void press(uchar *s)
nn: P3=0xf0; //保存個位
while(P3==0xf0)
get_weight();//得到重量
if(weight>0)
{weight_shuzhi(weight);}//顯示重量
{weight_shuzhi(-weight);}
dat=get_key();
if(dat>=0&&dat<10)
*s=dat;
price_shuzhi(1,dat+0x30);//顯示單價
s++;
if(dat==16) //去皮
{qi_weight=weight+qi_weight;goto nn;}
if(dat==15) //置零
zero();
goto="goto" nn;
mm: p3="0xf0;" //保存十位
while(P3==0xf0)
get_weight();//得到重量
if(weight>0)
dat=get_key();
if(dat>=0&&dat<10)
*s=dat;
price_shuzhi(2,dat+0x30);//顯示單價
s++;
if(dat==16) //去皮
{s--;*s=0;price_shuzhi(1,' ');goto nn;}
if(dat==12) //清除
{price_shuzhi(1,' ');goto nn;}
if(dat==15) //置零
zero();
goto="goto" nn;
zz: p3="0xf0;" //保存百位
while(P3==0xf0)
get_weight();//得到重量
if(weight>0)
dat=get_key();
if(dat>=0&&dat<10)
*s=dat;
price_shuzhi(4,dat+0x30);//顯示
if(dat==12) //清除
s--;*s=0;price_shuzhi(2,' ');goto mm;}
if(dat==16) //去皮
{qi_weight=weight+qi_weight;goto zz;}
if(dat==15) //置零
zero();
goto="goto" nn;
xx:
do{
p3="0xf0;" //清除百位
while(P3==0xf0)
get_weight();//得到重量
if(weight>0)
dat=get_key();
if(dat==16) //去皮
{qi_weight=weight+qi_weight;goto xx;}
if(dat==12) //清除
{*s=0;price_shuzhi(4,' ');goto zz;}
if(dat==15) //置零
zero();
goto nn;
}while(dat!=14);
uchar pricetable[3]={0,0,0}為全局數組;
最后在主函數中調用press(pricetable)
請問鍵值賦值到pricetable中沒?
jianzhi=(uint)((pricetable[0]*100)+(pricetable[1]*10)+pricetable[2]);
我希望得到jianzhi;
