查看: 2953|回復: 4
單片機LCD1602程序錯誤
ID:644966 發表于 2020-2-28 20:05 | 顯示全部樓層 |閱讀模式
#include"LCD1602.H"
#define  u16  unsigned int
#define         LCD_DelayNop()   NOP(20)
//檢測忙函數
void Check_Busy(void)
     u16 i;
     for(i=0;i<5000;i++) {if(!LCD_B7) break;}         //檢測忙
//初始化寫命令,不檢測忙
void Cmd_Send_Init()
     unsigned char cmd;
     LCD_RW=0;
     LCD_BusData(cmd);
         LCD_DelayNop();
         LCD_ENA=1;
         LCD_DelayNop();
         LCD_ENA=0;
     LCD_BusData(0xff);
//寫命令,檢測忙
void Write_CMD(unsigned char cmd)
     LCD_RS =0;
         LCD_RW=1;
         LCD_BusData(0xff);
         LCD_DelayNop();
         LCD_ENA=1;
         Check_Busy();
         LCD_ENA=0;
         LCD_RW=0;
     LCD_BusData(cmd);
         LCD_DelayNop();
         LCD_ENA=1;
         LCD_DelayNop();
         LCD_ENA=0;
     LCD_BusData(0xff);
//寫顯示數據,檢測忙
void Write_DIS_Data(unsigned char dat)
     LCD_RS=0;
         LCD_RW=1;
     LCD_BusData(0xff);
         LCD_DelayNop();
         LCD_ENA=1;
         Check_Busy();
         LCD_ENA=0;
         LCD_RW=0;
         LCD_RS =1;
     LCD_BusData(dat);
         LCD_DelayNop();
         LCD_ENA=1;
         LCD_DelayNop();
         LCD_ENA=0;
     LCD_BusData(0xff);
//LCD初始化
void LCD_Init(void)
     LCD_ENA=0;
     LCD_RS =0;
         LCD_RW=0;
         delay_Nms(100);
     Cmd_Send_Init(C_BIT8);                                //設置數據8位
     delay_Nms(10);
         Write_CMD(C_L2DOT7);                           //兩行5*7
         delay_Nms(6);
     Write_CMD(C_CLEAR);                                  //清屏
     Write_CMD(C_CUR_R);               //光標右移
         Write_CMD(C_ON);                                   //打開LCD
     Clear_Line(2);Clear_Line(1);
//清除一行
void Clear_Line(unsigned char row)
     unsigned char i;
     Write_CMD(((row&1)<<6)|0x80);
     for(i=0;i<LineLength;i++) Write_DIS_Data('');
//指定行、列和字符,寫一個字符
void Write_char(unsigned char row,unsigned char column,unsigned char dat)
      Write_CMD((((row & 1)<<6)+column)|0x80);
      Write_DIS_Data(dat);
//寫一個字符串,指定行、列和字符串首地址
void Put_String(unsigned char row,unsigned char column,unsigned char *puts)
         for(; *puts!=0; puts++)                        //遇到停止符0結束
         Write_DIS_Data(*puts);
         if(++column>=LineLength)  break;
// 寫數字
void Write_Num(unsigned char row,unsigned char column,long int dat)
     unsigned char num[8],i=0,j;
          while(dat){
                num[ i]=dat%10+'0';
                dat=dat/10;
                        i++;
       j=0;
       if(i==0){
              Write_Char(row,column+i-j,'');
                          Write_Char(row,column,'0');
       i--;
       while(j<=i){
             Write_Char(row,column+i-j,num[j]);
                j++;
//按指定位置顯示一串字符
void  DisplayString(unsigned char X,unsigned char Y,unsigned char code*dat)
    unsigned char ListLength,X2;
        ListLength=0;
        X2=X;
    if(Y<1) Y=1;                   //限制X不大于16
        if(Y>4) Y=4;                        //Y小于4
        X &=0x0F;
        switch(Y)
        case 1:X2|=0X80;     break;                  //根據行數來選擇相應的地址
                case 2:X2|=0X90;         break;
                case 3:X2|=0X88;         break;
                case 4:X2|=0X98;         break;
    Write_Cmd(X2,1);                                           //發送地址碼
        while(dat[ListLength]>=0x20)                   //字符串結束
        if(X<=0x0F)
         Write_Data(dat[ListLength]);
                 ListLength++;
                 X++;
錯誤compiling LCD1602.C...
..\SRC\LCD1602.C(18): error C236: '_Cmd_Send_Init': different length of parameter lists
..\SRC\LCD1602.C - 1 Error(s), 0 Warning(s).
ID:94031 發表于 2020-2-28 21:26 | 顯示全部樓層
改成下面樣子:
void Cmd_Send_Init(unsigned char cmd)
     LCD_RW=0;
     LCD_BusData(cmd);
         LCD_DelayNop();
         LCD_ENA=1;
         LCD_DelayNop();
         LCD_ENA=0;
     LCD_BusData(0xff);
ID:644966 發表于 2020-2-28 22:12 | 顯示全部樓層
俺明明定義了NOP,但是還有錯誤,求指教!!
ID:168996 發表于 2020-2-28 23:51 | 顯示全部樓層
Cmd_Send_Init定義沒有形參,調用時又有形參
二樓正解
ID:149451 發表于 2020-2-29 11:42 | 顯示全部樓層
我通常是在程序里把下面這兩句加上,有用沒用再說
#define uint  unsigned int
