xfe,0xc1};
   //T0中斷服務(wù)函數(shù)
timer0()interrupt 1 using 1{
TL0=tl;TH0=th;
BEEP=~BEEP;
void SendTo595(uchar Data);
char shu=0xFE;
char a[32]={0x3e,0x08,0x08,0x08,0x08,0x08,0x08,0x3e,
   0x00,0x66,0x99,0x81,0x42,0x24,0x18,0x00,
   0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x7e,
   0x00,0x3e,0x08,0x08,0x08,0x08,0x08,0x08} ;//列
void delay2(unsigned int n)//延時(shí)函數(shù)
unsigned int x=0,y=0;
   for(x=0;x<n;x++)
   for(y=0;y<123;y++);
void Hang()//行掃描
P1=shu;
shu=_crol_(shu,1);
//基本單位延時(shí)函數(shù)
void delay1(){
uint i;
for(i=0;i<20000;i++);
//節(jié)拍延時(shí)函數(shù)
void delay(tt){
uchar i;
for(i=0;i<=tt;i++)delay1();
//主函數(shù)
void main(){
int x=0,changeRow=0;
uchar t,t1,k=0;
while(1){
TMOD=0x01;IE=0x82;
while(TABLE[k]!=0){
tick=(TABLE[k])&0x0f;
t=(_crol_(TABLE[k],4))&0x0f;
if(t!=0){
t1=--t*2+1;
t=t*2;
tl=TL0=TABLE1[t1];
th=TH0=TABLE1[t];
TR0=1;
else TR0=0;
delay(tick);
k++;
TR0=0;
           while(1){
        int speed=12;          //控制速度
        while(speed--)
              {for(x=0;x<8;x++)
        {Hang();
        SendTo595(a[x+changeRow]);        //串行,控制列.
        delay2(4);} }
   changeRow++;        //原來的第二行,變成第一行了.
   if (changeRow>=24)
   changeRow=0;        //循環(huán)開始.
void SendTo595(uchar Data){
int x;
for(x=0;x<8;x++){
SCK=0;
SER = 0x80&Data;
Data = _crol_(Data,1);
SCK=1;
nop_();//等待一個(gè)機(jī)器指令時(shí)間.
   /*位移寄存器完畢,轉(zhuǎn)移到存儲(chǔ)寄存器*/
RCK = 1;         //上升沿,存儲(chǔ)寄存器變?yōu)楦唠娖?延遲兩個(gè)時(shí)鐘周期
  _nop_();
  _nop_();
RCK = 0;        //不加出錯(cuò),因?yàn)殡娖讲蛔兓鎯?chǔ)寄存器的內(nèi)容不變,為第一次輸入的移位寄存器內(nèi)容0x00.
喇叭在P2.0 使用這個(gè)程序喇叭沒有問題
ID:731982 發(fā)表于 2020-4-25 19:30 | 只看該作者
main里面有問題,不知道怎么改
