查看: 9480|回復(fù): 35
51單片機(jī) 用LCD1602顯示DHT11采集的溫濕度,實(shí)物可以顯示溫度但是仿真顯示不出來
回帖獎勵 90 黑幣 回復(fù)本帖可獲得 30 黑幣獎勵! 每人限 3 次
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^2;
sbit LCD1602_RW = P1^3;
sbit LCD1602_E  = P1^1;
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標(biāo)位置,(x,y)-對應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標(biāo)計(jì)算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應(yīng)屏幕上的起始坐標(biāo),str-字符串指針 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (*str != '\0')  //連續(xù)寫入字符串?dāng)?shù)據(jù),直到檢測到結(jié)束符
        LcdWriteDat(*str++);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標(biāo)關(guān)閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
#include<reg52.h>
#include<intrins.h>
sbit Data=P1^0;
uchar rec_dat[13]="123695669999";
extern void InitLcd1602();
uchar showset[16]="12369566999999";
int wendu=0;
int shidu=0;
sbit shezhi=P2^0;
sbit jia=P2^1;
sbit jian=P2^2;
sbit beep=P3^7;
int wendul=5;
int wenduh=30;
int shidul=30;
int shiduh=60;
int change=0;
uchar key_can;         //按鍵值
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void DHT11_delay_us(uchar n)
    while(--n);
void DHT11_delay_ms(uint z)
   uint i,j;
   for(i=z;i>0;i--)
      for(j=110;j>0;j--);
void DHT11_start()
   Data=1;
   DHT11_delay_us(2);
   Data=0;
   DHT11_delay_ms(20);
   Data=1;
   DHT11_delay_us(30);
uchar DHT11_rec_byte()
   uchar i,dat=0;
  for(i=0;i<8;i++)
      while(!Data);
      DHT11_delay_us(8);
      dat<<=1;
      if(Data==1)
         dat+=1;
      while(Data);
    return dat;
void DHT11_receive()
    uchar R_H,R_L,T_H,T_L,RH,RL,TH,TL,revise;
    DHT11_start();
    if(Data==0)
        while(Data==0);   //等待數(shù)據(jù)
        DHT11_delay_us(40);  //延時80us
        R_H=DHT11_rec_byte();    //濕度高位
        R_L=DHT11_rec_byte();    //濕度低位
        T_H=DHT11_rec_byte();    //溫度高位
        T_L=DHT11_rec_byte();    //溫度低位
        revise=DHT11_rec_byte(); //獲取數(shù)據(jù)
        DHT11_delay_us(25);    //延時
        if((R_H+R_L+T_H+T_L)==revise)      //校驗(yàn)
            RH=R_H;
            RL=R_L;
            TH=T_H;
            TL=T_L;
        /*數(shù)據(jù)分解*0-9*/
//        rec_dat[0]='0'+(RH/10);
//        rec_dat[1]='0'+(RH%10);
//        rec_dat[2]='R';
//        rec_dat[3]='H';
//        rec_dat[4]=' ';
//        rec_dat[5]=' ';
//        rec_dat[6]='0'+(TH/10);
//        rec_dat[7]='0'+(TH%10);
//        rec_dat[8]='C';
                                shidu=RH;
                                wendu=TH;
                                rec_dat[0]='H';
                                rec_dat[1]=':';
                                rec_dat[2]='0'+(RH/10);
        rec_dat[3]='0'+(RH%10);
        rec_dat[4]='R';
        rec_dat[5]='H';
        rec_dat[6]=' ';
        rec_dat[7]=' ';
                                rec_dat[8]='T';
                                rec_dat[9]=':';
        rec_dat[10]='0'+(TH/10);
        rec_dat[11]='0'+(TH%10);
        rec_dat[12]='C';
   InitLcd1602();   //1602初始化
       DHT11_delay_ms(500);    //DHT11初始1S延時1500
       DHT11_receive();
                         if(shezhi==0)
                                 DHT11_delay_ms(2);
                                 if(shezhi==0)
                                         change++;
                                  if(change>3)
                                         change=0;
                                if(change==0)
                                        if(jia==0)
                                                DHT11_delay_ms(2);
                                    if(jia==0)
                                                         shidul++;
                                                        if(shidul>99)
                                                         shidul=99;
                                         if(jian==0)
                                                DHT11_delay_ms(2);
                                    if(jian==0)
                                                         shidul--;
                                                        if(shidul<0)
                                                         shidul=0;
                                if(change==1)
                                        if(jia==0)
                                                DHT11_delay_ms(2);
                                    if(jia==0)
                                                         shiduh++;
                                                        if(shiduh>99)
                                                         shiduh=99;
                                         if(jian==0)
                                                DHT11_delay_ms(2);
                                    if(jian==0)
                                                         shiduh--;
                                                        if(shiduh<0)
                                                         shiduh=0;
                                if(change==2)
                                        if(jia==0)
                                                DHT11_delay_ms(2);
                                    if(jia==0)
                                                         wendul++;
                                                        if(wendul>99)
                                                         wendul=99;
                                         if(jian==0)
                                                DHT11_delay_ms(2);
                                    if(jian==0)
                                                         wendul--;
                                                        if(wendul<0)
                                                         wendul=0;
                                if(change==3)
                                        if(jia==0)
                                                DHT11_delay_ms(2);
                                    if(jia==0)
                                                         wenduh++;
                                                        if(wenduh>99)
                                                         wenduh=99;
                                         if(jian==0)
                                                DHT11_delay_ms(2);
                                    if(jian==0)
                                                         wenduh--;
                                                        if(wenduh<0)
                                                         wenduh=0;
                    showset[0]='L';
                                showset[1]=':';
                                showset[2]='0'+(shidul/10);
        showset[3]='0'+(shidul%10);
                    showset[4]='H';
                                showset[5]=':';
                                showset[6]='0'+(shiduh/10);
        showset[7]='0'+(shiduh%10);
                                showset[8]='L';
                                showset[9]=':';
        showset[10]='0'+(wendul/10);
        showset[11]='0'+(wendul%10);
              showset[12]='L';
                                showset[13]=':';
        showset[14]='0'+(wenduh/10);
        showset[15]='0'+(wenduh%10);
                                if((shidu< shidul )|| (shidu>shiduh))
                                        beep=0;
                                else if((wendu< wendul )|| (wendu>wenduh))
                                        beep=0;
                                        beep=1;
                  LcdShowStr(0,1,showset);  //顯示溫濕度設(shè)置
                        LcdShowStr(0,0,rec_dat);  //顯示溫濕度
收藏收藏3 分享淘帖 頂 踩
ID:719492 發(fā)表于 2020-4-1 14:40 | 只看該作者
為什么我的proteus沒有DHT11
ID:719492 發(fā)表于 2020-4-1 14:41 | 只看該作者
為什么我的Proteus沒有DHT11這個傳感器
ID:584814 發(fā)表于 2020-4-1 19:07 | 只看該作者
這程序拔掉DHT11試試
ID:362692 發(fā)表于 2020-4-2 15:14 來自觸屏版 | 只看該作者
只接一個LCD試試,有沒有顯示,沒顯示可能就是LCD部分的程序問題
ID:304751 發(fā)表于 2020-4-4 01:47 | 只看該作者
384749736 發(fā)表于 2020-4-1 14:40
為什么我的proteus沒有DHT11
用8.9試試
ID:745454 發(fā)表于 2020-5-7 18:23 | 只看該作者
剛好學(xué)習(xí)了謝謝樓主
ID:302325 發(fā)表于 2020-5-7 22:05 | 只看該作者
多半是時序問題吧
ID:440553 發(fā)表于 2020-5-8 00:40 | 只看該作者
while(Data==0);   //等待數(shù)據(jù)    ,可能會死循環(huán)在DTH11程序中。在這個while中寫一個超時跳出等待的語句
ID:746593 發(fā)表于 2020-5-8 08:48 | 只看該作者
會不會是仿真哪里出錯了?你檢查一下仿真
ID:420836 發(fā)表于 2020-5-8 08:49 | 只看該作者
通常說的是真實(shí)電路有效,但模擬可能無效。非常奇怪
ID:739545 發(fā)表于 2020-5-8 09:03 | 只看該作者
仿真和實(shí)際有差異,參考下網(wǎng)上的LCD1602顯示程序
ID:746607 發(fā)表于 2020-5-8 09:21 | 只看該作者
可以直接在keil跑片上仿真,也可以看變量值
ID:748033 發(fā)表于 2020-5-15 01:02 | 只看該作者
按鍵功能都實(shí)現(xiàn)不了!
ID:752299 發(fā)表于 2020-5-15 09:23 | 只看該作者
選擇實(shí)物類的比較簡單
ID:753788 發(fā)表于 2020-5-17 10:15 | 只看該作者
為什么我單片機(jī)燒進(jìn)去程序不行啊,難過
ID:745454 發(fā)表于 2020-5-17 12:32 | 只看該作者
按鍵模塊好像有問題
ID:755472 發(fā)表于 2020-5-20 13:22 | 只看該作者
應(yīng)該是protues軟件支持兼容性不好,建議用最新的版本
ID:780711 發(fā)表于 2020-6-16 13:28 | 只看該作者
樓主解決了嗎?是時序問題嗎?該怎么調(diào)呢?
ID:600952 發(fā)表于 2020-6-16 14:10 | 只看該作者
bobo233 發(fā)表于 2020-5-8 00:40
我同意你的觀點(diǎn),不知樓主解決了沒有
ID:600952 發(fā)表于 2020-6-16 14:13 | 只看該作者
唉,仿真就是這樣,總會出現(xiàn)各種各樣的問題,很讓人摸不到頭腦,(我發(fā)現(xiàn)大部分24小時必答的問題都是關(guān)于仿真的)這大概就是仿真程序需要完善的地方了
ID:633896 發(fā)表于 2020-7-7 12:06 | 只看該作者
看看是不是時鐘的問題  比如你的實(shí)物用的是11.0592Mhz 你的仿真用的是12Mhz 可能結(jié)果就不一樣。傳感器對延時要求是很高的、
ID:595237 發(fā)表于 2020-7-7 21:48 | 只看該作者
按鍵仿真  電平不正常,,LCD仿真能夠顯示  ,有時候不顯示,真的莫名其妙
ID:595237 發(fā)表于 2020-7-7 23:49 | 只看該作者
可以顯示,按鍵不靈活
ID:541982 發(fā)表于 2020-7-8 10:22 | 只看該作者
單片機(jī)要設(shè)置參數(shù)
ID:510861 發(fā)表于 2020-7-8 12:27 來自觸屏版 | 只看該作者
我的1602就是顯示不了解
ID:327265 發(fā)表于 2020-7-8 17:24 | 只看該作者
斷點(diǎn)仿真看時序,直接明了
ID:235954 發(fā)表于 2020-7-12 07:13 | 只看該作者
時序問題,應(yīng)該開在等著忙時序,數(shù)據(jù)沒能讀回來
ID:1027159 發(fā)表于 2022-5-22 16:49 | 只看該作者
樓主 我也是一樣的問題  接線仿真都一樣 實(shí)物可以 仿真數(shù)據(jù)在液晶上面讀不了
ID:161164 發(fā)表于 2022-5-23 13:18 | 只看該作者
小灰灰灰灰 發(fā)表于 2022-5-22 16:49
部份版本的Protues LCD1602仿真不支援查忙 于是你的程序在while (sta & 0x80);中死循環(huán)了
ID:1010970 發(fā)表于 2023-4-20 10:46 | 只看該作者
檢查一下仿真的電路有沒有連錯
ID:1041416 發(fā)表于 2023-11-20 19:55 | 只看該作者
試了,不行啊
ID:1138038 發(fā)表于 2024-11-29 17:20 | 只看該作者
可不以用在DHT11控制步進(jìn)電機(jī)上
ID:1138038 發(fā)表于 2024-11-29 17:21 | 只看該作者
實(shí)物可以顯示溫度但是仿真顯示不出來,是不是參數(shù)設(shè)置問題
ID:583948 發(fā)表于 2024-12-2 09:11 | 只看該作者
可以先排除一下硬件是否一致,仿真和實(shí)物還是有差距的。其次把溫濕度傳感器拔了,看看能否顯示。最后在主循環(huán)里只寫顯示函數(shù),比如顯示數(shù)字什么的。這樣會很快排查到問題在哪。
