查看: 2294|回復(fù): 2
單片機(jī)萬年歷,希望能在我寫的程序的基礎(chǔ)上修改 //STC89C52 LED1602
ID:709387 發(fā)表于 2020-3-21 18:26 | 顯示全部樓層 |閱讀模式
10黑幣
能顯示星期,顯示在右上角,并且能修改它;現(xiàn)在情況是用按鍵修改鬧鐘后,時間到了,卻不會響;很煩這個;還有就是希望能間歇響蜂鳴器,現(xiàn)在是長響;話不多說,各位大佬請看程序:
# include <reg52.h>
#define  uchar unsigned char
#define  uint  unsigned int                //宏定義
        腳位定義
sbit rs = P3^5;               //寫命令/數(shù)據(jù)端
sbit en = P3^4;               //使能
sbit rw = P3^6;               //led1602讀命令/數(shù)據(jù)端
sbit we = P2^7;               //數(shù)碼管位選
sbit du = P2^7;               //數(shù)碼管段選
sbit S2 = P3^0;
sbit S3 = P3^1;
sbit S4 = P3^2;
sbit S5 = P3^3;               //獨(dú)立鍵盤四個按鍵腳位
sbit fm = P2^3;               //蜂鳴器腳位
uchar count, S2num;    //定時器,修改按鍵次數(shù),
uchar hour = 7,        //時
       min = 59,       //分
       sec = 55;           //秒         時間
uint nian = 2020,      //年
       yue = 3,        //月
        ri = 19;       //日                日期
uchar clock,
     hour1 = 8,        //時
      min1 = 0;               //分         鬧鐘
//                  星期一↓ 二↓ 三↓ 四↓ 五↓ 六↓ 日↓
uchar X[] = {"MON,TUE,MED,THU,FRI,SAT,SUN"};//星期循環(huán)
uchar code table[] =  "2020-03-19";                    //注意:修改這里必須先修改↑ uchar ↑,↓↓↓↓
uchar code table1[] = "07:59:55  C08:00";   //       否則,時間不會跟著這里走
                        延時函數(shù)
void delay(uint z)//長延時函數(shù)
        uint x, y;
        for(x = z; x > 0;x --)
        for (y = 110; y > 0; y --);
                        寫命令函數(shù)
void write_com(uchar com)
        rs = 0;
        P0 = com;
        delay(5);
        en = 1;
        delay(5);
        en = 0;
                     寫數(shù)據(jù)函數(shù)
void write_dat(uchar dat)
        rs = 1;
        P0 = dat;
        delay(5);
        en = 1;
        delay(5);
        en = 0;
                         初始化函數(shù)
void init()
        uchar num;
        rw =0;
        en = 0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        for(num = 0; num < 10; num ++)
        write_dat(table[num]);
        write_com(0x80 + 0x40);
        for(num = 0; num < 16; num ++)
        write_dat(table1[num]);
        TMOD = 0x01;
        TH0 = (65536 - 50000) / 256;     //裝定時器初值
        TL0 = (65536 - 50000) % 256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
                          定時器函數(shù)
void timer0() interrupt 1
        TH0 = (65536 - 50000) / 256;//再次裝定時器初值
        count ++;
                          時分秒 + 鬧鐘函數(shù)
void write_sfm(uchar add, uchar date)
        uchar shi, ge;
        shi = date / 10;
        ge = date % 10;
        write_com(0x80 + 0x40 + add);  //時間 / 鬧鐘顯示的位置
        write_dat(0x30 + shi);
        write_dat(0x30 + ge);
                           年月日函數(shù)
void write_nyr(uint add, uint date)
{                                           //這里不能用uchar,uchar數(shù)字最多只有255,顯示不全年份
        uint qian, bai, shi, ge;
        qian = date / 1000;
        bai = date % 1000 / 100;
        shi = date % 100 / 10;
        ge = date % 10;
        write_com(0x80 + add);
        if (add == 0)                                    //年顯示的位置
                write_dat(0x30 + qian);
                write_dat(0x30 + bai);
        if(add == 5)                                        //月顯示的位置
        if(add == 8)                                    //日顯示的位置
                          星期函數(shù)
void write_xq(uchar add, uchar date)
        uchar ge;
        ge = date % 10;
        write_com(0x80 + add);                  //星期顯示的位置
                日期時間自加函數(shù) + 插入的鬧鐘函數(shù)
void write_shijian()
        if(count == 20)                    //定時1秒
                count = 0;
                sec ++;
                if(sec == 60)
                        sec = 0;
                        min ++;
                        if(min == 60)
                                min = 0;
                                hour ++;
/*******↓*****↓*****插入鬧鐘*****↓*****↓*******/
                                if(hour == hour1 & min == min1)         //當(dāng)時間‘時’‘分’==鬧鐘‘時’‘分’時,蜂鳴器打開
                                        fm = 0;                                                 //fm = 0時,蜂鳴器打開,fm = 1時,蜂鳴器關(guān)閉
                                if(hour == 24)
                                        hour = 0;
                                        ri ++;
                                        if(ri == 31)
                                                ri = 1;
                                                yue ++;
                                                if(yue == 13)
                                                        yue = 1;
                                                        nian ++;
                                                        if(nian == 2100)
        nian = 0;
        yue = 0;
        ri = 0;
        hour = 0;
        min = 0;
        sec = 0;
                                                        write_nyr(0, nian);//年份送回LED屏幕顯示
                                                write_nyr(5, yue);         //月份送回LED屏幕顯示
                                        write_nyr(8, ri);     //天數(shù)送回LED屏幕顯示
                                write_sfm(0, hour);           //小時送回LED屏幕顯示
                        write_sfm(3, min);                //分鐘送回LED屏幕顯示
                write_sfm(6, sec);                  //秒送回LED屏幕顯示
/*****************函數(shù)聲明********************/
void Key();
                           主函數(shù)
        init();
        Key();                         //插入按鍵函數(shù)
        write_shijian();
                                  按鍵函數(shù)
void Key()
/***************插入停止鬧鐘按鍵設(shè)置************/
        if(fm == 0)                        //鬧鐘是撿來的,到處插入^_^
                if(S5 == 0)
                        delay(5);
                        if(S5 == 0)
                        fm = 1;
/***********修改日期 + 時間 + 鬧鐘按鍵設(shè)置************/
        if(S2 == 0)                                                //按下修改按鍵
                delay(25);                                         //軟件消抖
                if(S2 == 0)                                        //確認(rèn)按下
                         S2num ++;                                //按鍵次數(shù)增加
                        while(!S2);                                //松開按鍵
                        TR0 = 0;                                //關(guān)閉定時器
                        write_com(0x0f);                //打開光標(biāo)且閃爍
                        if(S2num == 1)
                                write_com(0x80 + 0x40 + 7);        //修改時間秒針數(shù)
                        if(S2num == 2)
                                write_com(0x80 + 0x40 + 4);        //修改時間分鐘數(shù)
                        if(S2num == 3)
                                write_com(0x80 + 0x40 + 1);        //修改時間小時數(shù)
                        if(S2num == 4)
                                write_com(0x80 + 0X40 + 12);//修改鬧鐘小時數(shù)
                        if(S2num == 5)
                                write_com(0x80 + 0X40 + 15);//修改鬧鐘分鐘份
                        if(S2num == 6)
                                write_com(0x80 + 3);                //修改日期年份
                        if(S2num == 7)
                                write_com(0x80 + 6);                //修改日期月份
                        if(S2num == 8)
                                write_com(0x80 + 9);                //修改日期天數(shù)
                        if(S2num == 9)
                                S2num = 0;                            //修改按鍵次數(shù)清零
                                write_com(0x0c);            //關(guān)閉光標(biāo)且停止閃爍
                                TR0 = 1;                            //打開定時器
/*************增加日期 + 時間 + 鬧鐘按鍵設(shè)置**************/
        if(S2num != 0)                                        //按下修改按鍵,取消修改、增加和減少按鍵才有效
                if(S5 == 0)                                        //取消修改按鍵(僅在S2按下有效)
                        delay(25);
                        if(S5 == 0)
                        TR0 = 1;                                //打開定時器
                if(S3 == 0)                                        //增加鍵按下
                        delay(25);                                  //軟件消抖
                        if(S3 == 0)
                                while(!S3);                        //確定按鍵按下
/********************時間*************************/
                                if(S2num == 1)
                                        sec ++;
                                        if(sec == 60)
                                        sec = 0;
                                        write_sfm(6, sec);
                                        write_com(0x80 + 0x40 + 7);           //秒
                                if(S2num == 2)
                                        min ++;
                                        if(min == 60)
                                        min = 0;
                                        write_sfm(3, min);
                                        write_com(0x80 + 0x40 + 4);            //分
                                if(S2num == 3)
                                        hour ++;
                                        if(hour == 24)
                                        hour = 0;
                                        write_sfm(0, hour);
                                        write_com(0x80 + 0x40 + 1);                 //時
/********************鬧鐘*************************/
                                if(S2num == 4)
                                        hour1 ++;
                                        if(hour1 == 24)
                                        hour1 = 0;
                                        write_sfm(11, hour1);
                                        write_com(0x80 + 0x40 + 12);         //時
                                if(S2num == 5)
                                        min1 ++;
                                        if(min1 == 60)
                                        min1 = 0;
                                        write_sfm(14, min1);
                                        write_com(0x80 + 0x40 + 15);         //分
/********************日期*************************/
                                if(S2num == 6)
                                        nian ++;
                                        if(nian == 2101)
                                        nian = 1999;
                                        write_nyr(0, nian);
                                        write_com(0x80 + 3);                      //年
                                if(S2num == 7)
                                        yue ++;
                                        if(yue == 13)
                                           yue = 1;
                                        write_nyr(5, yue);
                                        write_com(0x80 + 6);                      //月
                                if(S2num == 8)
                                        ri ++;
                                        if(ri == 31)
                                        ri = 1;
                                        write_nyr(8, ri);
                                        write_com(0x80 + 9);                       //日
/***********減少日期 + 時間 + 鬧鐘按鍵設(shè)置******************/
                 if(S4 == 0)                                               //減少鍵按下
                        delay(25);
                        if(S4 == 0)
                                while(!S4);                                        //確定按鍵按下
                                if(S2num == 1)
                                        sec --;
                                        if(sec == -1)
                                        sec = 59;
                                        write_sfm(6, sec);
                                if(S2num == 2)
                                        min --;
                                        if(min == -1)
                                        min = 59;
                                        write_sfm(3, min);
                                if(S2num == 3)
                                        hour --;
                                        if(hour == -1)
                                        hour = 23;
                                        write_sfm(0, hour);
                                if(S2num == 4)
                                        hour1 --;
                                        if(hour1 == -1)
                                        hour1 = 23;
                                if(S2num == 5)
                                        min1 --;
                                        if(min1 == -1)
                                        min1 = 59;
                                if(S2num == 6)
                                        nian --;
                                        if(nian == 1998)
                                        nian = 2100;
                                        write_nyr(0, nian);
                                if(S2num == 7)
                                        yue --;
                                        if(yue == 0)
                                        yue = 12;
                                        write_nyr(5, yue);
                                if(S2num == 8)
                                        ri --;
                                        if(ri == 0)
                                        ri = 30;
                                        write_nyr(8, ri);
ID:709387 發(fā)表于 2020-3-21 20:49 | 顯示全部樓層
呃,抱歉,沒說清楚,是現(xiàn)在不能顯示星期,想顯示星期,希望能有大神幫忙,
ID:709387 發(fā)表于 2020-4-28 09:00 | 顯示全部樓層
可能是我寫得代碼不容易看懂吧
