查看: 2278|回復: 7
初學STM32單片機,請求大佬指教
回帖獎勵 5 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 1 次(中獎概率 50%)
ID:511875 發表于 2020-2-25 19:32 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
流水燈做成了,但我想讓他全亮全滅弄不通:
#include "stm32f10x.h"
  * @brief  Ö÷oˉêy
  * @param  ÎT
  * @retval ÎT
        #define LED1_TOGGLE            GPIOA->ODR^=GPIO_Pin_0
#define LED1_OFF                GPIOA->BSRR = GPIO_Pin_0
#define LED1_ON                 GPIOA->BRR = GPIO_Pin_0
#define LED2_TOGGLE             GPIOA->ODR^=GPIO_Pin_1
#define LED2_OFF                GPIOA->BSRR = GPIO_Pin_1
#define LED2_ON                 GPIOA->BRR = GPIO_Pin_1
#define LED3_TOGGLE             GPIOA->ODR^=GPIO_Pin_2
#define LED3_OFF                GPIOA->BSRR = GPIO_Pin_2
#define LED3_ON                 GPIOA->BRR = GPIO_Pin_2
#define LED4_TOGGLE             GPIOA->ODR^=GPIO_Pin_3
#define LED4_OFF                GPIOA->BSRR = GPIO_Pin_3
#define LED4_ON                 GPIOA->BRR = GPIO_Pin_3
//ê1óÿaoˉêy
#define LED5_OFF                GPIO_SetBits(GPIOA,GPIO_Pin_4)
#define LED5_ON                 GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define LED6_OFF                GPIO_SetBits(GPIOA,GPIO_Pin_5)
#define LED6_ON                 GPIO_ResetBits(GPIOA,GPIO_Pin_5)
#define LED7_OFF                GPIO_SetBits(GPIOA,GPIO_Pin_6)
#define LED7_ON                 GPIO_ResetBits(GPIOA,GPIO_Pin_6)
#define LEDALL_OFF              GPIO_SetBits(GPIOA,GPIO_Pin_All)
#define LEDALL_ON               GPIO_ResetBits(GPIOA,GPIO_Pin_All)
void LED_Cfg(void){
     GPIO_InitTypeDef led_gpio;
           SystemInit();
           RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
           led_gpio.GPIO_Pin = GPIO_Pin_All;
        //led_gpio.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3
           //                    | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
           led_gpio.GPIO_Mode = GPIO_Mode_Out_PP;//í¨óøøíÆíìêä3ö
           led_gpio.GPIO_Speed = GPIO_Speed_50MHz;//2MHz
           GPIO_Init(GPIOA,&led_gpio);
           //ÅäÖÃíê3éoó1رÕËùóDLED
           LED1_OFF;
          LED2_OFF;
          LED3_OFF;
          LED4_OFF;
          LED5_OFF;
          LED6_OFF;
          LED7_OFF;
          LEDALL_OFF;
void Delay(u32 nCount){
           while(nCount--);
int main(void)
            LED_Cfg();
            while(1){
                               LEDALL_ON;                                Delay(6000000);
                                LEDALL_OFF;
                                Delay(6000000);  燒錄這個程序流水燈不亮
          但以下這個就可以亮
                         /*LED1_ON;
          LED2_ON;
          LED3_ON;
          LED4_ON;
          LED5_ON;
          LED6_ON;
          LED7_ON;
             Delay(6000000);
        LED1_OFF;
          LED2_OFF;
          LED3_OFF;
          LED4_OFF;
          LED5_OFF;
          LED6_OFF;
          LED7_OFF;
        Delay(6000000);*/
ID:168996 發表于 2020-2-25 21:00 | 只看該作者
如果前面led受控(可高可低),那么證明GPIO_SetBits、GPIO_ResetBits沒問題,LEDALL_OFF LEDALL_ON 也應該沒問題。
所以我懷疑前面led并非受控,把delay函數優化一下:
void Delay2(u32 nCount){
  u32 tmp=0;
   while(nCount--);
試試
ID:592477 發表于 2020-2-25 22:24 | 只看該作者
全亮和全滅不是已經有了嗎?
第一個是全滅,第二個是全亮
ID:698253 發表于 2020-2-25 22:32 | 只看該作者
一共是幾個燈,具體怎么接線
ID:462827 發表于 2020-2-26 01:34 | 只看該作者
沒看到你的GPIO_Pin_All在哪里定義呀
ID:511875 發表于 2020-2-26 08:38 | 只看該作者
hantu 發表于 2020-2-26 01:34
GPIO_Pin_All是用的庫函數里面的0xFFFF
ID:679425 發表于 2020-2-26 09:05 | 只看該作者
ID:229016 發表于 2020-2-26 09:42 | 只看該作者
我個人覺得僅僅流水燈,用這么宏定義有點麻煩了,直接配置結構體就好了
