查看: 3181|回復: 0
12864點陣液晶屏代碼
ID:386503 發表于 2020-4-14 20:30 | 顯示全部樓層 |閱讀模式
#include <reg52.H>
#include <intrins.h>
sbit lcd_sclk=P0^0;  /*接口定義:lcd_sclk就是LCD的sclk*/
sbit lcd_sid=P0^1;   /*接口定義:lcd_sid就是LCD的sid*/
sbit lcd_rs=P2^6;    /*接口定義:lcd_rs就是LCD的A0*/
sbit lcd_reset=P2^5; /*接口定義:lcd_reset就是LCD的reset*/
sbit lcd_cs1=P2^4;   /*接口定義:lcd_cs1就是LCD的cs1*/
sbit Rom_IN=P0^3;    /*字庫IC接口定義:Rom_IN就是字庫IC的SI*/
sbit Rom_OUT=P0^2;   /*字庫IC接口定義:Rom_OUT就是字庫IC的SO*/
sbit Rom_SCK=P0^4;   /*字庫IC接口定義:Rom_SCK就是字庫IC的SCK*/
sbit Rom_CS=P0^5;    /*字庫IC接口定義Rom_CS就是字庫IC的CS#*/
#define ulong unsigned long
//uchar code wang[]={/*--文字:王--*/
// /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
//0x00,0x00,0x7F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xF8,
//0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x00,0x00
//uchar code tong[]={/*--  文字:  同  --*/
///*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
//0x00,0x00,0x3F,0xFC,0x20,0x04,0x20,0x04,0x2F,0xF4,0x20,0x04,0x20,0x04,0x27,0xE4,
//0x26,0x24,0x24,0x24,0x24,0x24,0x27,0xE4,0x24,0x24,0x20,0x04,0x20,0x14,0x20,0x08
//uchar code xue[]={/*--  文字:  學  --*/
//0x22,0x08,0x11,0x08,0x11,0x10,0x00,0x20,0x7F,0xFE,0x40,0x02,0x80,0x04,0x1F,0xE0,
//0x00,0x40,0x01,0x80,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00
/*寫指令到LCD模塊*/
void transfer_command_lcd(int data1)
char i;
lcd_rs=0;
for(i=0;i<8;i++)
  lcd_sclk=0;
  if(data1&0x80) lcd_sid=1;
  else lcd_sid=0;
  lcd_sclk=1;
   data1=data1<<=1;
/*寫數據到LCD模塊*/
void transfer_data_lcd(int data1)
char i;
lcd_rs=1;
for(i=0;i<8;i++)
  lcd_sclk=0;
  else lcd_sid=0;
  lcd_sclk=1;
   data1=data1<<=1;
/*延時*/
void delay(int n_ms)
int j,k;
for(j=0;j<n_ms;j++)
for(k=0;k<110;k++);
/*LCD模塊初始化*/
void initial_lcd()
lcd_cs1=0;
Rom_CS = 1;
lcd_reset=0;        /*低電平復位*/
delay(20);
lcd_reset=1;      /*復位完畢*/
delay(20);
transfer_command_lcd(0xe2);  /*軟復位*/
delay(5);
transfer_command_lcd(0x2c);  /*升壓步聚1*/
delay(5);
transfer_command_lcd(0x2e);  /*升壓步聚2*/
delay(5);
transfer_command_lcd(0x2f);  /*升壓步聚3*/
delay(5);
transfer_command_lcd(0x23);  /*粗調對比度,可設置范圍0x20~0x27*/
transfer_command_lcd(0x81);  /*微調對比度*/
transfer_command_lcd(0x2f);  /*0x28,微調對比度的值,可設置范圍0x00~0x3f*/
transfer_command_lcd(0xa2);  /*1/9偏壓比(bias)*/
transfer_command_lcd(0xc8);  /*行掃描順序:從上到下*/
transfer_command_lcd(0xa0);  /*列掃描順序:從左到右*/
transfer_command_lcd(0x40);  /*起始行:第一行開始*/
transfer_command_lcd(0xaf);  /*開顯示*/
lcd_cs1=1;
void lcd_address(uint page,uint column)
column=column-0x01;
transfer_command_lcd(0xb0+page-1);   /*設置頁地址*/
transfer_command_lcd(0x10+(column>>4&0x0f)); /*設置列地址的高4位*/
transfer_command_lcd(column&0x0f); /*設置列地址的低4位*/
/*全屏清屏*/
void clear_screen()
unsigned char i,j;
lcd_cs1=0;
Rom_CS = 1;
for(i=0;i<9;i++)
  transfer_command_lcd(0xb0+i);
  transfer_command_lcd(0x10);
  transfer_command_lcd(0x00);
  for(j=0;j<132;j++)
     transfer_data_lcd(0x00);
  lcd_cs1=1;
/*顯示16x16點陣圖像、漢字、生僻字或16x16點陣的其他圖標*/
void display_graphic_16x16(uint page,uint column,uchar *dp)
uint i,j;
  lcd_cs1=0;
Rom_CS = 1;
for(j=0;j<2;j++)
  lcd_address(page+j,column);
  for (i=0;i<16;i++)
   transfer_data_lcd(*dp);     /*寫數據到LCD,每寫完一個8位的數據后列地址自動加1*/
   dp++;
lcd_cs1=1;
/*顯示8x16點陣圖像、ASCII, 或8x16點陣的自造字符、其他圖標*/
void display_graphic_8x16(uint page,uchar column,uchar *dp)
uint i,j;
lcd_cs1=0;
for(j=0;j<2;j++)
  for (i=0;i<8;i++)
   dp++;
lcd_cs1=1;
/*顯示5*7點陣圖像、ASCII, 或5x7點陣的自造字符、其他圖標*/
void display_graphic_5x7(uint page,uchar column,uchar *dp)
uint col_cnt;
uchar page_address;
uchar column_address_L,column_address_H;
page_address = 0xb0+page-1;
lcd_cs1=0;
column_address_L =(column&0x0f)-1;
column_address_H =((column>>4)&0x0f)+0x10;
transfer_command_lcd(page_address);   /*Set Page Address*/
transfer_command_lcd(column_address_H); /*Set MSB of column Address*/
transfer_command_lcd(column_address_L); /*Set LSB of column Address*/
for (col_cnt=0;col_cnt<6;col_cnt++)
  dp++;
lcd_cs1=1;
/****送指令到字庫IC***/
void send_command_to_ROM( uchar datu )
uchar i;
for(i=0;i<8;i++ )
  if(datu&0x80)
   Rom_IN = 1;
   Rom_IN = 0;
   datu = datu<<1;
   Rom_SCK=0;
   Rom_SCK=1;
/****從字庫IC中取漢字或字符數據(1個字節)***/
static uchar get_data_from_ROM( )
uchar i;
uchar ret_data=0;
Rom_SCK=1;
for(i=0;i<8;i++)
  Rom_OUT=1;
  Rom_SCK=0;
  ret_data=ret_data<<1;
  if( Rom_OUT )
   ret_data=ret_data+1;
   ret_data=ret_data+0;
  Rom_SCK=1;
return(ret_data);
/*從相關地址(addrHigh:地址高字節,addrMid:地址中字節,addrLow:地址低字節)中連續讀出DataLen個字節的數據到 pBuff的地址*/
/*連續讀取*/
void get_n_bytes_data_from_ROM(uchar addrHigh,uchar addrMid,uchar addrLow,uchar *pBuff,uchar DataLen )
uchar i;
Rom_CS = 0;
lcd_cs1=1;
Rom_SCK=0;
send_command_to_ROM(0x03);
send_command_to_ROM(addrHigh);
send_command_to_ROM(addrMid);
send_command_to_ROM(addrLow);
for(i = 0; i < DataLen; i++ )
      *(pBuff+i) =get_data_from_ROM();
Rom_CS = 1;
ulong  fontaddr=0;
void display_GB2312_string(uchar y,uchar x,uchar *text)
uchar i= 0;
uchar addrHigh,addrMid,addrLow ;
uchar fontbuf[32];
while((text[i]>0x00))
  if(((text[i]>=0xb0) &&(text[i]<=0xf7))&&(text[i+1]>=0xa1))
   /*國標簡體(GB2312)漢字在字庫IC中的地址由以下公式來計算:*/
   /*Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 846)*32+ BaseAdd;BaseAdd=0*/
   /*由于擔心8位單片機有乘法溢出問題,所以分三部取地址*/
   fontaddr = (text[i]- 0xb0)*94;
   fontaddr += (text[i+1]-0xa1)+846;
   fontaddr = (ulong)(fontaddr*32);
   addrHigh = (fontaddr&0xff0000)>>16;  /*地址的高8位,共24位*/
   addrMid = (fontaddr&0xff00)>>8;      /*地址的中8位,共24位*/
   addrLow = fontaddr&0xff;      /*地址的低8位,共24位*/
   get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*取32個字節的數據,存到"fontbuf[32]"*/
   display_graphic_16x16(y,x,fontbuf);/*顯示漢字到LCD上,y為頁地址,x為列地址,fontbuf[]為數據*/
   i+=2;
   x+=16;
  else if(((text[i]>=0xa1) &&(text[i]<=0xa3))&&(text[i+1]>=0xa1))
   /*國標簡體(GB2312)15x16點的字符在字庫IC中的地址由以下公式來計算:*/
   /*Address = ((MSB - 0xa1) * 94 + (LSB - 0xA1))*32+ BaseAdd;BaseAdd=0*/
   fontaddr = (text[i]- 0xa1)*94;
   fontaddr += (text[i+1]-0xa1);
   i+=2;
   x+=16;
  else if((text[i]>=0x20) &&(text[i]<=0x7e))
   unsigned char fontbuf[16];
   fontaddr = (text[i]- 0x20);
   fontaddr = (unsigned long)(fontaddr*16);
   fontaddr = (unsigned long)(fontaddr+0x3cf80);
   get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,16 );/*取16個字節的數據,存到"fontbuf[32]"*/
   display_graphic_8x16(y,x,fontbuf);/*顯示8x16的ASCII字到LCD上,y為頁地址,x為列地址,fontbuf[]為數據*/
   i+=1;
   x+=8;
   i++;
//===============main program===================
void main(void)
  Rom_CS=1;
  lcd_cs1=0;
  initial_lcd();
  clear_screen();    //clear all dots
  display_GB2312_string(1,1,"Become Lonely !"); /*在第1頁,第1列,顯示一串16x16點陣漢字或8x16的ASCII字*/
   delay(1000);
  display_GB2312_string(3,1,"0.0    0.0");  /*顯示一串16x16點陣漢字或8x16的ASCII字.以下雷同*/
   delay(1000);
  display_GB2312_string(5,1,"0.0    0.0");
   delay(1000);
  display_GB2312_string(7,1,"0.0    0.0");
   delay(5000);
