查看: 2299|回復(fù): 1
這個(gè)是我學(xué)習(xí)別的大佬改的程序,8*8點(diǎn)陣?yán)飻?shù)字0從右到左滾動(dòng)。我想問還有沒有別的方法
ID:716161 發(fā)表于 2020-4-2 22:03 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <STC12C5A60S2.H>
#include <intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit DU = P2^0; //數(shù)碼管段選
sbit WE = P2^1; //數(shù)碼管位選
sbit CS88 = P2^2; //8X8點(diǎn)陣使能
sbit LCDEN=P2^5;
u8 code duan0[8][8]={{0x00,0x3C,0x42,0x42,0x42,0x3C,0x00,0x00},{0x3C,0x42,0x42,0x42,0x3C,0x00,0x00,0x00},
                     {0x42,0x42,0x42,0x3C,0x00,0x00,0x00,0x3C}, {0x42,0x42,0x3C,0x00,0x00,0x00,0x3C,0x42},
      {0x42,0x3C,0x00,0x00,0x00,0x3C,0x42,0x42},{0x3C,0x00,0x00,0x00,0x3C,0x42,0x42,0x42},
       {0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x3C},{0x00,0x00,0x3C,0x42,0x42,0x42,0x3C,0x00}};    //數(shù)字0的段選
u8 code wei[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};              //位選
void delay(u16 c)
u8 a,b;
    for(;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
  u8 i,j;
  u8 num;
       for(i=0;i<8;i++)
     num=40;
     while (num--)
         for(j=0;j<8;j++)
      DU=1;
                     P0=duan0[i][j];//取顯示數(shù)據(jù)
                  DU=0;
                  CS88=1;
                  P0=wei[j];  //取段碼
                  CS88=0;
                  delay(10); //掃描間隙延時(shí)
     delay(100);
ID:744201 發(fā)表于 2020-5-4 22:16 | 只看該作者
有沒有仿真圖
