//上電后按下K4鍵程序運行,小車進行超聲波避障跑
//LCD1602液晶屏上顯示探測到的實時距離
//重要說明:沒有LCD1602液晶顯示屏的師兄,需要用杜邦線將P0.7接地程序才能正常運行
//注意程序只做參考之用,要達到最理想的避障效果,還需要師兄們細心調試。
#include <reg52.h> //52芯片配置文件
#include <intrins.h> //包含nop等系統函數
#include "bst_car.h" //包含bst—v51智能小車頭文件
#define LCM_Data P0 //定義液晶屏數據口
#define Busy 0x80 //用于檢測LCM狀態字中的Busy標識
sbit DU = P2^6; //數碼管段選
sbit WE = P2^7; //數碼管位選
sbit LCM_RW=P1^1 ; //定義LCD引腳
sbit LCM_RS=P1^0 ;
sbit LCM_E=P2^5 ;
unsigned char code Range[] ="==Range Finder==";//LCD1602顯示格式
unsigned char code ASCII[13] = "0123456789.-M";
unsigned char code table[]="Distance:000.0cm";
unsigned char code table1[]="!!! Out of range";
unsigned char disbuff[4]={0,0,0,0};//用于分別存放距離的值0.1mm、mm、cm和m的值
unsigned int time=0;//用于存放定時器時間值
unsigned long S=0;//用于存放距離的值
bit flag =0; //量程溢出標志位
char a=0;
void delay(unsigned int xms)
unsigned int i,j;
for(i=xms;i>0;i--) //i=xms即延時約xms毫秒
for(j=112;j>0;j--);
void Delay10us(unsigned char i) //10us延時函數 啟動超聲波模塊時使用
unsigned char j;
do{
j = 10;
do{
_nop_();
}while(--j);
}while(--i);
void cmg88()//關數碼管
DU=1;
P0=0X00;
DU=0;
/************************************LCD1602液晶屏驅動函數************************************************/
//*******************讀狀態*************************//
unsigned char ReadStatusLCM(void)
LCM_Data = 0xFF;
LCM_RS = 0;
Delay10us(1);
LCM_RW = 1;
Delay10us(1);
do{
LCM_E = 0;
Delay10us(1);
LCM_E = 0;
Delay10us(1);
LCM_E = 1;
Delay10us(1);
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
/****************寫數據************************/
void WriteDataLCM(unsigned char WDLCM)
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
Delay10us(1);
LCM_RW = 0;
Delay10us(1);
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
Delay10us(1);
LCM_E = 0; //延時
Delay10us(1);
LCM_E = 1;
Delay10us(1);
//****************寫指令*************************//
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
Delay10us(1);
LCM_RW = 0;
Delay10us(1);
LCM_E = 0;
Delay10us(1);
LCM_E = 0;
Delay10us(1);
LCM_E = 1;
Delay10us(1);
//*******************LCM初始化**********************//
void LCMInit(void)
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
delay(5);
delay(5);
delay(5);
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(0x0c,1); // 顯示開及光標設置
//*********************按指定位置顯示一個字符***********************//
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
WriteCommandLCM(X, 1); //發命令字
WriteDataLCM(DData); //發數據
//**********************按指定位置顯示一串字符*************************//
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
unsigned char ListLength;
ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
if (X <= 0xF) //X坐標應小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
ListLength++;
X++;
void StartModule() //啟動超聲波模塊
TX=1; //啟動一次模塊
Delay10us(2);
TX=0;
void Forward(void)//前進
IN2=1;
IN3=1;
IN1=0;
IN4=0;
void Stop(void) //停車
IN1=0;
IN2=0;
IN3=0;
IN4=0;
void back(void) //后退
IN1=1;
IN2=0;
IN3=0;
IN4=1;
void Turn_Right(void) //向右旋轉
IN1=0;
IN2=1;
IN3=0;
IN4=1;
/********距離計算程序***************/
void conut1(void)
time=TH1*256+TL1;
TH1=0;
TL1=0;
//此時time的時間單位決定于晶振的頻率,外接晶振為11.0592MHZ
//那么1us聲波能走多遠的距離呢?1s=1000ms=1000000us
// 340/1000000=0.00034米
//0.00034米/1000=0.34毫米 也就是1us能走0.34毫米
//但是,我們現在計算的是從超聲波發射到反射接收的雙路程,
//所以我們將計算的結果除以2才是實際的路程
S=time*0.17+10;//此時計算到的結果為毫米,并且是精確到毫米的后兩位了,有兩個小數點
void Conut(void)
conut1();
//========顯示部分===========================================
if((S>=5000)||flag==1) //超出測量范圍
a=0;
flag=0;
DisplayListChar(0, 1, table1);
disbuff[0]=S%10;
disbuff[1]=S/10%10;
disbuff[2]=S/100%10;
disbuff[3]=S/1000;
DisplayListChar(0, 1, table);
DisplayOneChar(9, 1, ASCII[disbuff[3]]);
DisplayOneChar(10, 1, ASCII[disbuff[2]]);
DisplayOneChar(11, 1, ASCII[disbuff[1]]);
DisplayOneChar(12, 1, ASCII[10]);
DisplayOneChar(13, 1, ASCII[disbuff[0]]);
//========避障部分===========================================
if(S<=240) //////////////////////////// 剎車障礙物距離 跟車速有關 可更改
a++;
if(a>=2)
a=0;
FM=0;
Stop();
back(); //后退緩沖
delay(230);////////////////////////////////////////// 后退緩沖時間 跟車速有關 可更改
B:Turn_Right();
delay(50); /////////////////////////////////// 旋轉角度 跟環境復雜程度有關 可更改
Stop();
delay(100); //////////////////////////////////// 旋轉頓挫時間 視覺效果 可更改
StartModule();
while(RX==0);
TR1=1; //開啟計數
while(RX); //當RX為1計數并等待
TR1=0; //關閉計數
conut1();
if(S>340) //////////////////////// 可直行方向無障礙物距離 跟環境有關 可更改
Turn_Right();
delay(90);
Stop(); //微調前進方向 避免車寬對前進影響
delay(200);
FM=1;
Forward();
goto B; //若沒轉到空曠方向 回到B點 繼續旋轉一次
Forward(); //無障礙物 直行
a=0;
void zd0() interrupt 3 //T0中斷用來計數器溢出,超過測距范圍
flag=1; //中斷溢出標志
RX=0;
/********超聲波高電平脈沖寬度計算程序***************/
void Timer_Count(void)
TR1=1; //開啟計數
TR1=0; //關閉計數
Conut(); //計算
void keyscan(void) //按鍵掃描函數
A: if(K4==0) //判斷是否有按下信號
delay(10); //延時10ms
if(K4==0) //再次判斷是否按下
FM=0; //蜂鳴器響
while(K4==0); //判斷是否松開按鍵
FM=1; //蜂鳴器停止
goto A; //跳轉到A重新檢測
goto A; //跳轉到A重新檢測
/*************主程序********************/
void main(void)
unsigned int a;
cmg88();//關數碼管
delay(400); //啟動等待,等LCM講入工作狀態
LCMInit(); //LCM初始化
delay(5);//延時片刻
DisplayListChar(0, 0, Range);
TMOD=TMOD|0x10;//設T0為方式1,GATE=1;
EA=1; //開啟總中斷
TH1=0;
TL1=0;
ET1=1; //允許T0中斷
keyscan() ; //按鍵掃描
RX=1;
StartModule(); //啟動模塊
for(a=951;a>0;a--)
if(RX==1)
Timer_Count(); //超聲波高電平脈沖寬度計算函數
