查看: 4450|回復: 2
51單片機火災報警Proteus仿真程序 adc0808+1602顯示
用滑動變阻代替煙霧、溫度傳感器。采有adc0808雙通道,通過at89c52,lcd1602顯示。
  1. #include "reg52.h"
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. #define yushe_wendu 54
  6. #define yushe_yanwu 23
  7. uchar code Init1[]="SET:000  NOW:000";
  8. uchar code Init2[]="SEY:000  NOW:000";
  9. uchar code num[]="0123456789";
  10. uchar temp;
  11. unsigned char CHANNEL; //AD channel variable
  12. sbit ST_ALE=P3^0;   //START and ALE both connect to P3.0
  13. sbit EOC=P3^1;   //EOC connect to P3.1
  14. sbit OE=P3^2;    //OE conect to P3.2
  15. sbit CLK=P3^3;
  16. sbit lcdrs=P2^4;
  17. sbit lcdrw=P2^5;
  18. sbit lcden=P2^6;
  19. sbit beep=P3^4;
  20. sbit led=P3^5;
  21. void delay(uint x)
  22. {
  23.         uint i;
  24.         for(;x>0;x--)
  25.                 for(i=5;i>0;i--);
  26. }
  27. void write_com(uchar com )
  28. {
  29.         lcden = 0;
  30.         lcdrs = 0;//表示命令選擇
  31.         P1 = com;
  32.         delay(5);
  33.         lcden=1;
  34.         delay(5);
  35.         lcden=0;
  36.
  37. }
  38. void write_data(uchar date)
  39. {
  40.         lcden = 0;
  41.         lcdrs = 1;//n.1 write into the data;
  42.         P1 = date;
  43.         delay(5);
  44.         lcden=1;
  45.         delay(5);
  46.         lcden=0;
  47. }
  48. //1602初始化
  49. void Init1602()
  50. {
  51.   uchar i=0;
  52.   write_com(0x38);//屏幕初始化
  53.   write_com(0x0c);//打開顯示 無光標 無光標閃爍
  54.   write_com(0x06);//當讀或寫一個字符是指針后一一位
  55.   write_com(0x80);//設置位置
  56.
  57. for(i=0;i<4;i++)
  58.   {
  59.                 write_data(Init1[i]);          //顯示數組1的數據
  60.   }
  61.         write_com(0x80+9);
  62. for(i=9;i<13;i++)
  63.   {
  64.                 write_data(Init1[i]);          //顯示數組1的數據
  65.   }
  66.   write_com(0x80+0x40);//設置位置
  67. for(i=0;i<4;i++)
  68.   {
  69.                 write_data(Init2[i]);          //顯示數組2的數據
  70.   }
  71.         write_com(0x80+0x40+9);
  72. for(i=9;i<13;i++)
  73.   {
  74.                 write_data(Init2[i]);          //顯示數組2的數據
  75.   }
  76. }
  77. void display(uchar channel)
  78. {
  79. unsigned long temp;
  80. unsigned int k=0,i=0;
  81. temp=P0;    //the temporary variable
  82.         if(channel==0)
  83.         {
  84.         write_com(0x80+4);                    //設置煙霧
  85.         write_data(0x30+yushe_wendu/100);
  86.         write_data(0x30+yushe_wendu%100/10);
  87.         write_data(0x30+yushe_wendu%10);
  88.         write_com(0x80+13);               //時時煙霧
  89.         write_data(0x30+temp/100);
  90.         write_data(0x30+temp%100/10);
  91.         write_data(0x30+temp%10);
  92.         }
  93.         if(channel==1)
  94.         {
  95.   write_com(0x80+0x40+4);           //設置煙霧
  96.         write_data(0x30+yushe_yanwu/100);
  97.         write_data(0x30+yushe_yanwu%100/10);
  98.         write_data(0x30+yushe_yanwu%10);
  99.         write_com(0x80+0x40+13);           //時時煙霧
  100.         write_data(0x30+temp/100);
  101.         write_data(0x30+temp%100/10);
  102.         write_data(0x30+temp%10);
  103.         }
  104. }
  105. void main()
  106. {
  107. CHANNEL=0xF8;  //AD channel 0
  108. ST_ALE=0;   //START and ALE default
  109. OE=0;    //OE default
  110. TMOD=0x02;  //T0 operate in mode 2
  111. TH0=0xFF;   //auto load value
  112. TL0=0xFF;   //default value
  113. EA=1;    //all interrupt enable
  114. ET0=1;    //T0 interrupt enable
  115. TR0=1;    //T0 run
  116. beep=0;
  117. led=0;
  118. while(1)
  119. {
  120.   P2=0x07&CHANNEL;  //choose AD channel
  121.   ST_ALE=1;  //lock the AD channel address
  122.   ST_ALE=0;  //AD run
  123.   Init1602();
  124.   while(EOC==0); //wait until AD over
  125.   OE=1;   //enable to transmit AD data
  126.   if(CHANNEL==0xF8)
  127.   {
  128.   display(0);   //view the AD result and diaplay LED
  129.   }
  130.   if(CHANNEL==0xF9)
  131.   {
  132.   display(1);   //view the AD result and diaplay LED
  133.   }
  134.   delay(50);     //delay to prepare for next AD channel
  135.   OE=0;          //forbit to transmit AD data
  136.   if(CHANNEL==0xF9)
  137.   CHANNEL=0xF7;             //AD channel loop
  138.   CHANNEL++;                //next AD channel
  139. }
  140. }
  141. void T1_TIME() interrupt 1 using 0
  142. {
  143. CLK=~CLK;   //CLK 500 kHz
  144. }
火災報警兩路.zip (303.19 KB, 下載次數: 86)
ID:582615 發表于 2020-1-16 10:21 | 只看該作者
本帖最后由 cbay 于 2020-1-16 10:23 編輯
壓縮包里包括仿真和keil
ID:687379 發表于 2020-1-19 17:21 | 只看該作者
cbay 發表于 2020-1-16 10:21
壓縮包里包括仿真和keil
可以加一下你請教一下這個問題嗎
