查看: 2645|回復: 4
單片機1602顯示電子時鐘Proteus仿真程序
ID:716109 發表于 2020-3-26 12:03 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit LCD_RS = P2^0;
  5. sbit LCD_RW = P2^1;
  6. sbit LCD_EN = P2^2;
  7. sbit LED = P2^4;
  8. bit new_s=0, g = 0,k=0;
  9. char t0, sec = 00, min = 00, hour = 00;
  10. char code LCD_line1[] = "GOOD MORNING!";
  11. char code LCD_line2[] = "Timer: 00:00:00 ";
  12. char Timer_buf[] = "00:00:00";
  13. void delay(uint z)//延時
  14. {
  15.     uint  x, y;
  16.     for(x = z; x > 0; x--)
  17.                 for(y = 100; y > 0; y--);
  18. }
  19. void W_LCD_Com(uchar com)   //寫指令
  20. {
  21.     LCD_RS = 0;
  22.                 LCD_RW = 0;
  23.                 P3 = com;
  24.     LCD_EN = 1;
  25.                 delay(5);
  26.                 LCD_EN = 0;
  27. }
  28. void W_LCD_Dat(uchar dat)//寫數據
  29. {
  30.     LCD_RS = 1;
  31.         LCD_RW = 0;
  32.         P3 = dat;
  33.     LCD_EN = 1;
  34.         delay(5);
  35.         LCD_EN = 0;
  36. }
  37. void W_LCD_STR(uchar *s)  //寫字符
  38. {
  39.     while(*s)  W_LCD_Dat(*s++);
  40. }
  41. void W_BUFF(void) //顯示
  42. {
  43.                 Timer_buf[0] = hour / 10 + 48;
  44.                 Timer_buf[1] = hour % 10 + 48;
  45.                 Timer_buf[3] = min / 10 + 48;
  46.                 Timer_buf[4] = min % 10 + 48;
  47.                 Timer_buf[6] = sec / 10 + 48;
  48.                    Timer_buf[7] = sec % 10 + 48;
  49.                    W_LCD_Com(0xc0 + 7);
  50.                 W_LCD_STR(Timer_buf);
  51. }
  52. uchar read_key(void)//掃描按鍵
  53. {
  54.     uchar  x1, x2;
  55.     P1 = 255;
  56.     x1 = P1;
  57.     if (x1 != 255) {
  58.       delay(100);
  59.       x2 = P1;
  60.       if (x1 != x2)
  61.         return 255;
  62.       while(x2 != 255)
  63.         x2 = P1;
  64.       if      (x1 == 0xfe)  return 0;
  65.       else if (x1 == 0xfb)  return 1;
  66.       else if (x1 == 0xfd)  return 2;
  67.       else if (x1 == 0xf7)  return 3;
  68.       else if (x1 == 0xef)  return 4;
  69. else if(x1==0xdf)return 5;
  70.     }
  71.     return 255;
  72. }
  73. void Init()
  74. {
  75.     LCD_RW = 0;
  76.     W_LCD_Com(0x38); //顯示模式
  77.                 delay(50);
  78.
  79.                 W_LCD_Com(0x0c);
  80.     W_LCD_Com(0x06);//顯示光標移動位置
  81.     W_LCD_Com(0x01);//清屏
  82.     W_LCD_Com(0x80);//第一行
  83.                 W_LCD_STR(LCD_line1);
  84.     W_LCD_Com(0xC0);//第二行
  85.                 W_LCD_STR(LCD_line2);
  86.     TMOD = 0x01;   //T0定時方式1
  87.     TH0 = 0x3c;
  88.         TL0= 0xB0;
  89.     TR0 = 1;
  90.     ET0 = 1;
  91.     EA = 1;
  92. }
  93. void CountDown()
  94. {
  95.   if (k)
  96. while(!(sec==0&&min==0&&hour==0))
  97. {
  98.          if(new_s==1)
  99.         {
  100.            sec--;
  101.            new_s=0;
  102.            sec %=60;
  103.            if(sec<0)
  104.                    sec=58-sec;
  105.         if(sec==59)
  106.                 {
  107.                         min--;  min %=60;
  108.                         if(min<0&&hour!=0&&hour>0)
  109.                                 min=58-min;
  110.                   if(min==59)
  111.                           {
  112.                                   hour--; hour %= 24;
  113.
  114.                           }
  115.
  116.            }
  117.
  118.
  119.         W_BUFF();
  120.       }
  121.           }
  122.           k=0;
  123. }
  124. void main()
  125. {
  126.     uint i, j;
  127.     uchar Key;
  128.     Init();
  129.     while(1)
  130.         {
  131.       if (new_s)
  132.            {
  133.             new_s=0;sec++;  sec %= 60;
  134.         if(!sec)
  135.                 {
  136.                 min++;  min %= 60;
  137.           if(!min)
  138.                   { hour++; hour %= 24;}
  139.
  140.            }
  141.
  142.
  143.         W_BUFF();
  144.       }
  145.           Key = read_key();
  146.       switch(Key) {
  147.       case  0: g = 1; break;
  148.       case  1: if(g) {min++;  min %= 60;  W_BUFF(); break;}
  149.       case  2: if(g) {hour++; hour %= 24; W_BUFF(); break;}
  150.       case  3: g = 0; break;
  151.                 case 4:k=1;CountDown();break;
  152.     }
  153.
  154.                 }
  155. }
  156. void timer0(void) interrupt 1
  157. {
  158.                 TH0 = 0x3c;
  159.                 TL0= 0xB0;
  160.     t0++; t0 %= 20;  //20次
  161.     if(t0 == 0){new_s = 1; LED = ~LED;}
  162.     if(g)  LED = 0;
  163.
  164.
  165. }
電子時鐘.zip (72.96 KB, 下載次數: 59)
一、 項目要求
1. 能用LED顯示時間,以“時:分:秒”的形式;2. 能通過撥動按鍵達到調時的目的;3. 能實現倒計時功能。二、 項目開發環境1. 硬件環境:Windows 102. 軟件環境:Protues 8.6              Keil uVision4三、 項目分析1. 顯示時間使用的LED可以使用LM016L,時間顯示的原理可以使用定時器,定時器定時滿1S,秒加1,判斷秒大于59時,分加1,并且秒清0;判斷分大于59時,時加1,并且分清0;判斷時大于23時,時清0。主程序流程圖:3. 倒計時設計當時間設定完成后,從當前時間開始倒計時,當秒小于0時,分減1,秒置59,當分小于0時,時減1,分置59,當時小于0時,從00:00:00開始正計時。四、 設計與實現1. 設計思路1) 首先要將時間顯示部分的邏輯原理理清楚并畫出仿真圖,考慮按鍵進去,并寫出時間顯示部分的核心代碼;2) 將按鍵的各個功能理清楚,以及按鍵控制的邏輯思路,編寫出完整的代碼,并進行仿真。3) 考慮增添倒計時功能,在原有的基礎上增加一個按鍵,修改仿真圖,并編寫倒計時函數代碼,最后仿真調試。2. 設計和實現的主要內容1) 設計實現一個以“時:分:秒”形式顯示的電子時鐘,使用4個按鍵實現:開始計時,設置時,設置秒,完成時間設置功能,最后增添按鍵實現倒計時功能。
五、 總結
本次課程設計仿真電子時鐘,相對來說,電路比較簡單,沒有那么復雜,仿真圖中需要注意的LM016L這個LED顯示器件的工作原理,LM016L是1602的一種,它是以ASCII碼為編碼方式,不注意的話,可能會造成亂碼。LM016L在寫入顯示地址時要求最高位D7恒定為高電平1,所以實際寫入的數據應該加上80H,它在顯示字符時光標自動右移,無須人工干預,它的VL為液晶顯示器對比度調整端,我們在仿真中為它接入一個滑動變阻器。對于本次課程設計,其重點在與理清其中的邏輯思路,再來編寫代碼,使得整個課程設計條理清晰。
本次課程設計讓我對本學期所學的單片機是識進行了一次整合,對AT89C51單片機的認識更加的清晰明了。讓我對單片機有關的硬件設計產生了濃厚的興趣,特別時有關定時計數器的部分。
本次設計使用了Keil uVision4和Proteus 8 Professional軟件,讓我對這兩個軟件的運用更加熟練,更加得心應手。讓我認識到了自己本身的不足以及問題解決的方法,讓我認識到了實踐與理論結合的重要性。
ID:573789 發表于 2020-6-9 15:23 | 顯示全部樓層
牛逼頂
ID:723220 發表于 2020-8-30 10:13 | 顯示全部樓層
能不能發一下只有四個按鈕和排阻只有8個引腳的程序
ID:723220 發表于 2020-9-1 10:53 | 顯示全部樓層
為什么會突然卡退,程序到最后算是寫完了嗎?
ID:723220 發表于 2020-9-5 20:15 | 顯示全部樓層
在嗎,可不可以回復一下,程序運行卡退怎么修改
