查看: 1330|回復: 0
51單片機,矩陣鍵盤程序源碼
ID:722217 發表于 2020-4-4 14:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"
typedef unsigned char u8;
typedef unsigned int u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
#define GPIO_KEY P1
#define GPIO_DIG P0
u8 KeyValue;
u8 code smgduan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                   0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(u16 i)
    while(i--);
void KeyDown()
    u8 a;
    GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)
            delay(1000);
            if(GPIO_KEY!=0x0f)
                           GPIO_KEY=0x0f;
                        switch(GPIO_KEY)
                         case(0x07):KeyValue=0;break;
                         case(0x0b):KeyValue=1;break;
                         case(0x0d):KeyValue=2;break;
                         case(0x0e):KeyValue=3;break;
                       GPIO_KEY=0xf0;
                       switch(GPIO_KEY)
                         case(0x70):KeyValue=KeyValue;break;
                         case(0xb0):KeyValue=KeyValue+4;break;
                         case(0xd0):KeyValue=KeyValue+8;break;
                         case(0xe0):KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))
                           delay(1000);
                           a++;
   LSA=0;
   LSB=0;
   LSC=0;
       KeyDown();
           GPIO_DIG=smgduan[KeyValue];
