查看: 1788|回復: 0
AT89c51單片機設計8路搶答器
ID:718099 發表于 2020-3-29 13:39 | 顯示全部樓層 |閱讀模式
源程序如下
#include<at89x51.h>
sbit k1=P1^7;
unsigned char code disp_code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x00,0x40};
uchar biaozhi,xuanshou,s,z,z1,tiaoshi,bianliang1,bianliang2;
signed char time[]={0,0};
void delay(uint x)           //延時函數
uint i,j;
for(i=x;i>0;i--)
for(j=125;j>0;j--);
void xianshi()        //顯示函數
P3_6=1;
P3_0=0;
P3_7=1;
P0=disp_code[xuanshou];
delay(5);
if(xuanshou!=10)
P3_0=1;
P3_6=0;
P3_7=1;
P0=disp_code[time[0]/10];
delay(5);
P3_0=1;
P3_6=1;
P3_7=0;
P0=disp_code[time[0]%10];
delay(5);
if(tiaoshi==1)
P3_0=1;
P3_6=0;
P3_7=1;
P0=disp_code[time[1]/10];
delay(5);
P3_0=1;
P3_6=1;
P3_7=0;
P0=disp_code[time[1]%10];
delay(5);
P3_0=1;
P3_6=1;
P3_7=1;
void anjian()                //按鍵的識別和代碼的輸出
if(biaozhi==1)
if(P2!=0xff)
if(P2_0==0)
xuanshou=1;
if(P2_1==0)
xuanshou=2;
if(P2_2==0)
xuanshou=3;
if(P2_3==0)
xuanshou=4;
if(P2_4==0)
xuanshou=5;
if(P2_5==0)
xuanshou=6;
if(P2_6==0)
xuanshou=7;
if(P2_7==0)
xuanshou=8;
s=0;
time[0]=bianliang2;
biaozhi=2;
if(biaozhi==0)
if(P2!=0xff)
TR1=1;
void int1(void) interrupt 3                //蜂鳴器驅動函數的設計
k1=0;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
z++;
if(z==5)
z=0;
z1++;
k1=~k1;
if(z1==3)
k1=1;
z1=0;
TR1=0;
biaozhi=0;
xuanshou=10;
void int4(void) interrupt 0        //調節搶答時間函數
biaozhi=3;
tiaoshi=0;
xuanshou=12;
time[0]++;
bianliang1=time[0];
void int5(void) interrupt 2        //調節做題時間函數
tiaoshi=1;
biaozhi=3;
xuanshou=10;
time[1]++;
bianliang2=time[1];
void int0(void) interrupt 1                //中斷遞增
s++;
if(s==20)
s=0;
time[0]--;
if(time[0]==0)
time[0]=0;
TR0=0;
TR1=1;
void main()//主函數
IT0=1;        //開啟外部中斷0和1,用來控制強大時間和做題時間
EX0=1;
IT1=1;
EX1=1;
TMOD=0x11;        //定時中斷的初始化
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
TF1=0;
ET1=1;
TF0=0;
EA=1;
ET0=1;
xuanshou=10;        //xuanshou=10 是讓其顯示“--”
P2=0xff;
P1_7=1;
while(1)        //死循環
if(biaozhi!=3)        //判斷主持開始搶答鍵是否按下
if(P3_1==0)
delay(2);
if(P3_1==0)
time[0]=bianliang1;                //把調節好的搶答時間代入顯示time[0]
TR0=1;
biaozhi=1;
xuanshou=11;
if(P1_2==0)                  //判斷是否按下調節時間 的確定按鈕
delay(2);
if(P1_2==0)
TR0=0;
TR1=0;
biaozhi=0;
tiaoshi=0;
xuanshou=10;
if(P1_4==0)
delay(150);
if(P1_4==0)
biaozhi=3;
tiaoshi=0;
xuanshou=12;
time[0]--;
if(time[0]<=0)
time[0]=0;
if(P1_5==0)
delay(150);
if(P1_5==0)
tiaoshi=1;
biaozhi=3;
xuanshou=10;
time[1]--;
if(time[1]<=0)
time[1]=0;
anjian();
xianshi();
文檔.doc
932.71 KB, 下載次數: 5, 下載積分: 黑幣 -5
