查看: 3419|回復: 0
基于51單片機的廣告燈程序
  1. #include <REG52.H>                                  //頭文件
  2. /******定義廣告燈樣式******/
  3. unsigned char code table1[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xfe,0xfd,0xfb,0xf7,0xef,
  4.                              0xdf,0xbf,0x7f,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0x7f,0xbf,
  5.                                                          0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0x00,0xff,0x00,0xff};
  6. unsigned char code table2[]={0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00,0x80,0xc0,0xe0,0xf0,
  7.                              0xf8,0xfc,0xfe,0xff,0xfe,0xfc,0xf9,0xf3,0xf7,0xcf,0x9f,0x3f,0x9f,
  8.                                                          0xcf,0xf7,0xf3,0xf9,0xfc,0xff,0x7e,0x3c,0x18,0x00,0xff,0x7e,0x3c,
  9.                                                          0x18,0x00,0xff,0x7e,0x3c,0x18,0x00,0xff};
  10. //table2[]是增加的廣告樣式
  11. //全亮由左向右依次亮起,由右向左依次熄滅,兩相鄰燈同時左移右移,左右依次向中間亮起(三遍)
  12. unsigned char i;        //定義循環變量
  13. /******定義延時子函數******/
  14. void delay(void)
  15. {
  16.         unsigned char m,n,s;
  17.         for(m=20;m>0;m--)
  18.         for(n=20;n>0;n--)
  19.         for(s=248;s>0;s--);
  20. }
  21. void main(void)                                //主函數
  22. {
  23.     while(1)
  24.         {
  25.         for(i=0;i<38;i++)                //兩排燈同時進行原來的廣告樣式
  26.         {
  27.             P2=table1[i];
  28.                 P3=table1[i];
  29.                 delay();
  30.         }
  31.         for(i=0;i<47;i++)           //兩排燈同時進行新添加的廣告樣式
  32.         {
  33.             P2=table2[i];
  34.                 P3=table2[i];
  35.                 delay();
  36.         }
  37.         }
  38. }
  39.
廣告燈.rar (70.47 KB, 下載次數: 14)
