2黑幣
顯示出來是這樣的
這是主函數(shù):
- #include <reg52.h>
- #include "LCD1602.h"
- #include "stdio.h"
- unsigned char str1[2],str2[2];
- bit flag1s = 0; //1s定時(shí)標(biāo)志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- void ConfigTimer0(unsigned int ms);
- extern void UartDriver();
- extern void ConfigUART(unsigned int baud);
- extern void UartRxMonitor(unsigned char ms);
- extern void UartWrite(unsigned char *buf, unsigned char len);
- extern unsigned char RH_data,TH_data;
- void main ()
- EA = 1; //開總中斷
- ConfigTimer0(1); //配置T0定時(shí)1ms
- ConfigUART(9600); //配置波特率為9600
- InitLcd1602(); //初始化液晶
- DHT11_start();
- LcdShowStr(0,0,"Humi:");
- LcdShowStr(0,1,"Temp:");
- while (1)
- UartDriver(); //調(diào)用串口驅(qū)動(dòng)
- if(flag1s)
- flag1s=0;
- DHT11_receive();
- str1[0]=(char)(0x30+RH_data/10); //濕度整數(shù)部分
- str1[1]=(char)(0x30+RH_data%10);
- str2[0]=(char)(0x30+TH_data/10); //溫度整數(shù)部分
- str2[1]=(char)(0x30+TH_data%10);
- LCD_Write_Char(6,0,str1[0]);
- LCD_Write_Char(7,0,str1[1]);
- LcdShowStr(9,0,"%");
- LCD_Write_Char(6,1,str1[0]);
- LCD_Write_Char(7,1,str1[1]);
- LcdShowStr(9,1,"C");
- /* 串口動(dòng)作函數(shù),根據(jù)接收到的命令幀執(zhí)行響應(yīng)的動(dòng)作
- buf-接收到的命令幀指針,len-命令幀長度 */
- void UartAction(unsigned char *buf, unsigned char len)
- // buf[len++] = '\r'; //有效命令被執(zhí)行后,在原命令幀之后添加
- // buf[len++] = '\n'; //回車換行符后返回給上位機(jī),表示已執(zhí)行
- // UartWrite(buf, len);
- //UartWrite(buf, len);
- /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
- unsigned long tmp; //臨時(shí)變量
- tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
- tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
- tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
- tmp = tmp + 32; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動(dòng)T0
- /* T0中斷服務(wù)函數(shù),執(zhí)行串口接收監(jiān)控和蜂鳴器驅(qū)動(dòng) */
- void InterruptTimer0() interrupt 1
- static unsigned char tmr1s = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- UartRxMonitor(1); //串口接收監(jiān)控
- tmr1s++;
- if (tmr1s >= 100) //定時(shí)1s
- tmr1s = 0;
- flag1s = 1;
- 這是DHT11程序:
- #include "DHT11.h"
- //sbit Temp_data=P2^1;
- unsigned char RH_data,TH_data;
- unsigned int rec_dat[4];
- //DHT11起始信號(hào)
- void DHT11_delay_us(unsigned char n)
- while(--n);
- //延時(shí)ms
- void DHT11_delay_ms(unsigned int z)
- unsigned int i,j;
- for(i=z;i>0;i--)
- for(j=110;j>0;j--);
- void DHT11_start()
- Temp_data=1;
- DHT11_delay_us(2);
- Temp_data=0;
- DHT11_delay_ms(20);
- Temp_data=1;
- DHT11_delay_us(13);
- //接收一個(gè)字節(jié)
- unsigned char DHT11_rec_byte()
- unsigned char i,dat;
- for(i=0;i<8;i++)
- while(!Temp_data);
- DHT11_delay_us(8);
- dat<<=1;
- if(Temp_data==1)
- dat+=1;
- while(Temp_data);
- return dat;
- //接收溫濕度數(shù)據(jù)
- void DHT11_receive()
- unsigned int R_H,R_L,T_H,T_L;
- unsigned char RH,RL,TH,TL,revise;
- DHT11_start();
- Temp_data=1;
- if(Temp_data==0)
- while(Temp_data==0); //等待拉高
- DHT11_delay_us(40); //拉高后延時(shí)80us
- R_H=DHT11_rec_byte(); //接收濕度高八位
- R_L=DHT11_rec_byte(); //接收濕度低八位
- T_H=DHT11_rec_byte(); //接收溫度高八位
- T_L=DHT11_rec_byte(); //接收溫度低八位
- revise=DHT11_rec_byte(); //接收校正位
- DHT11_delay_us(25); //結(jié)束
- if((R_H+R_L+T_H+T_L)==revise) //校正
- RH=R_H;
- RL=R_L;
- TH=T_H;
- TL=T_L;
- /*數(shù)據(jù)處理,方便顯示*/
- /* rec_dat[0]=RH;
- rec_dat[1]=RL;
- rec_dat[2]=TH;
- rec_dat[3]=TL;*/
- RH_data=RH;
- TH_data=TH;
- 這是Uart.c程序:
- bit flagFrame = 0; //幀接收完成標(biāo)志,即接收到一幀新數(shù)據(jù)
- bit flagTxd = 0; //單字節(jié)發(fā)送完成標(biāo)志,用來替代TXD中斷標(biāo)志位
- unsigned char cntRxd = 0; //接收字節(jié)計(jì)數(shù)器
- unsigned char pdata bufRxd[64]; //接收字節(jié)緩沖區(qū)
- extern void UartAction(unsigned char *buf, unsigned char len);
- /* 串口配置函數(shù),baud-通信波特率 */
- void ConfigUART(unsigned int baud)
- SCON = 0x50; //配置串口為模式1
- TMOD &= 0x0F; //清零T1的控制位
- TMOD |= 0x20; //配置T1為模式2
- TH1 = 256 - (11059200/12/32)/baud; //計(jì)算T1重載值
- TL1 = TH1; //初值等于重載值
- ET1 = 0; //禁止T1中斷
- ES = 1; //使能串口中斷
- TR1 = 1; //啟動(dòng)T1
- /* 串口數(shù)據(jù)寫入,即串口發(fā)送函數(shù),buf-待發(fā)送數(shù)據(jù)的指針,len-指定的發(fā)送長度 */
- void UartWrite(unsigned char *buf, unsigned char len)
- while (len--) //循環(huán)發(fā)送所有字節(jié)
- flagTxd = 0; //清零發(fā)送標(biāo)志
- SBUF = *buf++; //發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- while (!flagTxd); //等待該字節(jié)發(fā)送完成
- /* 串口數(shù)據(jù)讀取函數(shù),buf-接收指針,len-指定的讀取長度,返回值-實(shí)際讀到的長度 */
- unsigned char UartRead(unsigned char *buf, unsigned char len)
- unsigned char i;
- if (len > cntRxd) //指定讀取長度大于實(shí)際接收到的數(shù)據(jù)長度時(shí),
- { //讀取長度設(shè)置為實(shí)際接收到的數(shù)據(jù)長度
- len = cntRxd;
- for (i=0; i<len; i++) //拷貝接收到的數(shù)據(jù)到接收指針上
- *buf++ = bufRxd[i];
- cntRxd = 0; //接收計(jì)數(shù)器清零
- return len; //返回實(shí)際讀取長度
- /* 串口接收監(jiān)控,由空閑時(shí)間判定幀結(jié)束,需在定時(shí)中斷中調(diào)用,ms-定時(shí)間隔 */
- void UartRxMonitor(unsigned char ms)
- static unsigned char cntbkp = 0;
- static unsigned char idletmr = 0;
- if (cntRxd > 0) //接收計(jì)數(shù)器大于零時(shí),監(jiān)控總線空閑時(shí)間
- if (cntbkp != cntRxd) //接收計(jì)數(shù)器改變,即剛接收到數(shù)據(jù)時(shí),清零空閑計(jì)時(shí)
- cntbkp = cntRxd;
- idletmr = 0;
- else //接收計(jì)數(shù)器未改變,即總線空閑時(shí),累積空閑時(shí)間
- if (idletmr < 30) //空閑計(jì)時(shí)小于30ms時(shí),持續(xù)累加
- idletmr += ms;
- if (idletmr >= 30) //空閑時(shí)間達(dá)到30ms時(shí),即判定為一幀接收完畢
- flagFrame = 1; //設(shè)置幀接收完成標(biāo)志
- else
- cntbkp = 0;
- /* 串口驅(qū)動(dòng)函數(shù),監(jiān)測(cè)數(shù)據(jù)幀的接收,調(diào)度功能函數(shù),需在主循環(huán)中調(diào)用 */
- void UartDriver()
- unsigned char len;
- unsigned char pdata buf[40];
- if (flagFrame) //有命令到達(dá)時(shí),讀取處理該命令
- flagFrame = 0;
- len = UartRead(buf, sizeof(buf)); //將接收到的命令讀取到緩沖區(qū)中
- UartAction(buf, len); //傳遞數(shù)據(jù)幀,調(diào)用動(dòng)作執(zhí)行函數(shù)
- /* 串口中斷服務(wù)函數(shù) */
- void InterruptUART() interrupt 4
- if (RI) //接收到新字節(jié)
- RI = 0; //清零接收中斷標(biāo)志位
- if (cntRxd < sizeof(bufRxd)) //接收緩沖區(qū)尚未用完時(shí),
- { //保存接收字節(jié),并遞增計(jì)數(shù)器
- bufRxd[cntRxd++] = SBUF;
- if (TI) //字節(jié)發(fā)送完畢
- TI = 0; //清零發(fā)送中斷標(biāo)志位
- flagTxd = 1; //設(shè)置字節(jié)發(fā)送完成標(biāo)志
復(fù)制代碼 |
