激光測距資料,移植參考的資料
- #include "vl53l0.h"
- #include "usart.h"
- u8 sendbuff[6]={0,0,0,0,0,0};
- VL53L0X_Dev_t vl53l0x_dev;
- VL53L0X_DeviceInfo_t vl53l0x_dev_info;
- VL53L0X_RangingMeasurementData_t vl53l0x_data;
- VL53L0X_Error vl53l0x_status;
- void print_pal_error(VL53L0X_Error Status)
- char buf[VL53L0X_MAX_STRING_LENGTH];
- VL53L0X_GetPalErrorString(Status, buf); //得到錯誤碼與字符串
- printf("API Status: %i : %s\n", Status, buf);
- void print_range_status(VL53L0X_RangingMeasurementData_t* pdata)
- uint8_t RangeStatus;
- // New Range Status: data is valid when pdata->RangeStatus = 0
- RangeStatus = pdata->RangeStatus;
- VL53L0X_GetRangeStatusString(RangeStatus, buf);
- printf("Range Status: %i : %s\n", RangeStatus, buf);
- VL53L0X_Error vl53l0x_start_single_test(VL53L0X_Dev_t *pdev, \
- VL53L0X_RangingMeasurementData_t *pdata)
- int i=0,j=0,sum=0;
- VL53L0X_Error status = VL53L0X_ERROR_NONE;
- if(vl53l0x_status != VL53L0X_ERROR_NONE)
- return vl53l0x_status;
- status = VL53L0X_PerformSingleRangingMeasurement(pdev, pdata); //VL53L0X執行單一測量范圍
- if(status != VL53L0X_ERROR_NONE){
- printf("error:Call of VL53L0X_PerformSingleRangingMeasurement\n");
- return status;
- print_range_status(pdata);
- for(i=0;i<5;i++)
- sum+=pdata->RangeMilliMeter;
- pdata->RangeMilliMeter=sum/5;
- printf("Measured distance: %i\n\n", pdata->RangeMilliMeter);
- sendbuff[0]=200;
- sendbuff[1]=201;
- sendbuff[2]=pdata->RangeMilliMeter%100;
- sendbuff[3]=pdata->RangeMilliMeter/100;
- sendbuff[4]=data1;
- sendbuff[5]=data2;
- for(j=0;j<6;j++)
- USART1->DR = sendbuff[j];
- while((USART1->SR&0X40)==0);//循環發送,直到發送完畢
- return status;
- VL53L0X_Error vl53l0x_measure_init(VL53L0X_Dev_t *pMyDevice)
- VL53L0X_Error Status = VL53L0X_ERROR_NONE;
- //FixPoint1616_t LimitCheckCurrent;
- uint32_t refSpadCount;
- uint8_t isApertureSpads;
- uint8_t VhvSettings;
- uint8_t PhaseCal;
- // Device Initialization
- Status = VL53L0X_StaticInit(pMyDevice); //基本設備初始化
- if(Status != VL53L0X_ERROR_NONE){ //判斷是否初始化成功 失敗打印錯誤信息
- printf ("Call of VL53L0X_StaticInit\n");
- print_pal_error(Status);
- return Status;
- Status = VL53L0X_PerformRefCalibration(pMyDevice, &VhvSettings, &PhaseCal); //執行參考校準
- if(Status != VL53L0X_ERROR_NONE){ //判斷是否校準成功
- printf ("Call of VL53L0X_PerformRefCalibration\n");
- return Status;
- // needed if a coverglass is used and no calibration has been performed
- Status = VL53L0X_PerformRefSpadManagement(pMyDevice,&refSpadCount, &isApertureSpads);
- printf ("Call of VL53L0X_PerformRefSpadManagement\n");
- printf ("refSpadCount = %d, isApertureSpads = %d\n", refSpadCount, isApertureSpads);
- return Status;
- // no need to do this when we use VL53L0X_PerformSingleRangingMeasurement 當我們使用VL53L0X_PerformSingleRangingMeasurement不需要
- Status = VL53L0X_SetDeviceMode(pMyDevice, VL53L0X_DEVICEMODE_SINGLE_RANGING); // Setup in single ranging mode 設置單一測量模式
- printf ("Call of VL53L0X_SetDeviceMode\n");
- return Status;
- // Enable/Disable Sigma and Signal check
- if(Status == VL53L0X_ERROR_NONE){
- Status = VL53L0X_SetLimitCheckEnable(pMyDevice, //啟用/禁用特定限制檢查
- VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE, 1);
- VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE, 1);
- Status = VL53L0X_SetLimitCheckValue(pMyDevice,
- (FixPoint1616_t)(0.25*65536));
- (FixPoint1616_t)(18*65536));
- Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, //設置微秒時間
- 200000);
- printf ("Sigma and Signal check error\n");
- return Status;
- * Step 4 : Test ranging mode
- /* for(i=0;i<10;i++){
- printf ("Call of VL53L0X_PerformSingleRangingMeasurement\n");
- Status = VL53L0X_PerformSingleRangingMeasurement(pMyDevice,
- &vl53l0x_data);
- print_range_status(&vl53l0x_data);
- VL53L0X_GetLimitCheckCurrent(pMyDevice,
- VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, &LimitCheckCurrent);
- printf("RANGE IGNORE THRESHOLD: %f\n\n", (float)LimitCheckCurrent/65536.0);
- if (Status != VL53L0X_ERROR_NONE) break;
- printf("Measured distance: %i\n\n", vl53l0x_data.RangeMilliMeter);
- return Status; //返回0
- VL53L0X_Error vl53l0x_init(void)
- VL53L0X_Error Status = VL53L0X_ERROR_NONE; //初始值賦值為0
- VL53L0X_Dev_t *pMyDevice = &vl53l0x_dev; //得到設備地址
- pMyDevice->I2cDevAddr = 0x52; //iic地址
- pMyDevice->comms_type = 1; //選擇IIC還是SPI iic=1;SPI=0
- pMyDevice->comms_speed_khz = 400; //iic速率
- VL53L0X_i2c_init(); //IIC配置
- Status = VL53L0X_DataInit(pMyDevice); // Data initialization //VL53L0X_DataInit:一次設備的初始化,初始化成功返回0
- if(Status != VL53L0X_ERROR_NONE){ //判斷如果狀態不為0 打印錯誤信息
- return Status; // 返回錯誤值 可通過此值DEBUG查找錯誤位置
- Status = VL53L0X_GetDeviceInfo(pMyDevice, &vl53l0x_dev_info); //讀取給定設備的設備信息
- return Status;
- printf("VL53L0X_GetDeviceInfo:\n");
- printf("Device Name : %s\n", vl53l0x_dev_info.Name); //設備名
- printf("Device Type : %s\n", vl53l0x_dev_info.Type); //產品類型VL53L0X = 1, VL53L1 = 2
- printf("Device ID : %s\n", vl53l0x_dev_info.ProductId); // 設備ID
- printf("ProductRevisionMajor : %d\n", vl53l0x_dev_info.ProductRevisionMajor);
- printf("ProductRevisionMinor : %d\n", vl53l0x_dev_info.ProductRevisionMinor);
- if ((vl53l0x_dev_info.ProductRevisionMajor != 1) && (vl53l0x_dev_info.ProductRevisionMinor != 1)){
- printf("Error expected cut 1.1 but found cut %d.%d\n",
- vl53l0x_dev_info.ProductRevisionMajor, vl53l0x_dev_info.ProductRevisionMinor);
- Status = VL53L0X_ERROR_NOT_SUPPORTED;
- return Status;
- Status = vl53l0x_measure_init(pMyDevice); //測量配置
- vl53l0x_status = Status;
- if(Status != VL53L0X_ERROR_NONE){ //判斷如果不為0打印錯誤信息
- return Status;
復制代碼 全部資料51hei下載地址:
VL53L0X激光測距傳感器.7z
(449.71 KB, 下載次數: 76)
2020-2-21 00:02 上傳
下載積分: 黑幣 -5
