查看: 1823|回復(fù): 0
我這個可以控制步進(jìn)電機(jī)的開始、暫停、正轉(zhuǎn)、反轉(zhuǎn)、加速、減速嗎? 求幫助
ID:685171 發(fā)表于 2020-3-1 13:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include"reg52.h"
  2. #include"intrins.h"
  3.
  4. typedef unsigned int u16;
  5. typedef unsigned char u8;
  6. #define GPIO_MOTOR P1;//定義步進(jìn)電機(jī)的IO口
  7. u8 code FFW[8]={0xf4,0xf5,0xf1,0xf9,0xf8,0xfa,0xf2,0xf6};  // 電機(jī)正轉(zhuǎn)
  8. u8 code FFZ[8]={0xf2,0xfa,0xf8,0xf9,0xf1,0xf5,0xf4,0xf6}; //電機(jī)反轉(zhuǎn)
  9. u8 Speed=0;
  10. u8 direction=0;
  11. u8 receiveData='0';
  12. void UsartConfiguration(); //函數(shù)的聲明
  13. void Motor();
  14. void delay(u16 i)
  15. {
  16.   while(i--);
  17. }
  18. void main()
  19. {
  20.         UsartConfiguration();
  21.         Speed=180;
  22.         while(1)
  23.         {
  24.                 if(receiveData=='1')  //串口接收到'1',電機(jī)正轉(zhuǎn)
  25.                 {
  26.                         direction=1;
  27.                         receiveData='0';
  28.                 }
  29.                 if(receiveData=='2')   //串口接收到'2',電機(jī)反轉(zhuǎn)
  30.                 {
  31.                     direction=2;
  32.                         receiveData='0';
  33.                 }
  34.                 if(receiveData=='3')   // 串口接收到'3',電機(jī)暫停
  35.                 {
  36.                    P1=0;
  37.                receiveData='0';
  38.                 }
  39.                 if(receiveData=='4') //串口接收到'4',電機(jī)開始
  40.                 {
  41.                      P1=1;
  42.                      receiveData='0';
  43.                 }
  44.                 if(receiveData=='5') //串口接收到'5',電機(jī)加速
  45.                 {
  46.                Speed=20;
  47.                    receiveData='0';
  48.                    Speed=+180;
  49.                 }
  50.                 if(receiveData=='6') //串口接收到'6',電機(jī)減速
  51.                 {
  52.                    Speed=-20;
  53.                    receiveData='0';
  54.                    Speed=+180;
  55.
  56.                 }
  57.         }
  58.         Motor();
  59.         direction=0;
  60. }
  61. void UsartConfiguration()
  62. {
  63.         SCON=0X50;           //波特率是4800
  64.     TMOD=0X20;
  65.     PCON=0X80;
  66.     TH1=0XF3;
  67.     TL1=0XF3;
  68.     ES=1;
  69.     EA=1;
  70.     TR1=1;
  71. }
  72. void Usart() interrupt 4
  73. {
  74.         receiveData=SBUF;//出去接收到的數(shù)據(jù)
  75.         RI = 0;
  76.         SBUF=receiveData;
  77.     while(!TI);
  78.     TI=0;//清除接收中斷標(biāo)志位
  79. }
  80. void Motor()
  81. {
  82.    u8 i;
  83.    for(i=0;i<8;i++)
  84.    {
  85.       if(direction==1)
  86.           {
  87.               P1=FFW[i];
  88.           }
  89.           if(direction==2)
  90.           {
  91.               P1=FFZ[i];
  92.           }
  93.           delay(Speed);
  94.         }
  95. }
