仿真電路圖
2020-2-1 22:39 上傳
匯編程序代碼:
- ORG 0000h
- MAIN:
- SETB P1.7;
- CLR A;
- MOV P2,A;
- ;讓定時(shí)計(jì)數(shù)器0作為定時(shí)器使用,工作在模式1;定時(shí)100ms
- ;讓定時(shí)計(jì)數(shù)器1作為計(jì)數(shù)器使用,工作在模式2,自動(dòng)重裝入;
- MOV TMOD,#61H;
- MOV TH1,#0FBH;
- MOV TL1,#0FBH;給計(jì)數(shù)器置初值,共計(jì)數(shù)五次
- SETB TR1;
- LOOP1:
- CPL A;
- MOV P2,A;
- LOOP2:
- MOV TH0,#3CH;計(jì)時(shí)100ms
- MOV TL0,#0B0H;
- SETB TR0;
- LOOP3:
- JBC TF0,LOOP4;判斷是否計(jì)時(shí)了100ms
- SJMP LOOP3;
- LOOP4:
- CPL P1.7;
- JBC TF1,LOOP1;判斷是否計(jì)數(shù)了5次,如果計(jì)時(shí)已經(jīng)是5次時(shí),跳去執(zhí)行將P2口輸出反向
- AJMP LOOP2;經(jīng)判斷計(jì)數(shù)還未達(dá)到五次,再去計(jì)時(shí)100ms
- END
