可下載,需要PCB可私發(fā)
2020-3-10 13:02 上傳
2020-3-10 13:05 上傳
單片機(jī)源程序如下:
- #include <reg52.h>
- unsigned long int fre;
- unsigned char time;
- unsigned int count;
- unsigned int count1;
- sbit LCD_RS=P1^0; //片選信號
- sbit LCD_RW=P1^1; //讀寫信號
- sbit LCD_E=P1^2; //使能信號
- #define LCD_DB P0 //數(shù)據(jù)信號
- unsigned char character[10]={0};//在屏幕上顯示的字符串
- unsigned char character_1[]={"fre= Hz"};
- unsigned char FLAG = 0; //是否分頻選擇標(biāo)志
- void LCD_init(void);//初始化函數(shù)
- void LCD_write_command(unsigned char command);//寫指令函數(shù)
- void LCD_write_data(unsigned char dat);//寫數(shù)據(jù)函數(shù)
- void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat);//在某個屏幕位置上顯示一個字符,X(0-15),y(1-2)
- void delay_n40us(unsigned int n);//延時函數(shù)
- void timer_init(); //中斷初始化函數(shù)
- //-----------------------------延時函數(shù)---------------------------
- void delay_n40us(unsigned int n) //延時函數(shù)
- unsigned int i;
- unsigned char j;
- for(i=n;i>0;i--)
- for(j=0;j<2;j++);
- void delay_1s()
- unsigned int i,j;
- for(i = 0;i<100;i++)
- for(j = 0;j<1000;j++);
- //---------------------lcd1602液晶顯示函數(shù)--------------------
- void LCD_init(void) //液晶初始化函數(shù)
- LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
- LCD_write_command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
- LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
- LCD_write_command(0x01);//清除屏幕顯示
- delay_n40us(100);//清屏延時
- void LCD_write_command(unsigned char dat) //寫命令函數(shù)
- LCD_DB=dat;
- LCD_RS=0;//指令
- LCD_RW=0;//寫入
- LCD_E=1; //使能
- LCD_E=0;
- delay_n40us(1);//寫命令延時
- void LCD_write_data(unsigned char dat) //寫數(shù)據(jù)函數(shù)
- LCD_DB=dat;
- LCD_RS=1;//數(shù)據(jù)
- LCD_RW=0;//寫入
- LCD_E=1;//使能
- LCD_E=0;
- delay_n40us(1); //寫數(shù)據(jù)延時
- void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat)//顯示一個字符
- unsigned char address;
- if(y==1)
- address=0x80+x; //顯示在第一排的時候的x的地址
- else
- address=0xc0+x; //顯示在第二排的時候的x的地址
- LCD_write_command(address); //輸入地址
- LCD_write_data(dat); //輸入數(shù)據(jù)
- void LCD_disp_num(unsigned char x,unsigned char y,unsigned char dat)//顯示一個數(shù)字
- if(y==1)
- else
- LCD_write_data(dat+48); //輸入數(shù)據(jù)
- void dis_num(void)
- unsigned char i=0,j=0,k=0;
- character[0] = fre/10000000;
- character[1] = fre/1000000%10;
- character[2] = fre/100000%10;
- character[3] = fre/10000%10;
- character[4] = fre/1000%10;
- character[5] = fre/100%10;
- character[6] = fre/10%10;
- character[7] = fre%10;
- character[8] = 'H';
- character[9] = 'z';
- for(i = 0;i<4;i++) //顯示“fre=”
- LCD_disp_char(i+0,1,character_1[i]);
- for(i = 0;i<10;i++) //判斷第一個不為0的數(shù)
- if(character[i]!=0)
- break;
- k = 8-i;
- for(j = 0;j<k;j++) //顯示所有的數(shù)字
- LCD_disp_num(4+j,1,character[i++]);
- for(i = 5;i<7;i++) //顯示“Hz”
- LCD_disp_char(j+4,1,character_1[i]);
- j++;
- //----------------主函數(shù)--------------------
- void main()
- unsigned char i;
- LCD_init();
- timer_init(); //定時/計(jì)數(shù)器初始化
- while(1)
- dis_num(); //顯示
- delay_1s();
- //-------------------定時/計(jì)數(shù)器初始化--------------
- void timer_init(void) //定時/計(jì)數(shù)器初始化
- TMOD=0x66; //計(jì)數(shù)器0和計(jì)數(shù)器1工作工作方式2,自動重裝初值
- TH0=0; //計(jì)數(shù)器初值為0
- TL0=0;
- TR0=1; //計(jì)數(shù)器開始計(jì)數(shù)
- ET0=1; //打開計(jì)數(shù)器0中斷
- TH1=0; //計(jì)數(shù)器初值為0
- TL1=0;
- TR1=1; //計(jì)數(shù)器開始計(jì)數(shù)
- ET1=1; //打開計(jì)數(shù)器1中斷
- RCAP2H=(65536-62500)/256; //在程序初始化的時候給RCAP2L和RCAP2H賦值,
- RCAP2L=(65536-62500)%256; //TH2和TL2將會在中斷產(chǎn)生時自動使TH2=RCAP2H,TL2=RCAP2L。
- TH2=RCAP2H; //12M晶振下每次中斷62.5ms(1s=1000ms=62.5ms×16)
- TL2=RCAP2L;
- ET2=1; //打開定時器2中斷
- TR2=1; //定時器2開始計(jì)時
- EA=1; //開總中斷
- //------------------中斷函數(shù)----------------------
- void timer2(void) interrupt 5 //定時器2中斷(62.5ms)
- time++;
- TF2=0; //定時器2的中斷標(biāo)志位TF2不能夠由硬件清零,所以要在中斷服務(wù)程序中將其清零
- if (time==16) //定時1s時間到
- time=0; //計(jì)時清0
- EA=0; //關(guān)中斷
- fre=(long)count1*256+TL1; //count*256強(qiáng)制轉(zhuǎn)換成long型,否則將不產(chǎn)生進(jìn)位~先判斷分頻后(計(jì)數(shù)器1)
- FLAG = 0;
- if(fre<2000)//如果不到200KHz則讀取分頻前(計(jì)數(shù)器0)頻率(200K÷100=2000)
- fre = (long)count*256+TL0;
- FLAG = 1;
- if(!FLAG)
- fre = fre *100;//100分頻
- TL0=0; //清零計(jì)數(shù)器0計(jì)數(shù)
- TH0=0;
- TL1=0;
- TH1=0;
- count=0; //清零計(jì)數(shù)器0計(jì)數(shù)
- count1=0;
- EA=1; //開中斷
- void timer0(void) interrupt 1 //計(jì)數(shù)器0中斷(100分頻前)
- count++;
- void timer1(void) interrupt 3 //計(jì)數(shù)器1中斷(100分頻后)
- count1++;
2020-3-10 13:03 上傳
單片機(jī)頻率計(jì).7z
(1.03 MB, 下載次數(shù): 69)
2020-3-10 09:44 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
