查看: 2822|回復: 0
51 MCU獨立按鍵輸入 Proteus仿真&C程序設計
  1. #include "scanf.h"
  2. #include "delay.h"
  3. #include <reg52.h>
  4. #include "led.h"
  5. #define uint unsigned int
  6. #define uchar unsigned char
  7. void key0()
  8. {
  9.         liushui6();
  10.         P0=0xff;
  11. }
  12. void key1()
  13. {
  14.         liushui5();
  15.         P0=0xff;
  16. }
  17. void key2()
  18. {
  19.         led_turn();
  20.         P0=0xff;
  21. }
  22. void key3()
  23. {
  24.         liushui4();
  25.         P0=0xff;
  26. }
  27. void key4()
  28. {
  29.         liushui3();
  30.         P0=0xff;
  31. }
  32. void key5()
  33. {
  34.         liushui2();
  35.         P0=0xff;
  36. }
  37. void key6()
  38. {
  39.         liushui1();
  40.         P0=0xff;
  41. }
  42. void key7()
  43. {
  44.         P0=0x00;
  45.         delay_ms(800);
  46.         P0=0xff;
  47. }
  48. void scanf(void)
  49. {
  50.         while(1)
  51.          {
  52.                  while(P1==0xff);
  53.                  delay_ms(10);
  54.              while(P1==0xff);
  55.              switch(P1)
  56.                         {
  57.                                  case 0xfe:key0();break;
  58.                                  case 0xfd:key1();break;
  59.                                  case 0xfb:key2();break;
  60.                                  case 0xf7:key3();break;
  61.                                  case 0xef:key4();break;
  62.                                  case 0xdf:key5();break;
  63.                                  case 0xbf:key6();break;
  64.                                  case 0x7f:key7();break;
  65.                                  default:  break;
  66.                         }
  67.           while(P1!=0xff);//等待鍵釋放
  68.          }
  69. }
實驗二.rar (86.25 KB, 下載次數: 15)
