查看: 2381|回復(fù): 0
單片機(jī)+sht75+1602 proteus仿真程序
ID:643631 發(fā)表于 2020-1-31 19:52 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include <math.h>
#include <stdio.h>
#define LCD_DB P0
sbit LCD_RS=P2^0;
sbit LCD_RW=P2^1;
sbit LCD_E=P2^2;
void LCD_init(void);
void LCD_write_command(uchar command);
void LCD_write_data(uchar dat);
void LCD_disp_char(uchar x,uchar y,uchar dat);
void LCD_disp_str(uchar x,uchar y,uchar *str);
void delay_n10us(uint n);
void LCD_init(void)
        delay_n10us(10);
        LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
        delay_n10us(10);
        LCD_write_command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
        delay_n10us(10);
        LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
        delay_n10us(10);
        LCD_write_command(0x01);//清除屏幕顯示
        delay_n10us(100);       //延時(shí)清屏,延時(shí)函數(shù),延時(shí)約n個(gè)10us
void LCD_write_command(uchar dat)
        delay_n10us(10);
        LCD_RS=0;         //指令
        LCD_RW=0;         //寫入
        LCD_E=1;          //允許
        LCD_DB=dat;
        delay_n10us(10);  //實(shí)踐證明,我的LCD1602上,用for循環(huán)1次就能完成普通寫指令。
        LCD_E=0;
        delay_n10us(10);
        LCD_RS=1;          //數(shù)據(jù)
        LCD_RW=0;          //寫入
        LCD_E=1;           //允許
        LCD_DB=dat;
        delay_n10us(10);
        LCD_E=0;
        delay_n10us(10);
  uchar address;
  if(y==1)
    address=0x80+x;
    address=0xc0+x;
  LCD_write_command(address);
  LCD_write_data(dat);
  uchar address;
  if(y==1)
     address=0x80+x;
     address=0xc0+x;
  while(*str!='\0')
    LCD_write_data(*str);
    str++;
void delay_n10us(uint n)  //延時(shí)n個(gè)10us@12M晶振
        uint i;
        for(i=n;i>0;i--)
            _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
sbit SCK  = P2^6;      //定義通訊時(shí)鐘端口
sbit DATA = P2^7;      //定義通訊數(shù)據(jù)端口
typedef union
        unsigned int i;      //定義了兩個(gè)共用體
  float f;
} value;
enum {TEMP,HUMI};      //TEMP=0,HUMI=1
#define noACK 0             //用于判斷是否結(jié)束通訊
#define ACK   1             //結(jié)束數(shù)據(jù)傳輸
                            //adr  command  r/w
#define STATUS_REG_W 0x06   //000   0011    0
#define STATUS_REG_R 0x07   //000   0011    1
#define MEASURE_TEMP 0x03   //000   0001    1
#define MEASURE_HUMI 0x05   //000   0010    1
#define RESET        0x1e   //000   1111    0
void s_transstart(void);               //啟動(dòng)傳輸函數(shù)
void s_connectionreset(void);          //連接復(fù)位函數(shù)
char s_write_byte(unsigned char value);//DHT90寫函數(shù)
char s_read_byte(unsigned char ack);   //DHT90讀函數(shù)
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);
void calc_dht90(float *p_humidity ,float *p_temperature);//溫濕度補(bǔ)償
// generates a transmission start
//       _____         ________
// DATA:      |_______|
//           ___     ___
// SCK : ___|   |___|   |______
   DATA=1;
   SCK=0;                   //Initial state
   _nop_();
   SCK=1;
   _nop_();
   DATA=0;
   _nop_();
   SCK=0;
   SCK=1;
   _nop_();
   DATA=1;
   _nop_();
   SCK=0;
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
//       _____________________________________________________         ________
// DATA:                                                      |_______|
//          _    _    _    _    _    _    _    _    _        ___     ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
  unsigned char i;
  DATA=1; SCK=0;                    //Initial state
  for(i=0;i<9;i++)                  //9 SCK cycles
    SCK=1;
    SCK=0;
  s_transstart();                   //transmission start
// writes a byte on the Sensibus and checks the acknowledge
  unsigned char i,error=0;
  for (i=0x80;i>0;i/=2)             //shift bit for masking
    if (i & value) DATA=1;          //masking value with i , write to SENSI-BUS
    else DATA=0;
    SCK=1;                          //clk for SENSI-BUS
    _nop_();_nop_();_nop_();        //pulswith approx. 3 us
    SCK=0;
  DATA=1;                           //release DATA-line
  SCK=1;                            //clk #9 for ack
  error=DATA;                       //check ack (DATA will be pulled down by DHT90),DATA在第9個(gè)上升沿將被DHT90自動(dòng)下拉為低電平。
  SCK=0;
  return error;                     //error=1 in case of no acknowledge //返回:0成功,1失敗
// reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
  unsigned char i,val=0;
    if (DATA) val=(val | i);        //read bit
    SCK=0;
  if(ack==1)DATA=0;                 //in case of "ack==1" pull down DATA-Line
  else DATA=1;                      //如果是校驗(yàn)(ack==0),讀取完后結(jié)束通訊
  SCK=0;
  return val;
// makes a measurement (humidity/temperature) with checksum
  unsigned error=0;
  unsigned int i;
  switch(mode)
  {                     //send command to sensor
    case TEMP  : error+=s_write_byte(MEASURE_TEMP); break;
    case HUMI  : error+=s_write_byte(MEASURE_HUMI); break;
    default     : break;
  for (i=0;i<65535;i++)
          if(DATA==0)
                  break; //wait until sensor has finished the measurement
  if(DATA) error+=1;                // or timeout (~2 sec.) is reached
  *(p_value)  =s_read_byte(ACK);    //read the first byte (MSB)
  *(p_value+1)=s_read_byte(ACK);    //read the second byte (LSB)
  *p_checksum =s_read_byte(noACK);  //read checksum
  return error;
// calculates temperature [C] and humidity [%RH]
// input :  humi [Ticks] (12 bit)
//          temp [Ticks] (14 bit)
// output:  humi [%RH]
//          temp [C]
  const float C1=-4.0;              // for 12 Bit
  const float C2=+0.0405;           // for 12 Bit
  const float C3=-0.0000028;        // for 12 Bit
  const float T1=+0.01;             // for 14 Bit @ 5V
  const float T2=+0.00008;           // for 14 Bit @ 5V
  float rh=*p_humidity;             // rh:      Humidity [Ticks] 12 Bit
  float t=*p_temperature;           // t:       Temperature [Ticks] 14 Bit
  float rh_lin;                     // rh_lin:  Humidity linear
  float rh_true;                    // rh_true: Temperature compensated humidity
  float t_C;                        // t_C   :  Temperature [C]
  t_C=t*0.01 - 40;                  //calc. temperature from ticks to [C]
  rh_lin=C3*rh*rh + C2*rh + C1;     //calc. humidity from ticks to [%RH]
  rh_true=(t_C-25)*(T1+T2*rh)+rh_lin-3;   //calc. temperature compensated humidity [%RH]
  if(rh_true>100)rh_true=100;       //cut if the value is outside of
  if(rh_true<0.1)rh_true=0.1;       //the physical possible range
  *p_temperature=t_C;               //return temperature [C]
  *p_humidity=rh_true;              //return humidity[%RH]
void main(void)
        value humi_val,temp_val;
        unsigned char error,checksum;
        unsigned int wendu,shidu;
        LCD_init();
        s_connectionreset();
        LCD_disp_str(0,1,"TE");
        LCD_disp_str(0,2,"RH");
//*********初始化溫度顯示區(qū)*********
        LCD_disp_str(2,1,"TTT.TC");
//*********初始化濕度顯示區(qū)*********
        LCD_disp_str(2,2,"RRR.R%");
        delay_n10us(20000);     //延時(shí)0.2s
                                  error=0;
          error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI);  //measure humidity
          error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP);  //measure temperature
          if(error!=0) s_connectionreset();                 //in case of an error: connection reset
                                          humi_val.f=(float)humi_val.i;                   //converts integer to float
            temp_val.f=(float)temp_val.i;                   //converts integer to float
            calc_dht90(&humi_val.f,&temp_val.f);            //calculate humidity, temperature
            wendu=10*temp_val.f;
            LCD_disp_char(2,1,wendu/1000+'0');              //顯示溫度百位
            LCD_disp_char(3,1,(wendu%1000)/100+'0');        //顯示溫度十位
            LCD_disp_char(4,1,(wendu%100)/10+'0');          //顯示溫度個(gè)位
            LCD_disp_char(6,1,(wendu%10)+'0');              //顯示溫度小數(shù)點(diǎn)后第一位
            shidu=10*humi_val.f;
            LCD_disp_char(2,2,shidu/1000+'0');               //顯示濕度百位
            LCD_disp_char(3,2,(shidu%1000)/100+'0');         //顯示濕度十位
            LCD_disp_char(4,2,(shidu%100)/10+'0');           //顯示濕度個(gè)位
            LCD_disp_char(6,2,(shidu%10)+'0');               //顯示濕度小數(shù)點(diǎn)后第一位
          //----------wait approx. 0.8s to avoid heating up SHTxx------------------------------
          delay_n10us(80000);                                //延時(shí)約0.8s
全部資料51hei下載地址:
sht75+1602.rar (76.44 KB, 下載次數(shù): 38)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
