#include <reg52.h> #include <lcd.h> #include <epprom.h>
unsigned int temp_low_pulse1; unsigned int temp_low_pulse0; unsigned int temp_high_pulse1; unsigned int temp_high_pulse0; unsigned int count; unsigned char write_enable;
sbit led8=P0^7; sbit key=P0^0; sbit key1=P0^1; sbit key2=P0^2;
/********* 延時(shí)1S ******************************************/ void delay_1s() { unsigned int i,j; for(i=5;i>0;i--) for(j=110;j>0;j--); }
void initial() { EA=1; //開啟總中斷 EX1=1; //開啟外部中斷1 IT1=1; //外部中斷1為下降沿有效 TMOD=0x19; //定時(shí)器1,2 方式為1,且T0 GATE位有效 TH0=0x00; TL0=0x00; TH1=0x00; TL1=0x00; count=0; }
void main() { unsigned char temp,temp_ge,temp_shi,temp_bai,num_ge,num_shi,num_bai,num_qian; unsigned int count_qian,count_bai,count_shi,count_ge,num; initial(); init(); lcd_int();
num=0; while(1) { if(key==0) {
num++; if(num==2048) num=0; while(!key); } if(key1==0) {
if(num==0) num=2048; num--; while(!key1); } if(count>=2048) count=0; temp=read_add(num); temp_bai=temp/100; temp_shi=temp%100/10; temp_ge=temp%10; num_qian=num/1000; num_bai=num%1000/100; num_shi=num%100/10; num_ge=num%10; count_qian=count/1000; count_bai=count%1000/100; count_shi=count%100/10; count_ge=count%10; write_com(0x80); write_date(0x30+temp_bai); write_com(0x81); write_date(0x30+temp_shi); write_com(0x82); write_date(0x30+temp_ge); write_com(0x84); write_date(0x30+num_qian); write_com(0x85); write_date(0x30+num_bai); write_com(0x86); write_date(0x30+num_shi); write_com(0x87); write_date(0x30+num_ge); write_com(0x89); write_date(0x30+count_qian); write_com(0x8a); write_date(0x30+count_bai); write_com(0x8b); write_date(0x30+count_shi); write_com(0x8c); write_date(0x30+count_ge); if (write_enable==1) { write_add(count,5); //將紅外信號(hào)的低電平的值寫入儲(chǔ)存器COUNT地址內(nèi) delay_1s(); write_add(count+1,6); //將紅外信號(hào)的低電平的值寫入儲(chǔ)存器COUNT+1地址內(nèi) delay_1s(); write_add(count+2,7); //將紅外信號(hào)的高電平的值寫入儲(chǔ)存器COUNT+2地址內(nèi) delay_1s(); write_add(count+3,8); //將紅外信號(hào)的高電平的值寫入儲(chǔ)存器COUNT+3地址內(nèi) delay_1s(); write_enable=0; } }
void int1() interrupt 2 { EX1=0; //關(guān)外部中斷1 TR0=0; //關(guān)閉定時(shí)器0 TR1=0; //關(guān)閉定時(shí)器1 temp_low_pulse1=TH1-TH0; //將TH1減去TL0的值(即紅外信號(hào)的低電平)賦予temp_low_pulse1 temp_low_pulse0=TL1-TL0; //將TL1減去TL0的值(即紅外信號(hào)的低電平)賦予temp_low_pulse0 temp_high_pulse1=TH0; //將TH0值(即紅外信號(hào)的高電平值)賦予temp_high_pulse1 temp_high_pulse0=TL0; //將TL0值(即紅外信號(hào)的高電平值)賦予temp_high_pulse0 write_enable=1; TH0=0x00; //TH0清零 TL0=0x00; //TL0清零 TH1=0x00; //TH1清零 TL1=0x00; //TL1清零 TR0=1; //啟動(dòng)定時(shí)器0 TR1=1; //啟動(dòng)定時(shí)器1 led8=!led8; count=count+4; EX1=1; //開外部中斷1
本人編寫了一個(gè)紅外接收的程序,紅外接收管接收端接單片機(jī)中斷1,接收的紅外波形以后,開啟T0,T1定時(shí)器,對(duì)紅外波形的高低電平及時(shí),其中中斷下降沿開啟T1計(jì)時(shí),電平升高后開啟T0計(jì)時(shí),T1-T0的時(shí)間就是紅外波形的低電平時(shí)間,我利用AT24C16芯片保存定時(shí)時(shí)間,根據(jù)寫的程序,在兩次中斷間隙時(shí)間過短了,沒有足夠的時(shí)間寫進(jìn)存儲(chǔ)芯片,怎么解決啊?
