查看: 2435|回復(fù): 3
基于STM32單片機感光萬年歷程序
ID:701491 發(fā)表于 2020-3-3 08:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
   做了一個stm32的萬年歷,具有溫度顯示,鬧鐘設(shè)置,可以通過感光播放音樂。
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "rtc.h"
  4. #include "oled.h"
  5. #include "bmp.h"
  6. #include "key.h"
  7. #include "adc.h"
  8. #include "ds18b20.h"
  9. u8  timetemp=0;
  10. u8 Naozhonghour=0;
  11. u8 Naozhongminite=0;
  12. u16 MenueSlect = 0;//0正常,1、2、3、4年4位設(shè)置,5月設(shè)置,
  13.                    //6日設(shè)置, 7時設(shè)置, 8分設(shè)置, 9秒復(fù)位設(shè)置
  14.        //鬧鐘設(shè)置,10時設(shè)置, 11分設(shè)置, 12鬧鐘開關(guān)設(shè)置
  15.        //感光元件設(shè)置:13感光設(shè)置
  16. u8 SetFalg = 0; //1為設(shè)置狀態(tài)
  17. u8 FirstFlag = 0;
  18. u8 NaozhongFlag = 0;//1為開狀態(tài)
  19. u8 GanguangFlag = 0;//1為開狀態(tài)
  20. u8 NaoxiangFlag = 0;
  21. u8 AllSetNumber = 0;
  22. //u8 Wendu = 0;
  23. short temperature = 0;
  24. u8 Bhour;
  25. u8 Bmin;
  26. u8 Bsec;
  27.         //公歷日月年周
  28. u16 Bw_year;
  29. u8  Bw_month;
  30. u8  Bw_date;
  31. u8  Bweek;
  32. u16 Number = 1;
  33. u16 NumberBuf1 = 1;
  34. u16 NumberBuf2 = 10;
  35. u16 ActNumber = 0;
  36. u16 ActNumbertemp = 0;
  37. u16 ActNumber1[3] ;
  38. u8  ActNumberLoop = 0;
  39. u16 ActNumberBuf1;
  40. u16 ADBuf;
  41. u16 ADBuf1;
  42. u16 ADBuf2;
  43. u8  NumberBuff[3];
  44. float Xielv =1;
  45. float B =1;
  46. u8  CheckFalg = 0;//0正常模式,1設(shè)置步驟1,2設(shè)置步驟2
  47. u8  FaultFalg = 0;
  48. u8  FirstFalg = 0;
  49. u8  OKFalg = 0;
  50. void Set_All(void);
  51. void MokuaiInit(void)
  52. {
  53.         GPIO_InitTypeDef  GPIO_InitStructure;
  54.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能B端口時鐘
  55.         GPIO_InitStructure.GPIO_Pin |= GPIO_Pin_9;
  56.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
  57.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
  58.         GPIO_Init(GPIOB, &GPIO_InitStructure);          //初始化GPIOD3,6
  59.         GPIO_SetBits(GPIOB,GPIO_Pin_9);
  60.
  61.
  62.                 //RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能B端口時鐘
  63.                 //GPIO_InitStructure.GPIO_Pin |= GPIO_Pin_5;
  64.                 //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;                  //
  65.                 //GPIO_Init(GPIOB, &GPIO_InitStructure);          //初始化GPIOD3,6
  66. }
  67. void HexToAsc1(uint8_t HexData,uint8_t  *p)
  68. {
  69.     p[0] = HexData % 10 | 0x30;
  70. }
  71. //數(shù)值轉(zhuǎn)換:3位HEX數(shù)(1字節(jié))和ASC碼轉(zhuǎn)換
  72. void HexToAsc3(uint16_t HexData,uint8_t  *p)
  73. {
  74.     p[0] = HexData / 100 ;
  75.     p[1] = HexData % 100 / 10 ;
  76.     p[2] = HexData % 10 ;
  77. }
  78. void KeyLedHandle(void)                            //鍵盤和LED處理
  79. {
  80.          static u8  KeyTemp1;    //按鍵值臨時緩存1
  81.          static u8  KeyTemp2;    //按鍵值臨時緩存2
  82.          static u8  KeyCount;
  83.          static u8  KeyValue;
  84.                 u8 tempge =0,tempshi=0,tempbai=0,tempqian=0;
  85.           u16 temp;
  86.
  87.
  88.
  89.
  90.         KeyTemp1 =KEY_Scan(0);
  91.
  92.
  93.                 if(KeyTemp1 !=0)               //其它按鍵按下,計數(shù)為5,執(zhí)行相應(yīng)的按鍵操作
  94.                         {
  95.                                 //Music=!Music;
  96.                           if(NaoxiangFlag == 1)
  97.                         {
  98.                                   NaoxiangFlag = 0;
  99.                                         Music_OFF;
  100.
  101.
  102.                         }
  103.                                 switch(KeyTemp1)
  104.              {
  105.                      case KEY_UP:                                //上+
  106.              LED0=!LED0;
  107.                                     if(SetFalg == 1)
  108.                                                  {
  109.                                                    AllSetNumber++;
  110.                                                          if(MenueSlect == 1)//年第一位設(shè)置
  111.                                                          {
  112.
  113.        if(AllSetNumber >=3)
  114.        {
  115.        AllSetNumber = 1;
  116.                                                           }
  117.                                                          }
  118.                                                          else if((MenueSlect ==2)||(MenueSlect ==3)||(MenueSlect ==4)) //年第二三四位設(shè)置
  119.                                                          {
  120.                                                           if(AllSetNumber >=10)
  121.        {
  122.        AllSetNumber = 0;
  123.        }
  124.                                                          }
  125.                                                          else if(MenueSlect == 5)//月設(shè)置
  126.                                                          {
  127.                                                            if(AllSetNumber >=13)
  128.        {
  129.        AllSetNumber = 1;
  130.        }
  131.                                                          }
  132.                                                         else if(MenueSlect == 6)//日設(shè)置
  133.                                                          {
  134.                                                            if(AllSetNumber >=32)
  135.        {
  136.        AllSetNumber = 1;
  137.        }
  138.                                                          }
  139.                                                          else if(MenueSlect == 7)//時設(shè)置
  140.                                                          {
  141.        if(AllSetNumber >=24)
  142.        {
  143.        AllSetNumber = 0;
  144.        }
  145.                                                          }
  146.                                                          else if(MenueSlect == 8)//分設(shè)置
  147.                                                          {
  148.        if(AllSetNumber >=60)
  149.        {
  150.        AllSetNumber = 0;
  151.        }
  152.                                                          }
  153.                                                          else if(MenueSlect ==9 )//秒復(fù)位
  154.                                                          {
  155.                                                           AllSetNumber = 0;
  156.                                                          }
  157.                                                          else if(MenueSlect == 10)//鬧鐘時設(shè)置
  158.                                                          {
  159.        if(AllSetNumber >=24)
  160.        {
  161.        AllSetNumber = 0;
  162.        }
  163.                                                          }
  164.                                                          else if(MenueSlect == 11)//鬧鐘分設(shè)置
  165.                                                          {
  166.        if(AllSetNumber >=60)
  167.        {
  168.        AllSetNumber = 0;
  169.        }
  170.                                                          }
  171.                                                          else if(MenueSlect == 12)//鬧鐘開關(guān)設(shè)置
  172.                                                          {
  173.        if(NaozhongFlag == 0 )
  174.        {
  175.        NaozhongFlag = 1;//1為開狀態(tài)
  176.        }
  177.        else
  178.        {
  179.        NaozhongFlag = 0;//1為開狀態(tài)
  180.        }
  181.
  182.                                                          }
  183.                                                          else if(MenueSlect == 13)//感光元件開關(guān)設(shè)置
  184.                                                          {
  185.                  if(GanguangFlag == 0)
  186.        {
  187.        GanguangFlag = 1;//1為開狀態(tài)
  188.        }
  189.                  else
  190.        {
  191.        GanguangFlag = 0;//1為開狀態(tài)
  192.        }
  193.
  194.                                                          }
  195.                                                          else
  196.                                                          {
  197.                                                          }
  198.                                                  }
  199.
  200.                                                         break;
  201.                                 case KEY_DOWN:                                //下-
  202. LED0=!LED0;
  203.              if(SetFalg == 1)
  204.                                                  {
  205.
  206.                                                          if(MenueSlect == 1)//年第一位設(shè)置
  207.                                                          {
  208.        if(AllSetNumber ==1)
  209.        {
  210.        AllSetNumber = 2;
  211.                                                           }
  212.        else
  213.                                                          {
  214.                                                            AllSetNumber--;
  215.                                                          }
  216.                                                          }
  217.                                                         else if((MenueSlect ==2)||(MenueSlect ==3)||(MenueSlect ==4)) //年第二三四位設(shè)置
  218.                                                          {
  219.                                                           if(AllSetNumber ==0)
  220.        {
  221.        AllSetNumber = 9;
  222.        }
  223.        else
  224.                                                          {
  225.                                                            AllSetNumber--;
  226.                                                          }
  227.                                                          }
  228.                                                          else if(MenueSlect == 5)//月設(shè)置
  229.                                                          {
  230.                                                            if(AllSetNumber ==1)
  231.        {
  232.        AllSetNumber = 12;
  233.        }
  234.        else
  235.                                                          {
  236.                                                            AllSetNumber--;
  237.                                                          }
  238.                                                          }
  239.                                                         else if(MenueSlect == 6)//日設(shè)置
  240.                                                          {
  241.                                                            if(AllSetNumber ==1)
  242.        {
  243.        AllSetNumber = 31;
  244.        }
  245.        else
  246.                                                          {
  247.                                                            AllSetNumber--;
  248.                                                          }
  249.                                                          }
  250.                                                          else if(MenueSlect == 7)//時設(shè)置
  251.                                                          {
  252.        if(AllSetNumber == 0)
  253.        {
  254.        AllSetNumber = 23;
  255.        }
  256.        else
  257.                                                          {
  258.                                                            AllSetNumber--;
  259.                                                          }
  260.                                                          }
  261.                                                          else if(MenueSlect == 8)//分設(shè)置
  262.                                                          {
  263.        if(AllSetNumber ==0)
  264.        {
  265.        AllSetNumber = 59;
  266.        }
  267.        else
  268.                                                          {
  269.                                                            AllSetNumber--;
  270.                                                          }
  271.                                                          }
  272.                                                          else if(MenueSlect ==9 )//秒復(fù)位
  273.                                                          {
  274.                                                           AllSetNumber = 0;
  275.                                                          }
  276.                                                          else if(MenueSlect == 10)//鬧鐘時設(shè)置
  277.                                                          {
  278.        if(AllSetNumber ==0)
  279.        {
  280.        AllSetNumber = 23;
  281.        }
  282.        else
  283.                                                          {
  284.                                                            AllSetNumber--;
  285.                                                          }
  286.                                                          }
  287.                                                          else if(MenueSlect == 11)//鬧鐘分設(shè)置
  288.                                                          {
  289.        if(AllSetNumber ==0)
  290.        {
  291.        AllSetNumber = 59;
  292.        }
  293.        else
  294.                                                          {
  295.                                                            AllSetNumber--;
  296.                                                          }
  297.                                                          }
  298.                                                          else if(MenueSlect == 12)//鬧鐘開關(guān)設(shè)置
  299.                                                          {
  300.        if(NaozhongFlag == 0 )
  301.        {
  302.        NaozhongFlag = 1;//1為開狀態(tài)
  303.        }
  304.
  305.        else
  306.        {
  307.        NaozhongFlag = 0;//1為開狀態(tài)
  308.        }
  309.
  310.                                                          }
  311.                                                          else if(MenueSlect == 13)//感光元件開關(guān)設(shè)置
  312.                                                          {
  313.                  if(GanguangFlag == 0)
  314.        {
  315.        GanguangFlag = 1;//1為開狀態(tài)
  316.        }
  317.                  else
  318.        {
  319.        GanguangFlag = 0;//1為開狀態(tài)
  320.        }
  321.
  322.                                                          }
  323.                                                          else
  324.                                                          {
  325.                                                          }
  326.                                                  }
  327.
  328.                           break;
  329.                                 case KEY_LEFT:                                //左,菜單切換+
  330.               LED0=!LED0;
  331.                                      if(SetFalg == 1)
  332.                                                         {
  333.
  334.                                                          if(MenueSlect == 13)
  335.                                                          {
  336.                                                            MenueSlect = 1;
  337.                                                          }
  338.                                                          else
  339.                                                          {
  340.                                                            MenueSlect++;
  341.                                                          }
  342.        if(MenueSlect == 1)
  343.        {
  344.        AllSetNumber = Bw_year/1000;
  345.        }
  346.        else if(MenueSlect == 2)
  347.        {
  348.        AllSetNumber = (Bw_year%1000)/100;
  349.        }
  350.        else if(MenueSlect == 3)
  351.        {
  352.        AllSetNumber = ((Bw_year%1000)%100)/10;
  353.        }
  354.        else if(MenueSlect == 4)
  355.        {
  356.        AllSetNumber = ((Bw_year%1000)%100)%10;
  357.
  358.        }
  359.        else if(MenueSlect == 5)
  360.        {
  361.        AllSetNumber = Bw_month;
  362.        }
  363.        else if(MenueSlect == 6)
  364.        {
  365.        AllSetNumber = Bw_date;
  366.        }
  367.        else if(MenueSlect == 7)
  368.        {
  369.        AllSetNumber = Bhour;
  370.        }
  371.        else if(MenueSlect == 8)
  372.        {
  373.        AllSetNumber = Bmin;
  374.        }
  375.        else if(MenueSlect == 9)
  376.        {
  377.        AllSetNumber = Bsec;
  378.        }
  379.        else if(MenueSlect == 10)
  380.        {
  381.        AllSetNumber = Naozhonghour;
  382.        }
  383.        else if(MenueSlect == 11)
  384.        {
  385.        AllSetNumber = Naozhongminite;
  386.        }
  387.        else if(MenueSlect == 12)
  388.        {
  389.        AllSetNumber = (Bw_year%1000)/100;
  390.        }
  391.        else if(MenueSlect == 13)
  392.        {
  393.        AllSetNumber = (Bw_year%1000)/100;
  394.        }
  395.
  396.
  397.
  398.
  399.                                                         }
  400.                           break;
  401.                                 case KEY_RIGHT:                                //右,菜單切換-
  402.              LED0=!LED0;
  403.                                      if(SetFalg == 1)
  404.                                                         {
  405.        if(MenueSlect == 1)
  406.                                                          {
  407.                                                            MenueSlect = 13;
  408.                                                          }
  409.                                                          else
  410.                                                          {
  411.                                                            MenueSlect--;
  412.                                                          }
  413.
  414.        if(MenueSlect == 1)
  415.        {
  416.        AllSetNumber = Bw_year/1000;
  417.        }
  418.        else if(MenueSlect == 2)
  419.        {
  420.        AllSetNumber = (Bw_year%1000)/100;
  421.        }
  422.        else if(MenueSlect == 3)
  423.        {
  424.        AllSetNumber = ((Bw_year%1000)%100)/10;
  425.        }
  426.        else if(MenueSlect == 4)
  427.        {
  428.        AllSetNumber = ((Bw_year%1000)%100)%10;
  429.
  430.        }
  431.        else if(MenueSlect == 5)
  432.        {
  433.        AllSetNumber = Bw_month;
  434.        }
  435.        else if(MenueSlect == 6)
  436.        {
  437.        AllSetNumber = Bw_date;
  438.        }
  439.        else if(MenueSlect == 7)
  440.        {
  441.        AllSetNumber = Bhour;
  442.        }
  443.        else if(MenueSlect == 8)
  444.        {
  445.        AllSetNumber = Bmin;
  446.        }
  447.        else if(MenueSlect == 9)
  448.        {
  449.        AllSetNumber = Bsec;
  450.        }
  451.        else if(MenueSlect == 10)
  452.        {
  453.        AllSetNumber = Naozhonghour;
  454.        }
  455.        else if(MenueSlect == 11)
  456.        {
  457.        AllSetNumber = Naozhongminite;
  458.        }
  459.        else if(MenueSlect == 12)
  460.        {
  461.        AllSetNumber = (Bw_year%1000)/100;
  462.        }
  463.        else if(MenueSlect == 13)
  464.        {
  465.        AllSetNumber = (Bw_year%1000)/100;
  466.        }
  467.                                                         }
  468.
  469.
  470.
  471.
  472.                           break;
  473.                                 case KEY_SURE:                                //確定
  474.         LED0=!LED0;
  475.                                     if(SetFalg ==0)//1為設(shè)置狀態(tài)
  476.                                                  {
  477.                                                    SetFalg = 1;
  478.                                                          FirstFlag = 1;
  479.                                                          MenueSlect = 1;
  480.                                                          Bw_year = calendar.w_year;
  481.                                                          AllSetNumber = Bw_year/1000;
  482.
  483.                                                  }
  484.                                                  else
  485.                                                  {
  486.                                                    SetFalg = 0;
  487.                                                          MenueSlect = 0;
  488.                                                          FirstFlag = 0;
  489.                                                          Set_All();
  490.                                                  }
  491.                            break;
  492.                                 //case KEY_MENU:                                //菜單,設(shè)置ok
  493.
  494.         //                  break;
  495.                                         default:
  496.                                         break;
  497.
  498.             }
  499.                         }
  500.
  501.
  502. }
  503. void MainDisplay(void)
  504. {
  505.                   u8 t;
  506.
  507.                 //OLED_ShowPicture(0,0,128,8,BMP1);
  508.                 //delay_ms(500);
  509.                 OLED_Clear();
  510.         //電(0) 子(1) 萬(2) 年(3) 歷(4) 時(5) 間(6) 鬧(7) 鐘(8) 感(9) 光(10) 狀(11) 態(tài)(12) 開(13) 關(guān)(14)
  511.
  512.
  513.         if(DS18B20_Init())        //DS18B20初始化
  514.         {
  515.                 OLED_ShowString(16,16,"DS18B20 Error",16);//8*16
  516.
  517.                 //delay_ms(200);
  518.                 //OLED_Refresh();
  519.         }
  520.         else
  521.         {
  522.            OLED_ShowString(16,16,"DS18B20 OK",16);//8*16
  523.         }
  524.
  525.           //OLED_Clear();
  526.           OLED_ShowChinese(0,1,0,16);//電
  527.                 OLED_ShowChinese(18,1,1,16);//子
  528.                 OLED_ShowChinese(36,1,2,16);//計
  529.                 OLED_ShowChinese(54,1,3,16);//萬
  530.                 OLED_ShowChinese(72,1,4,16);//年
  531.                 //OLED_ShowChinese(90,1,5,16);//歷
  532.
  533.                 OLED_Refresh();
  534.           delay_ms(60000);
  535.           delay_ms(60000);
  536.           delay_ms(60000);
  537.           OLED_Clear();
  538.
  539.
  540.                 //OLED_ShowChinese(0,16,5,16);//時
  541.                 //OLED_ShowChinese(18,16,6,16);//間
  542.           OLED_ShowChinese(26,16,15,16);//℃
  543.
  544.                 OLED_ShowChinese(0,32,7,16);//鬧
  545.                 OLED_ShowChinese(18,32,8,16);//鐘
  546.                 //OLED_ShowChinese(90,32,13,16);// 開
  547.                 //OLED_ShowChinese(90,32,14,16);//關(guān)
  548.                 OLED_ShowChinese(0,48,9,16);//感
  549.                 OLED_ShowChinese(18,48,10,16);//光
  550.                 OLED_ShowChinese(36,48,11,16);//狀
  551.                 OLED_ShowChinese(54,48,12,16);//態(tài)
  552.                 //OLED_ShowChinese(90,48,13,16);// 開
  553.                 //OLED_ShowChinese(90,48,14,16);//關(guān)
  554.
  555.
  556.
  557. //時間現(xiàn)實
  558.                 OLED_ShowString(2,0,"    -  -  ",12);//6*12
  559.                 OLED_ShowString(62,0,"Sunday   ",12);
  560.
  561.                 OLED_ShowString(42,16,"  :  :  ",16);//8*16
  562.
  563. //鬧鐘顯示
  564.                 OLED_ShowString(42,32,"  :  ",16);//8*16
  565.
  566.
  567.
  568.                         OLED_ShowNum(2,0,calendar.w_year,4,12);
  569.                         OLED_ShowNum(32,0,calendar.w_month,2,12);
  570.                         OLED_ShowNum(50,0,calendar.w_date,2,12);
  571.       OLED_ShowNum(8,16,temperature/10,2,16);        //顯示正數(shù)部分
  572.       //OLED_ShowNum(0,16,Wendu,2,16);                //8*16
  573.                         OLED_ShowNum(42,16,calendar.hour,2,16);                //8*16
  574.                         OLED_ShowNum(66,16,calendar.min,2,16);
  575.                         OLED_ShowNum(90,16,calendar.sec,2,16);
  576.
  577.
  578.                         OLED_ShowNum(42,32,Naozhonghour,2,16);                //8*16
  579.                         OLED_ShowNum(66,32,Naozhongminite,2,16);
  580.
  581.       OLED_ShowChar(90,32,'N',16);//關(guān)
  582.       OLED_ShowChar(90,48,'N',16);//關(guān)
  583.                         //OLED_ShowChar(90,32,"Y",16);//關(guān)
  584.       //OLED_ShowChar(90,48,"Y",16);//關(guān)
  585.
  586.                 //OLED_ShowString(40,16,": 000",12);
  587.           //OLED_ShowNum(40,16,Number,3,16);
  588.                 //OLED_ShowString(40,32,": 000",12);
  589.                 //OLED_ShowNum(40,32,ActNumber,3,16);
  590.                 //OLED_ShowString(0,48,"AD:0000",16);
  591.                 //OLED_ShowNum(24,48,ADBuf,4,16);
  592.
  593.                 /*OLED_ShowChar(48,48,t,16);//顯示ASCII字符
  594.                 t++;
  595.                 if(t>'~')t=' ';
  596.                 OLED_ShowNum(103,48,t,3,16);
  597.                 OLED_Refresh();
  598.                 delay_ms(500);
  599.                 OLED_Clear();
  600.                 OLED_ShowChinese(0,0,0,16);  //16*16 中
  601.           OLED_ShowChinese(16,0,0,24); //24*24 中
  602.                 OLED_ShowChinese(24,20,0,32);//32*32 中
  603.           OLED_ShowChinese(64,0,0,64); //64*64 中
  604.                 OLED_Refresh();
  605.           delay_ms(500);
  606.           OLED_Clear();
  607.                 OLED_ShowString(0,0,"ABC",12);//6*12 “ABC”
  608.           OLED_ShowString(0,12,"ABC",16);//8*16 “ABC”
  609.                 OLED_ShowString(0,28,"ABC",24);//12*24 “ABC”
  610.           OLED_Refresh();
  611.                 delay_ms(500);
  612.                 OLED_ScrollDisplay(11,4);*/
  613.                 OLED_Refresh();
  614.                 delay_ms(500);
  615. }
  616. void FunDataRun(void)
  617. {
  618.
  619.                         //PBout(5)=!PBout(5);
  620.                 //}
  621.                         if(SetFalg == 1)
  622.                          {
  623.
  624.                          u8 tempge =0,tempshi=0,tempbai=0,tempqian=0;
  625.              u16 temp;
  626.                                  if(FirstFlag == 1)
  627.                                  {
  628.                                     FirstFlag = 0;
  629.                                                 Bw_year = calendar.w_year;
  630.                                                 Bw_month = calendar.w_month;
  631.                                                 Bw_date = calendar.w_date;
  632.                                                 Bhour = calendar.hour;
  633.                                                 Bmin = calendar.min;
  634.                                                 Bsec = calendar.sec;
  635.
  636.                                  }
  637.                                                 OLED_ShowNum(2,0,Bw_year,4,12);
  638.                                                 OLED_ShowNum(32,0,Bw_month,2,12);
  639.                                                 OLED_ShowNum(50,0,Bw_date,2,12);
  640.                                                 OLED_ShowNum(42,16,Bhour,2,16);                //8*16
  641.                                                 OLED_ShowNum(66,16,Bmin,2,16);
  642.                                                 OLED_ShowNum(90,16,Bsec,2,16);
  643.                                                 OLED_ShowNum(42,32,Naozhonghour,2,16);                //8*16
  644.                                                 OLED_ShowNum(66,32,Naozhongminite,2,16);
  645.                                                 if(NaozhongFlag == 1)
  646.                                                 {
  647.                                                 OLED_ShowChar(90,32,'Y',16);//開
  648.                                                 }
  649.                                                 else
  650.                                                 {
  651.                                                 OLED_ShowChar(90,32,'N',16);//關(guān)
  652.                                                 }
  653.                                                 if(GanguangFlag == 1)
  654.                                                 {
  655.                                                         OLED_ShowChar(90,48,'Y',16);//
  656.                                                 }
  657.                                                 else
  658.                                                 {
  659.                                                         OLED_ShowChar(90,48,'N',16);//
  660.                                                 }
  661.
  662.
  663.
  664.                                                  tempqian = Bw_year/1000;
  665.                                                 tempbai = (Bw_year%1000)/100;
  666.                                                 tempshi = ((Bw_year%1000)%100)/10;
  667.                                                 tempge = ((Bw_year%1000)%100)%10;
  668.
  669.                                  if(MenueSlect == 1)//年第一位設(shè)置
  670.                                  {
  671.
  672.                                         tempqian = AllSetNumber;
  673.                                         OLED_ShowNumKong(2,0,tempqian,1,12);
  674.
  675.                                  }
  676.                                  else if(MenueSlect == 2) //年第二三四位設(shè)置
  677.                                  {
  678.            tempbai = AllSetNumber;
  679.                                          OLED_ShowNumKong(8,0,tempbai,1,12);
  680.                                  }
  681.                                  else if(MenueSlect == 3) //年第二三四位設(shè)置
  682.                                  {
  683.            tempshi = AllSetNumber;
  684.                                          OLED_ShowNumKong(14,0,tempshi,1,12);
  685.                                  }
  686.                                  else if(MenueSlect == 4) //年第二三四位設(shè)置
  687.                                  {
  688.            tempge = AllSetNumber;
  689.                                          OLED_ShowNumKong(20,0,tempge,1,12);
  690.                                  }
  691.                                  else if(MenueSlect == 5)//月設(shè)置
  692.                                  {
  693.                                           Bw_month = AllSetNumber;
  694.
  695.                               OLED_ShowNumKong(32,0,Bw_month,2,12);
  696.                                  }
  697.                                 else if(MenueSlect == 6)//日設(shè)置
  698.                                  {
  699.                    Bw_date = AllSetNumber;
  700.
  701.                               OLED_ShowNumKong(50,0,Bw_date,2,12);
  702.                                  }
  703.                                  else if(MenueSlect == 7)//時設(shè)置
  704.                                  {
  705.                                          Bhour = AllSetNumber;
  706.                                          OLED_ShowNumKong(42,16,Bhour,2,16);                //8*16
  707.
  708.                                  }
  709.                                  else if(MenueSlect == 8)//分設(shè)置
  710.                                  {
  711.            Bmin = AllSetNumber;
  712.                                          OLED_ShowNumKong(66,16,Bmin,2,16);
  713.
  714.                                  }
  715.                                  else if(MenueSlect ==9 )//秒復(fù)位
  716.                                  {
  717.                                            Bsec = AllSetNumber;
  718.                                          OLED_ShowNumKong(90,16,Bsec,2,16);
  719.                                  }
  720.                                  else if(MenueSlect == 10)//鬧鐘時設(shè)置
  721.                                  {
  722.           Naozhonghour = AllSetNumber;
  723.
  724.                                         OLED_ShowNumKong(42,32,Naozhonghour,2,16);                //8*16
  725.                                  }
  726.                                  else if(MenueSlect == 11)//鬧鐘分設(shè)置
  727.                                  {
  728.           Naozhongminite = AllSetNumber;
  729.                                         OLED_ShowNumKong(66,32,Naozhongminite,2,16);
  730.                                  }
  731.                                  else if(MenueSlect == 12)//鬧鐘開關(guān)設(shè)置
  732.                                  {
  733.                                                 if(NaozhongFlag == 1)
  734.                                                 {
  735.                                            OLED_ShowCharKong(90,32,'Y',16);//開
  736.                                                 }
  737.                                                 else
  738.                                                 {
  739.                                                 OLED_ShowCharKong(90,32,'N',16);//關(guān)
  740.                                                 }
  741.
  742.                                  }
  743.                                  else if(MenueSlect == 13)//感光元件開關(guān)設(shè)置
  744.                                  {
  745.                                                 if(GanguangFlag == 1)
  746.                                                 {
  747.                                                         OLED_ShowCharKong(90,48,'Y',16);//
  748.                                                 }
  749.                                                 else
  750.                                                 {
  751.                                                         OLED_ShowCharKong(90,48,'N',16);//
  752.                                                 }
  753.
  754.                                  }
  755.                                  else
  756.                                  {
  757.                                  }
  758.
  759.                                  Bw_year = (tempqian*1000)+(tempbai*100)+(tempshi*10)+tempge;
  760.                                  //OLED_ShowNum(0,48,AllSetNumber,1,16);
  761.                                  //OLED_ShowNum(32,48,Bw_year,4,16);
  762.                                  //RTC_Set(Bw_year,Bw_month,Bw_date,Bhour,Bmin,Bsec);  //設(shè)置時間
  763.                      //RTC_Set(2023,3,3,3,3,3);  //設(shè)置時間
  764.
  765.                          }
  766.                          else
  767.                          {
  768.
  769.        //if (RTC_GetITStatus(RTC_IT_SEC) != RESET)//秒鐘中斷
  770.                                                         //if(SetFalg == 0)
  771.                                                         //{
  772.                                                         //        RTC_ClearITPendingBit(RTC_IT_SEC|RTC_IT_OW);                //清鬧鐘中斷
  773.        RTC_Get();//更新時間
  774.                                                         //}
  775.
  776.
  777.        //if(timetemp!=calendar.sec)
  778.        //{
  779.        //timetemp=calendar.sec;
  780.        OLED_ShowNum(2,0,calendar.w_year,4,12);
  781.        OLED_ShowNum(32,0,calendar.w_month,2,12);
  782.        OLED_ShowNum(50,0,calendar.w_date,2,12);
  783.
  784.        switch(calendar.week)
  785.        {
  786.        case 0:
  787.        OLED_ShowString(62,0,"Sunday   ",12);
  788.        break;
  789.        case 1:
  790.        OLED_ShowString(62,0,"Monday   ",12);
  791.        break;
  792.        case 2:
  793.        OLED_ShowString(62,0,"Tuesday  ",12);
  794.        break;
  795.        case 3:
  796.        OLED_ShowString(62,0,"Wednesday",12);
  797.        break;
  798.        case 4:
  799.        OLED_ShowString(62,0,"Thursday ",12);
  800.        break;
  801.        case 5:
  802.        OLED_ShowString(62,0,"Friday   ",12);
  803.        break;
  804.        case 6:
  805.        OLED_ShowString(62,0,"Saturday ",12);
  806.        break;
  807.        }
  808.        OLED_ShowNum(42,16,calendar.hour,2,16);                //8*16
  809.        OLED_ShowNum(66,16,calendar.min,2,16);
  810.        OLED_ShowNum(90,16,calendar.sec,2,16);
  811.        OLED_ShowNum(42,32,Naozhonghour,2,16);                //8*16
  812.        OLED_ShowNum(66,32,Naozhongminite,2,16);
  813.        if(NaozhongFlag == 1)
  814.        {
  815.        OLED_ShowChar(90,32,'Y',16);//開
  816.        if((calendar.hour == Naozhonghour)&&(calendar.min == Naozhongminite)&&(NaoxiangFlag == 0))
  817.        {
  818.        //if(NaoxiangFlag == 0)
  819.        // {
  820.        Music_ON;
  821.        NaoxiangFlag = 1;
  822.        //}
  823.
  824.        }
  825.        //else
  826.        //{
  827.        //  NaoxiangFlag = 0;
  828.        //}
  829.        }
  830.        else
  831.        {
  832.        OLED_ShowChar(90,32,'N',16);//關(guān)
  833.        }
  834.        if(GanguangFlag == 1)
  835.        {
  836.        OLED_ShowChar(90,48,'Y',16);//
  837.        if(GanGuang == 0)
  838.        {
  839.        Music_ON;
  840.        LED0=!LED0;
  841.        }
  842.        else if(NaoxiangFlag == 0)
  843.        {
  844.        Music_OFF;
  845.        }
  846.        }
  847.        else
  848.        {
  849.        OLED_ShowChar(90,48,'N',16);//
  850.        }
  851.
  852.
  853.
  854.
  855.                          }
  856.
  857.                         temperature=DS18B20_Get_Temp();
  858.                         if(temperature<0)
  859.                         {
  860.                                 OLED_ShowChar(0,16,'-',16);                        //顯示負(fù)號
  861.                                 temperature=-temperature;                                        //轉(zhuǎn)為正數(shù)
  862.                         }else OLED_ShowChar(0,16,' ',16);                        //去掉負(fù)號
  863.
  864.                         OLED_ShowNum(8,16,temperature/10,2,16);        //顯示正數(shù)部分
  865.                            //OLED_ShowNum(60+40+32,150,temperature%10,1,16);        //顯示小數(shù)部分
  866.
  867.
  868.
  869.
  870.
  871. }
  872. void Naozhong_Set(void)
  873. {
  874. }
  875. void Set_All(void)
  876. {
  877.     RTC_Set(Bw_year,Bw_month,Bw_date,Bhour,Bmin,Bsec);  //設(shè)置時間
  878.     Naozhong_Set();
  879.
  880. }
  881. void FunDataShow(void)
  882. {
  883.                  OLED_ShowNum(40,16,Number,3,16);
  884.                  OLED_ShowNum(40,32,ActNumber,3,16);
  885.                  OLED_ShowNum(24,48,ADBuf,4,16);
  886. }
  887. int main(void)
  888. {
  889.
  890.         u8 t;
  891.
  892.         delay_init();
  893.         NVIC_Configuration();          //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
  894.         //usmart_dev.init(SystemCoreClock/1000000);        //初始化USMART
  895.         RTC_Init();
  896.
  897.         //Adc_Init();
  898.         OLED_Init();
  899.         KEY_Init();
  900.         MokuaiInit();
  901.         OLED_ColorTurn(0);//0正常顯示,1 反色顯示
  902.   OLED_DisplayTurn(0);//0正常顯示 1 屏幕翻轉(zhuǎn)顯示
  903.
  904. //        OLED_DrawPoint(0,0);
  905. //        OLED_DrawLine(20,0,50,60);
  906. //        OLED_DrawCircle(64,32,20);
  907.         OLED_Refresh();
  908.         t=' ';
  909.         LED_ON;
  910.         //OLED_ShowString(72,0,"Sunday   ",12);
  911.                 //OLED_Refresh();
  912.
  913.         MainDisplay();
  914.         while(1)
  915.         {
  916.                 /*if(KEY_Scan(1) == KEY_UP)
  917.                 {
  918.                 OLED_ShowString(96,0,"HHH",16);//6*12
  919.
  920.                 }
  921.                 else
  922.                 {
  923.                 OLED_ShowString(96,0,"RRR",16);//6*12
  924.                 }
  925.                 OLED_ShowNum(0,16,KEY_Scan(1),1,16);
  926.                 OLED_ShowNum(16,16,KEY_Scan(1),1,16);
  927.                 OLED_ShowNum(32,16,KEY_Scan(1),1,16);
  928.                 OLED_ShowNum(48,16,KEY_Scan(1),1,16);
  929.                 OLED_ShowNum(64,16,KEY_Scan(1),1,16);
  930.                 OLED_ShowNum(80,16,KEY_Scan(1),1,16);*/
  931.                 /*if(FaultFalg == 0)
  932.                 {
  933.                   KeyLedHandle();
  934.                 }*/
  935.                 KeyLedHandle();
  936.                 //LinData();
  937.                 FunDataRun();
  938.                 //FunDataShow();
  939.                 OLED_Refresh();
  940.
  941.
  942.         }
  943. }
軟件.7z
223.6 KB, 下載次數(shù): 10, 下載積分: 黑幣 -5
軟件源碼
收藏收藏2 分享淘帖 頂 踩
ID:1 發(fā)表于 2020-3-4 18:52 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:780228 發(fā)表于 2020-6-20 18:38 | 只看該作者
有沒有proteus仿真
ID:779799 發(fā)表于 2020-6-22 16:56 | 只看該作者
感光用的什么傳感器?
