用stc89c52單片機(jī)做了一個(gè)串口控制燈,結(jié)果加了看門狗后,就燒錄不了別的程序了,大神幫忙看一下問題出在哪里
#include<reg52.h>
sfr WDT_CONTR=0xe1;
sbit beep=P1^5;
sbit G_led=P1^2;
sbit B_led=P1^3;
sbit R_led=P1^4;
sbit timekey=P3^2;
static unsigned char Rdata;
void delay(unsigned int a) //1ms
unsigned int i;
while(--a!=0)
for(i=0;i<1000;i++);
void timer0init()
TMOD|=0X09;
TH0=0XFF;
TL0=0X9C;
ET0=1;
EA=1;
TR0=1;
void UART_init()
SCON=0X50;
TMOD=0X20;
PCON=0X80;
TH1=0XCC;
TL1=0XCC;
ES=1;
EA=1;
TR1=1;
WDT_CONTR=0x35;
timekey=0;
R_led=0;
G_led=1;
B_led=0;
beep=0;
UART_init();
timer0init();
delay(100);
WDT_CONTR=0x35;
void Usart() interrupt 4
Rdata=SBUF;
switch(Rdata)
case'1':B_led=0;G_led=1;R_led=0;beep=0;timekey=0;break;
case'2':B_led=1;G_led=0;R_led=0;beep=0;timekey=0;break;
case'3':B_led=0;G_led=0;R_led=1;timekey=1;break;
RI=0;
SBUF=Rdata;
while(!TI);
TI=0;
void Timer0() interrupt 1
static unsigned int i;
static unsigned int j;
TH0=0XFF; //?????????????????1ms
TL0=0X9C;
i++;
j++;
if(i==5000)
i=0;
R_led=~R_led;
if(j==5000)
j=0;
beep=~beep;
