#include <stc15f2k60s2.h>
#include <I2C.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
sbit S5 = P3^2;
sbit S4 = P3^3;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char code dat_led[4][8] = {
{0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}, //模式1
{0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE}, //模式2
{0x7E,0xBD,0xDB,0xE7}, //模式3
{0xE7,0xDB,0xBD,0x7E} //模式4
unsigned char mode=0,site=0; //mode控制流水燈模式,site控制流水燈的位置
unsigned int time_led = 400;//LED流轉(zhuǎn)間隔
unsigned char pwn_duty = 0;//脈沖寬度
unsigned char grade_led = 1;//LED亮度等級
unsigned char s6_set = 0;
bit s4_set = 0; //在非設(shè)置狀態(tài)下按下S4可以顯示LED的亮度等級
unsigned char dat_rb2 = 0;
void InitSystem();
void ScanKeys();
void ConfigSMG();
void Read_Rb2();
void LED();
void Timer0Init(void); //1毫秒@12.000MHz
unsigned char I2CRead(unsigned char addr);
void I2CWrite(unsigned char addr,unsigned char dat);
InitSystem();
Timer0Init();
mode = I2CRead(0x01);
time_led = I2CRead(0x08)*10;
ConfigSMG();
Read_Rb2();
LED();
ScanKeys();
void SelectHC573(unsigned char chane)
switch(chane)
case 4:P2 = (P2&0x1F)|0x80;break;
case 5:P2 = (P2&0x1F)|0xA0;break;
case 6:P2 = (P2&0x1F)|0xC0;break;
case 7:P2 = (P2&0x1F)|0xE0;break;
default:P2 = (P2&0x1F)|0x00;break;
/*******關(guān)閉LED和蜂鳴器、繼電器******/
void InitSystem()
SelectHC573(5);
P0 = 0x00;
SelectHC573(4);
P0 = 0xFF;
SelectHC573(0);
/******數(shù)碼管顯示函數(shù)******/
void ConfigSMG()
if(s6_set>0)
LedBuff[0] = LedChar[16];
LedBuff[1] = LedChar[mode];
LedBuff[2] = LedChar[16];
LedBuff[3] = 0xFF;
if(time_led>=1000)
LedBuff[4] = LedChar[time_led/1000];
LedBuff[5] = LedChar[time_led/100%10];
LedBuff[6] = LedChar[time_led/10%10];
LedBuff[7] = LedChar[time_led%10];
LedBuff[4] = 0xFF;
LedBuff[5] = LedChar[time_led/100];
LedBuff[0] = 0xFF;
LedBuff[1] = 0xFF;
LedBuff[2] = 0xFF;
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = 0xFF;
LedBuff[6] = 0xFF;
LedBuff[7] = 0xFF;
if(s4_set)
LedBuff[0] = 0xFF;
LedBuff[1] = 0xFF;
LedBuff[2] = 0xFF;
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = 0xFF;
LedBuff[6] = LedChar[16];
LedBuff[7] = LedChar[grade_led];
/******EEPROM相關(guān)函數(shù)********/
I2CStart();
I2CSendByte(0xA0);
I2CWaitACK();
I2CSendByte(addr);
I2CWaitACK();
I2CSendByte(dat);
I2CWaitACK();
I2CStop();
unsigned char dat;
I2CStart();
I2CSendByte(0xA0);
I2CWaitACK();
I2CSendByte(addr);
I2CWaitACK();
I2CStart();
I2CSendByte(0xA1);
I2CWaitACK();
dat = I2CRecByte();
I2C_ACK(0);
I2CStop();
return dat;
/******PCF8591數(shù)據(jù)采集*******/
void Read_Rb2()
I2CStart();
I2CSendByte(0x90);
I2CWaitACK();
I2CSendByte(0x03);
I2CWaitACK();
I2CStop();
I2CStart();
I2CSendByte(0x91);
I2CWaitACK();
dat_rb2 = I2CRecByte();
I2C_ACK(0);
I2CStop();
/******LED亮度控制函數(shù)******/
void LED()
if(dat_rb2<60)
pwn_duty = 5;
grade_led = 1;
else if(dat_rb2<120)
pwn_duty = 10;
grade_led = 2;
else if(dat_rb2<180)
pwn_duty = 15;
grade_led = 3;
pwn_duty = 20;
grade_led = 4;
/********按鍵掃描與處理邏輯*********/
void Delay1ms() //@12.000MHz
unsigned char i;
i = 1000;
while(i--);
void ScanKeys()
/*****按鍵S7*****/
if(S7==0)
Delay1ms();
if(S7==0)
if(TR0==0)
TR0 = 1;
s6_set = 0;
TR0 = 0;
while(S7==0);
/******按鍵S6*****/
if(S6==0)
Delay1ms();
if(S6==0)
s6_set++;
if(s6_set==2)
I2CWrite(0x01,mode);
Delay1ms();
else if(s6_set>=3)
s6_set = 0;
I2CWrite(0x08,time_led/10);
Delay1ms();
while(S6==0);
/*****按鍵S5*****/
if(S5==0)
Delay1ms();
if(S5==0)
if(s6_set==2)
time_led = time_led+100;
if(time_led>=1200)
time_led = 1200;
else if(s6_set==1)
mode++;
if(mode>=4)
mode = 4;
while(S5==0);
/******按鍵S4*****/
if(S4==0)
Delay1ms();
if(S4==0)
if(s6_set==2)
time_led = time_led-100;
if(time_led<400)
time_led = 400;
else if(s6_set==1)
mode--;
if(mode<=1)
mode = 1;
s4_set = ~s4_set;
while(S4==0);
/*******數(shù)碼管刷新*******/
void ScanSMG()
static unsigned char i = 0;
P0 = 0xFF;
SelectHC573(6);
P0 = 0x01<<i;
SelectHC573(7);
P0 = LedBuff[i++];
if(i>=8)
i = 0;
/****配置定時器0****/
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0x18; //設(shè)置定時初值
TH0 = 0xFC; //設(shè)置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0 = 1;
EA = 1;
void InterruptTimer0() interrupt 1 //定時器服務(wù)函數(shù)
static unsigned int cnt = 0;
static unsigned char PWN = 0;
ScanSMG();
PWN++;
cnt++;
if(PWN<=pwn_duty) //控制LED的亮度大小
SelectHC573(4);
P0 = dat_led[mode-1][site];
else if(PWN<20)
SelectHC573(4);
P0 = 0xFF;
SelectHC573(4);
PWN = 0;
if(cnt>=time_led) //控制LED的流轉(zhuǎn)間隔
SelectHC573(4);
cnt = 0;
site++;
if(mode<=2)
if(site>=8)
site = 0;
if(site>=4)
site = 0;
第9屆彩燈控制器_1.rar
2020-3-24 18:07 上傳
下載積分: 黑幣 -5
44.89 KB, 下載次數(shù): 20, 下載積分: 黑幣 -5
省賽試題-第9屆-彩燈控制器.pdf
2020-3-24 18:07 上傳
下載積分: 黑幣 -5
283.36 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
