查看: 11432|回復: 11
基于stm32f103c8t6的ADC多通道DMA電壓采集
ID:487316 發表于 2020-3-27 17:30 | 顯示全部樓層 |閱讀模式
本帖最后由 491621 于 2020-3-30 14:16 編輯
單一的電壓采集簡單容易實現
從原理圖可得stm32f103有十個通道:壓縮包有注釋
  1. #include "adc.h"
  2. __IO uint16_t ADC_ConvertedValue[NOFCHANEL] = {0,0,0,0,0,0};
  3. static void ADCx_GPIO_Config(void)
  4. {
  5.         GPIO_InitTypeDef GPIO_InitStructure;
  6.         RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOA, ENABLE );
  7.         GPIO_InitStructure.GPIO_Pin =         ADC_PIN1|ADC_PIN2|ADC_PIN3|ADC_PIN4|ADC_PIN5|ADC_PIN6;
  8.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  9.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  10. }
  11. static void ADC_GPIO_Config(void)
  12. {
  13.         DMA_InitTypeDef DMA_InitStructure;
  14.         ADC_InitTypeDef ADC_InitStructure;
  15.
  16.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  17.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_ADC1,ENABLE);
  18.
  19.         DMA_DeInit( DMA1_Channel1);
  20.         DMA_InitStructure.DMA_PeripheralBaseAddr = ( uint32_t ) ( & ( ADC_x->DR ) );
  21.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_ConvertedValue;
  22.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  23.         DMA_InitStructure.DMA_BufferSize = NOFCHANEL;
  24.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  25.         DMA_InitStructure.DMA_MemoryInc =DMA_MemoryInc_Enable ;
  26.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  27.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  28.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  29.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  30.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  31.         DMA_Init( DMA1_Channel1, &DMA_InitStructure);
  32.         DMA_Cmd( DMA1_Channel1 , ENABLE);
  33.
  34.
  35. /*-----------------------------------------------------------------*/
  36.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  37.         ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  38.         ADC_InitStructure.ADC_ContinuousConvMode =  ENABLE;
  39.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None ;
  40.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  41.         ADC_InitStructure.ADC_NbrOfChannel = NOFCHANEL        ;
  42.         ADC_Init(ADC_x, &ADC_InitStructure);
  43.
  44.         RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  45.
  46.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL1, 1, ADC_SampleTime_55Cycles5);
  47.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL2, 2, ADC_SampleTime_55Cycles5);
  48.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL3, 3, ADC_SampleTime_55Cycles5);
  49.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL4, 4, ADC_SampleTime_55Cycles5);
  50.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL5, 5, ADC_SampleTime_55Cycles5);
  51.         ADC_RegularChannelConfig(ADC_x, ADC_CHANNEL6, 6, ADC_SampleTime_55Cycles5);
  52.
  53.
  54.         ADC_DMACmd(ADC_x, ENABLE);
  55.         ADC_Cmd(ADC_x,ENABLE );
  56.
  57.
  58.         ADC_ResetCalibration(ADC_x);
  59.         while(ADC_GetResetCalibrationStatus(ADC_x));
  60.         ADC_StartCalibration(ADC_x);
  61.         while(ADC_GetCalibrationStatus(ADC_x));
  62.         ADC_SoftwareStartConvCmd(ADC_x, ENABLE);
  63. }
  64. void ADCx_Init(void)
  65. {
  66.         ADC_GPIO_Config();
  67.         ADCx_GPIO_Config();
  68. }
STM32F103C8T6最小系統原理圖.pdf
615.14 KB, 下載次數: 220, 下載積分: 黑幣 -5
ADC多通道DMA讀取.rar
307.85 KB, 下載次數: 507, 下載積分: 黑幣 -5
參與人數 1黑幣 +30 收起 理由
咸魚王哈哈 + 30 絕世好帖!
ID:487316 發表于 2020-3-30 14:14 | 顯示全部樓層
C8T6 ADC單通道中斷讀取.7z (186.65 KB, 下載次數: 83)
ID:487316 發表于 2020-3-30 14:15 | 顯示全部樓層
C8T6 ADC12規則同步.7z (187.4 KB, 下載次數: 76)
ID:825544 發表于 2020-12-5 16:38 | 顯示全部樓層
怎么丟失了開發環境的文件
ID:835973 發表于 2020-12-8 22:53 來自觸屏版 | 顯示全部樓層
你們可以去洋桃學習啊里面的庫都整理好了
ID:602882 發表于 2021-4-25 10:35 | 顯示全部樓層
很好的資料,正在設計多路溫度采集使用DMA傳輸數據,看過樓主的代碼,有些東西好像明白了。謝謝!
ID:857698 發表于 2021-11-5 12:54 | 顯示全部樓層
很棒的資料,幫了大忙,謝謝!
ID:294361 發表于 2022-3-9 15:46 | 顯示全部樓層
很棒的資料,幫了大忙,謝謝!
ID:961184 發表于 2022-3-22 11:32 | 顯示全部樓層
寫的很棒,幫大忙了
ID:147106 發表于 2022-11-11 08:12 | 顯示全部樓層
有鋰電池保護板的案例嗎
ID:788390 發表于 2022-11-24 17:16 | 顯示全部樓層
借鑒路過
ID:282650 發表于 2023-2-7 10:07 | 顯示全部樓層
不過還得做個數據濾波,不然抖動太厲害
