經(jīng)實物實驗60顆全部點亮。多種顯示方式。
Arduino源程序如下:
- strip.setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b);
- 第一個參數(shù)n是彩帶中LED的編號,最接近單片機(jī)引腳的編號為0;接下來的三個參數(shù)描述像素顏色,分別表示紅色,綠色和藍(lán)色的亮度級別,0為最暗,255是最大亮度;
- strip.setPixelColor(uint16_t n, uint32_t c);
- n是彩帶中LED的編號,顏色color是一種32位類型,將紅色,綠色和藍(lán)色值合并為一個數(shù)字,有時這樣做能提高程序的效率.通過下面的方法,可以將紅色,綠色和藍(lán)色值轉(zhuǎn)換為32位類型。
- uint32_t magenta = strip.Color(red, green, blue);
- strip.setBrightness(uint8_t);
- 一般只在setup()中調(diào)用,以保證在整個程序執(zhí)行過程中LED顏色亮度的一致性,其實在程序中通過合適的邏輯控制各像素的亮度值可能動畫效果更好.
- strip.show();
- 該方法更新彩帶上的全部LED。一個好的習(xí)慣是先利用setPixelColor()設(shè)置好整個彩帶的顏色,然后再調(diào)用show()方法,以防止出現(xiàn)動畫跳躍而不平滑。
- #include <Adafruit_NeoPixel.h>
- #ifdef __AVR__
- #include <avr/power.h>
- #endif
- //int pinInterrupt = 2; //接中斷信號的腳
- //void onChange()
- // if ( digitalRead(pinInterrupt) == LOW )
- // Serial.println("Key Down");
- // else
- // Serial.println("Key UP");
- /******************************************key
- #define BUTTON 3
- int val=0;
- int old_val=0;
- int state=0;
- #define PIN 6
- // Parameter 1 = number of pixels in strip
- // Parameter 2 = Arduino pin number (most are valid)
- // Parameter 3 = pixel type flags, add together as needed:參數(shù) 3 = 像素類型標(biāo)志,根據(jù)需要添加在一起:
- // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
- // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
- // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
- // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
- // NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
- Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
- // IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
- // pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
- // and minimize distance between Arduino and first pixel. Avoid connecting
- // on a live circuit...if you must, connect GND first.
- // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
- void setup()
- #if defined (__AVR_ATtiny85__)
- if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
- #endif
- // End of trinket special code
- // Serial.begin(9600); //打開串口
- // pinMode( pinInterrupt, INPUT);//設(shè)置管腳為輸入
- //Enable中斷管腳, 中斷服務(wù)程序為onChange(), 監(jiān)視引腳變化
- //attachInterrupt( digitalPinToInterrupt(pinInterrupt), onChange, CHANGE);
- // pinMode(BUTTON,INPUT);//key
- strip.begin();
- strip.show(); // Initialize all pixels to 'off'
- void loop()
- /****************************************** key
- val = digitalRead(BUTTON);
- if((val==HIGH)&&(old_val==LOW))
- state=1-state;
- delay(10);
- old_val = val;
- if(state==1)
- // Some example procedures showing how to display to the pixels:顯示如何顯示到像素的一些示例過程:
- colorWipe(strip.Color(255, 0, 0), 50); // Red delay50
- colorWipe(strip.Color(0, 255, 0), 50); // Green
- colorWipe(strip.Color(0, 0, 225), 50); // Blue
- colorWipe(strip.Color(255, 0, 255), 50); // purple
- colorWipe(strip.Color(128, 0, 175), 50); // purple
- colorWipe(strip.Color(0, 128, 255), 50);
- colorWipe(strip.Color(0, 255, 255), 50);
- //colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
- // Send a theater pixel chase in...發(fā)送劇院像素追逐.
- theaterChase(strip.Color(127, 127, 127), 50); // White
- theaterChase(strip.Color(255, 0, 0), 50); // Red
- theaterChase(strip.Color(0, 0, 255), 50); // Blue劇院追逐
- theaterChase(strip.Color(0, 255, 0), 50);
- theaterChase(strip.Color(255, 0, 255), 50);
- theaterChase(strip.Color(255, 255, 0), 50);
- theaterChase(strip.Color(0, 255, 255), 50);
- rainbow(20);
- rainbowCycle(20);
- theaterChaseRainbow(50);
- rainbowCycle1(20);
- rainbowCycle2(20);
- /************************************************** key
- else
- // Fill the dots one after the other with a color用顏色一個接一個地填充這些點
- void colorWipe(uint32_t c, uint8_t wait)
- for(uint16_t i=0; i<strip.numPixels(); i++)
- strip.setPixelColor(i, c);
- strip.show();
- delay(wait);
- void rainbow(uint8_t wait)
- uint16_t i, j;
- for(j=0; j<256; j++)
- for(i=0; i<strip.numPixels(); i++)
- strip.setPixelColor(i, Wheel((i+j) & 255));
- strip.show();
- delay(wait);
- // Slightly different, this makes the rainbow equally distributed throughout略有不同,這使得彩虹在整個
- void rainbowCycle(uint8_t wait)
- uint16_t i, j;
- for(j=0; j<256*5; j++) // 5 cycles of all colors on wheel
- for(i=0; i< strip.numPixels(); i++)
- strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
- strip.show();
- delay(wait);
- void rainbowCycle1(uint8_t wait)
- uint16_t i, j;
- for(j=256*5; j>=0; j--) // 5 cycles of all colors on wheel
- strip.show();
- delay(wait);
- void rainbowCycle2(uint8_t wait)
- uint16_t i, j;
- for(i=strip.numPixels(); i>=0; i--)
- strip.show();
- delay(wait);
- //Theatre-style crawling lights.
- void theaterChase(uint32_t c, uint8_t wait)
- for (int j=0; j<10; j++)
- { //do 10 cycles of chasing
- for (int q=0; q < 3; q++)
- for (uint16_t i=0; i < strip.numPixels(); i=i+3)
- strip.setPixelColor(i+q, c); //turn every third pixel on
- strip.show();
- delay(wait);
- strip.setPixelColor(i+q, 0); //turn every third pixel off
- //Theatre-style crawling lights with rainbow effect彩虹色效果的劇院風(fēng)格爬行燈
- void theaterChaseRainbow(uint8_t wait)
- for (int j=0; j < 256; j++)
- { // cycle all 256 colors in the wheel
- strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on
- strip.show();
- delay(wait);
- // Input a value 0 to 255 to get a color value.
- // The colours are a transition r - g - b - back to r.
- uint32_t Wheel(byte WheelPos)
- WheelPos = 255 - WheelPos;
- if(WheelPos < 85)
- return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
- if(WheelPos < 170)
- WheelPos -= 85;
- return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
- WheelPos -= 170;
- return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
sketch_RGB.rar
(2.96 KB, 下載次數(shù): 37)
2020-3-10 14:13 上傳
RGB全彩燈
