查看: 4840|回復: 0
51單片機ADC0809電壓采集
程序:
/******************調用頭文件*******************/
#include "reg52.h"
#include "intrins.h"
/*****************定義地址**********************/
sbit KEY   = P1^0;            //按鍵
sbit ADD_C = P1^2;
sbit ADD_B = P1^3;
sbit ADD_A = P1^4;            // 選輸入口
sbit CLK =   P1^5;            // 時鐘
sbit START = P1^6;            // 轉換啟動信號
sbit EOC =   P1^7;            // 轉換結束信號
sbit OE =    P1^1;            // 輸出允許信號
/*****************定義全局變量********************/
int flag = 0;
/*****************數碼管段碼**********************/
unsigned char code DUAN[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};    //不帶小數點
unsigned char code DUAN1[] = {0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,0x80};   //帶小數點
/*****************電壓值區間******************/
float JS[] = {0,62.5,125,187.5,250,312.5,375,437.5,500};
/*******************讀ADC*******************/
void read_adc(void)
                START = 0;
                _nop_();
                START = 1;
                _nop_();
                START = 0;
                while(EOC==0);
                OE=1;
/*****************AD值區間計算*********************/
int LED_JS(float AD)
        int t0 = 0;
        int i = 0;
        for(; i<8 ;i++)
                if(AD >= JS[i])
                        if(AD <= JS[i+1])
                                t0 = i;
        return t0+1;
/*****************不精確延時**********************/
void delay_ms(int i)
        int j=0;
        while(i--)
                for(j=0;j<120;j++);
/*****************數碼管顯示**********************/
void display1(unsigned char ADC1_PORT)
        int AD1 = ADC1_PORT * 500.0/255.0;
        P2 = 0xFD;   P0 = DUAN1[AD1/100];     delay_ms(5);     // 位選:P2^1  個位
        P2 = 0xFB;   P0 = DUAN[(AD1/10)%10];  delay_ms(5);     // 位選:P2^2  小數點后一位
        P2 = 0xF7;   P0 = DUAN[AD1%10];       delay_ms(5);     // 位選:P2^3  小數點后兩位
/*****************LED顯示**********************/
void display2(unsigned char ADC2_PORT)
        float AD2 = ADC2_PORT * 1.96;
        P2 = 0xFF;                  // 清屏
  switch(LED_JS(AD2))
                case 1: P0 = 0xff; break;
                case 2: P0 = 0xfe; break;
                case 3: P0 = 0xfc; break;
                case 4: P0 = 0xf8; break;
                case 5: P0 = 0xe0; break;
                case 6: P0 = 0xc0; break;
                case 7: P0 = 0x80; break;
                case 8: P0 = 0x00; break;
                default:P0 = 0xef;
/*******************初始化*******************/
void init()
        ADD_C=0;
        ADD_B=1;
        ADD_A=1;           // 選擇第三通道
        CLK=0;             //時鐘
        START=1;           // 內部寄存器清零
        EOC=1;             // 轉換結束
        OE=0;              // 使能
        TMOD=0x02;      // 0000_0010 8位 0~255
        TH0=200;
        TL0=200;        // 裝載初值
        EA=1;           // 開總中斷
        ET0=1;          // 開定時器中斷
        TR0=1;          // 開定時器
/****************mAin函數*******************/
        init();         // 初始化
                if(KEY == 0)               // 檢測到按鍵
                        delay_ms(5);             // 防抖
                        if(KEY == 0)
                                while(!KEY);           // 等松手
                                flag ++;               // 加1
                                flag &= 0x01;          // 與0x01相與 保證每次進入flag都為0或1
                if(flag == 0)
                        read_adc();
                        display1(P3);
                        OE=0;
                if(flag == 1)
                        read_adc();
                        display2(P3);
                        OE=0;
/****************中斷服務程序*******************/
void TIM0_Serves() interrupt 1         // 用于產生CLK
        CLK = !CLK;
01.zip
58.42 KB, 下載次數: 53, 下載積分: 黑幣 -5
