查看: 1623|回復: 0
基于51單片機的藍牙小車
ID:723182 發表于 2020-4-22 19:29 | 顯示全部樓層 |閱讀模式
目前藍牙小車還在調試
#include <STC89C5xRC.H>
#define Left_moto2_pwm     P0_4
#define Right_moto2_pwm    P0_5
#define Left_moto_pwm     P1_4
#define Right_moto_pwm    P1_5
sbit P0_4=P0^4;
sbit P0_5=P0^5;
sbit P1_4=P1^4;
sbit P1_5=P1^5;
sbit IN1 = P1^2;
sbit IN2 = P1^3;
sbit IN3 = P1^6;
sbit IN4 = P1^7;
sbit IN5 = P0^2;
sbit IN6 = P0^3;
sbit IN7 = P0^6;
sbit IN8 = P0^7;
bit Right_moto_stop=1;
bit Left_moto_stop =1;
unsigned  int  time=0;
int pwm=1;
#define left_motor_en        EN1 = 1
#define left_motor_stops        EN1 = 0
#define right_motor_en        EN2 = 1
#define right_motor_stops        EN2 = 0
#define left_motor2_en        EN3 = 1
#define left_motor2_stops        EN3 = 0
#define right_motor2_en        EN4 = 1
#define right_motor2_stops        EN4 = 0
#define left_motor_go        IN1 = 0, IN2 = 1
#define left_motor_back        IN1 = 1, IN2 = 0
#define right_motor_go        IN3 = 1, IN4 = 0
#define right_motor_back        IN3 = 0, IN4 = 1
#define left_motor2_go        IN5 = 0, IN6 = 1
#define left_motor2_back        IN5 = 1, IN6 = 0
#define right_motor2_go        IN7 = 1, IN8 = 0
#define right_motor2_back        IN7 = 0, IN8 = 1
unsigned char pwm_val_left  =0;
unsigned char push_val_left =0;
unsigned char pwm_val_right =0;
unsigned char push_val_right=0;
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
        for(y = 114; y > 0 ; y--);
void UART_INIT()
        SM0 = 0;
        SM1 = 1;
        REN = 1;
        EA = 1;
        ES = 1;
        TMOD = 0x20;
        TH1 = 0xfd;
        TL1 = 0xfd;
        TR1 = 1;
     void  run(void)
     push_val_left  =pwm;
         push_val_right =pwm;
         if(pwm==10) pwm=0;
         if(pwm==0&&pwm<0) pwm=0;
                void pwm_out_left_moto(void)
   if(Left_moto_stop)
    if(pwm_val_left<=push_val_left)
             {  Left_moto_pwm=1;
                    Left_moto2_pwm=1;  }
              { Left_moto_pwm=0;Left_moto2_pwm=0;                 }
        if(pwm_val_left>=10)
        pwm_val_left=0;
   else { Left_moto_pwm=0;Left_moto2_pwm=0;          }
   void pwm_out_right_moto(void)
  if(Right_moto_stop)
    if(pwm_val_right<=push_val_right)
             {  Right_moto_pwm=1;
                   Right_moto2_pwm=1;           }
               {Right_moto_pwm=0;
                    Right_moto2_pwm=0;}
        if(pwm_val_right>=10)
            pwm_val_right=0;
   else    {Right_moto_pwm=0;Right_moto2_pwm=0;        }
        void timer0()interrupt 1   using 2
     TH0=0XF8;
         TL0=0X30;
         time++;
         pwm_val_left++;
         pwm_val_right++;
         pwm_out_left_moto();
         pwm_out_right_moto();
void forward()
        ET0 = 1;
        run();
        left_motor_go;
        right_motor_go;
        left_motor2_go;
        right_motor2_go;
void left_go()
        ET0 = 1;
        run();
        left_motor_back;
        right_motor_go;
        left_motor2_back;
        right_motor2_go;
        delay(700);
        forward();
void right_go()
        ET0 = 1;
        run();
        delay(50);
        right_motor_back;
        left_motor_go;
        right_motor2_back;
        left_motor2_go;
        delay(700);
        forward();
void left()
        ET0 = 1;
        run();
        delay(50);
        right_motor_go;
        left_motor_back;
        right_motor2_go;
        left_motor2_back;
void right()
        ET0 = 1;
        run();
        left_motor_go;
        right_motor_back;
        left_motor2_go;
        right_motor2_back;
void back()
        ET0 = 1;
        run();
        left_motor_back;
        right_motor_back;
        left_motor2_back;
        right_motor2_back;
void stop()
        ET0 = 0;
        P1=0;
        P0=0;
void UART_SER() interrupt 4
        if(RI)
                RI = 0;
                switch(SBUF)
                        case 'g': forward(); break;
                        case 'b': back(); break;
                        case 'l': left(); break;
                        case 'r': right(); break;
                        case 's': stop(); break;
                        case 'z': left_go(); break;
                         case 'y': right_go(); break;
                        case 'p': pwm++;break;
                        case 'c': pwm--;break;
        TMOD=0X01;
        TH0= 0XF8;
        TL0= 0X30;
        TR0= 1;
        ET0= 1;
        EA = 1;
        UART_INIT();
        while(1);
