本帖最后由 1032405648 于 2020-3-20 17:32 編輯
仿真時數碼管亂碼不知道問題在哪,我用開發板可以達到想要效果
單片機程序;
#include<reg52.h>
unsigned long count;
sbit key1=P3^4;
sbit key2=P3^5;
sbit dula=P2^6;
sbit wela=P2^7;
uchar ge,shi,bai,qian,wan,sw;
void init();
void read_num(void);
void display(uchar ge,uchar shi,uchar bai,uchar qian ,uchar wan,uchar sw);
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
void delay(uint z)
uint x,y;
for(x=z;x>0;x--);
for(y=110;y>0;y--);
void read_num(void)
if (count>999999)
TH0=0x00;
TL0=0x00;
count=0;
ge=count%10;
shi=count%100/10;
bai=count%1000/100;
qian=count%10000/1000;
wan=count%100000/10000;
sw=count/100000;
P3=0xff;
P0=0xff;
P2=0xff;
init();
if(key1==0)
delay(10);
if (key1==0)
count++;
while(!key1);
delay(10);
while(!key1);
read_num();
display(ge,shi,bai,qian,wan,sw);
if(key2==0)
count=0;
dula=1;
P0=table[sw];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(1);
dula=1;
P0=table[wan];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(1);
dula=1;
P0=table[qian];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
wela=0;
delay(1);
dula=1;
P0=table[bai];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay(1);
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay(1);
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay(1);
void init()
TMOD=0x05;
TH0=0x00;
TL0=0;
TR0=1;
