查看: 1258|回復: 0
串口發送接收程序
ID:707653 發表于 2020-3-13 14:18 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
unsigned char DATA[]={0x49,0x20,0x61,0x6d,0x20,0x57,0x5a,0x48};
unsigned char g_uData_1[];
unsigned char g_uData;
sbit led_0=P1^0;
sbit led_1=P1^1;
sbit led_2=P1^2;
sbit led_3=P1^3;
sbit led_4=P1^4;
sbit led_5=P1^5;
sbit led_6=P1^6;
sbit led_7=P1^7;
sbit key_0=P3^4;
sbit key_1=P3^5;
sbit key_2=P3^6;
sbit key_3=P3^7;
void Delay(unsigned int n)
        while(n--);
void main(void)
          SCON=0x50;
                EA=1;
                ES=1;
                TMOD=0X20;                        //設置計數器工作方式2
                TH1=0XFd;                                //計數器初始值設置,注意波特率是4800的
                TL1=0XFd;
          TR1=1;
                                Delay(100);
void Rec_Data(void) interrupt 4
{        if(        SBUF==0x31)
                unsigned int i;
        g_uData = SBUF;
        for(i=0;i<8;i++)
                SBUF=DATA[i];
                while(!TI);
                TI=0;
                RI=0;
//        SBUF=g_uData;
//        while(!TI);
//        TI=0;
//        SBUF=0xa;
//        while(!TI);
//        TI=0;
串口接收發送.zip
33.38 KB, 下載次數: 3, 下載積分: 黑幣 -5
