近日,“嫁接”了個VFD和TM1638的程序,想驅(qū)動4位(加冒號)的數(shù)碼管,顯示個時鐘,結(jié)果功能正常(暫時未加冒號顯示部分),可看到走時,但顯示有時關(guān)閉(沒顯示),有時顯示中不停、無規(guī)律閃爍。求助走過路過的給看看,是何原因?
單片機(jī)程序如下:
20200405 嫁接了個原來顯示正常的VFD程序,結(jié)果走時正常,但無規(guī)律閃爍
#include "REG52.H"
#include "intrins.h"
#define T100us (256-134)
unsigned char day,hour, minute, second;
unsigned int c100us;
#define const_time_05s 6880 //0.5秒鐘的時間需要的定時中斷次數(shù) 6881,15小時慢3秒
#define DATA_COMMAND 0X40
#define DISP_COMMAND 0x80
#define ADDR_COMMAND 0XC0
//TM1638模塊引腳定義
sbit DIO=P0^0;
sbit CLK=P0^1;
sbit STB=P0^2;
void initial_myself(); //三區(qū)之:一區(qū) 系統(tǒng)自身變量;
void delay_long(unsigned int uiDelaylong); //一線
void T0_time(); //定時中斷函數(shù)
//共陰數(shù)碼管顯示代碼
unsigned char code shuzi[]={0x7b,0x18,0x6d,0x3d,0x1e,0x37,0x77,0x19,0x7b,0x3f}; //0-9
void TM1638_Write(unsigned char DATA) //寫數(shù)據(jù)函數(shù)
unsigned char i;
for(i=0;i<8;i++)
CLK=0;
if(DATA&0X01)
DIO=1;
DIO=0;
DATA>>=1;
CLK=1;
unsigned char TM1638_Read(void) //讀數(shù)據(jù)函數(shù)
unsigned char i;
unsigned char temp=0;
DIO=1; //設(shè)置為輸入
for(i=0;i<8;i++)
temp>>=1;
CLK=0;
if(DIO)
temp|=0x80;
CLK=1;
return temp;
void Write_COM(unsigned char cmd) //發(fā)送命令字
STB=0;
TM1638_Write(cmd);
STB=1;
void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫入數(shù)據(jù)
Write_COM(0x44);
STB=0;
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
STB=1;
//20200405
void write_TM1638(uchar w,uchar dat) //(Wλ:0-7 ,dat????)
uchar wei[]={0x00,0x02,0x04,0x06,}; //0x08,0x0a,0x0c,0x0e,這是原程序8個數(shù)碼管的
Write_DATA(wei[w],dat);
//清TM1638
void clr_tm1638()
uchar i;
Write_COM(0x40);
STB=0;
TM1638_Write(0xc0);
for(i=0;i<16;i++)TM1638_Write(0x00);
STB=1;
//TM1638初始化函數(shù)
void init_TM1638(void)
unsigned char i;
Write_COM(0x8b); //亮度 (0x88-0x8f)8級亮度可調(diào)
Write_COM(0x40); //采用地址自動加1
STB=0; //
TM1638_Write(0xc0); //設(shè)置起始地址
for(i=0;i<16;i++) //傳送16個字節(jié)的數(shù)據(jù)
TM1638_Write(0x00);
STB=1;
initial_myself();
delay_long(100);
write_TM1638(3,shuzi[minute%10]);
write_TM1638(0,shuzi[minute/10]);
write_TM1638(1,shuzi[hour%10]);
write_TM1638(2,shuzi[hour/10]);
void T0_time() interrupt 1
c100us--; //c100us;主程序void main()里有此句,減一后if判斷是否為“0”
//不為零繼續(xù)減一
if(c100us==0) //為零執(zhí)行下面{}
c100us=const_time_05s; //因為已經(jīng)見到零,所以進(jìn)來先重裝數(shù)tick=7554
second++; //秒加一
if(second==60) //判斷加一后second=60不,若不等跳出執(zhí)行前面c100us--;若等于60了,進(jìn)入下面{}
second=0; //因為已經(jīng)見到60,所以清零
minute++; //到了60秒,就分加一
if(minute==60) //判斷加一后minute=60不,若不等跳出執(zhí)行前面c100us--;若等于60了,進(jìn)入下面{}
minute=0;
hour++;
if(hour==24)
hour=0;
day++;
if(day==8)
day=1;
void delay_long(unsigned int uiDelayLong)
unsigned int i;
unsigned int j;
for(i=0;i<uiDelayLong;i++)
for(j=0;j<500;j++) //內(nèi)嵌循環(huán)的空指令數(shù)量
; //一個分號相當(dāng)于執(zhí)行一條空語句
TMOD=0x02; //設(shè)置定時器0為工作方式2
TH0=T100us;
TL0=T100us;
init_TM1638(); //ET16311_Init();
day=4;
hour=10;
minute=50;
second=0;
EA=1; //開總中斷
ET0=1; //允許定時中斷
TR0=1; //啟動定時中斷
