查看: 2259|回復: 1
12c5a60s2 ad讀取1602顯示(匯編語言)
ID:277948 發表于 2020-4-9 12:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
     P1ASF     EQU 09DH
    ADC_CONTR EQU 0BCH
    ADC_RESL  EQU 0BEH
    AUXR1     EQU 0A2H
    LCD_RS EQU P2.6
    LCD_RW EQU P2.5
    LCD_EN EQU P2.7
    LCD_DATA EQU P0
    AD_L   EQU 30H
    ORG 0000H
    LJMP START
START:
    LCALL LCD_INIT;
    MOV   R1,#01H
    LCALL LCD_WCMOD
    MOV   R1,#01H
    LCALL LCD_WCMOD
    S2:LCALL INIT_ADC
       LCALL AD_CON
       MOV   R1,#01H
       LCALL LCD_WCMOD
       LCALL LCD_DIS2
       LJMP  S2
INIT_ADC:
    MOV P1ASF,#01H
    MOV AUXR1,#04H
    MOV ADC_CONTR,#0E0H
    LCALL DELAY5US
    MOV ADC_CONTR,#0E8H
    LCALL DELAY5US
RET
AD_CON:
    MOV ADC_CONTR,#0E8H
    LCALL DELAY5US
    MOV A,ADC_RESL
    LCALL DELAY5US
    MOV AD_L,A
    MOV R3,AD_L
    MOV ADC_CONTR,#00H
RET
//*************************************************10進制顯示*********************************************//
LCD_DIS2:
    LCALL LCD_BUSY
    CLR   A
    MOV   A,R3
    MOV   B,#33H
    DIV   AB
    ANL   A,#0FH
    ADD   A,#30H
    LCALL LCD_WDATA
    LCALL DELAY
       MOV   A,#2EH
    LCALL LCD_WDATA
    LCALL DELAY
    MOV   A,B
    MOV   B,#05H
    MUL   AB
    MOV   B,#33H
    DIV   AB
    MOV   R2,B
    MOV   B,#02H
    MUL   AB
    MOV   R0,A
    MOV   A,R2
    MOV   B,#05H
    MUL   AB
    MOV   B,#33H
    DIV   AB
    ANL   A,#0FH
    MOV   B,#04H
    MUL   AB
    MOV   R4,A
    CJNE  A,#09H,L1
    L1: JNC LOOP2
        JMP LOOP1
    LOOP1:
        MOV   A,R0
        ADD   A,#30H
        LCALL LCD_WDATA
        LCALL DELAY
        MOV   A,R4
        ADD   A,#30H
        LCALL LCD_WDATA
        JMP L2
    LOOP2:
        INC   R0
        MOV   A,R0
        ADD   A,#30H
        LCALL LCD_WDATA
        LCALL DELAY
        MOV   A,R4
        SUBB   A,#0AH
        ADD   A,#30H
        LCALL LCD_WDATA
        JMP L2
    L2:
         LCALL DELAY
RET
//*************************************************1602********************************//
LCD_INIT:
    MOV   R1,#38H
    LCALL LCD_WCMOD
    MOV   R1,#08H
    LCALL LCD_WCMOD
    MOV   R1,#0CH
    LCALL LCD_WCMOD
RET
LCD_WCMOD:
    LCALL LCD_BUSY
    CLR   LCD_EN
    CLR   LCD_RW
    CLR   LCD_RS
    SETB  LCD_EN
    MOV   A,R1
    MOV   LCD_DATA,A
    CLR   LCD_EN
RET
LCD_WDATA:
    CLR   LCD_EN
    SETB  LCD_RS
    CLR   LCD_RW
    SETB  LCD_EN
    MOV   LCD_DATA,A
    CLR   LCD_EN
RET
LCD_BUSY:
    CLR   A
    CLR   LCD_EN
    CLR   LCD_RS
    SETB  LCD_RW
    SETB  LCD_EN
    MOV   A,LCD_DATA
    CLR   LCD_EN
    JB    ACC.7,LCD_BUSY
    LCALL DELAY
RET
DELAY:
    MOV  R7,#250
    LOOP0:MOV R6,#100
    DJNZ R6,$
    DJNZ R7,LOOP0
RET
DELAY5US:
    MOV R2,#120
    DJNZ R2,$
RET
END
12_ad采集.rar
22.5 KB, 下載次數: 3, 下載積分: 黑幣 -5
12c5a60s2 ad讀取
ID:1 發表于 2020-4-11 00:55 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
